Prevent a window can be moved
jparada
Post by jparada »
Is there any way (or trick) to prevent a user can not move a window by clicking on the title bar of the window (I hope I've explained).
Please I await your comments.
Best Regards
Javier
Re: Prevent a window can be moved
jparada wrote: Is there any way (or trick) to prevent a user can not move a window by clicking on the title bar of the window
Hola Javier
AFAIK we haven't a NOMOVE keyword in DEFINE WINDOW statement. IMHO only you can use NOCAPTION for prevent user to use the title bar (if appropriate your need).
Saludos, Regards
Czarny_Pijar
Post by Czarny_Pijar »
jparada
For my own curiosity I've checked every available option in the HMG. Looks like at this time with this tool you can't do this.
You can prevent moving the window in this way:
1. Rememeber the position of window
2. When user moves window - move it programmatically to the previous position
You are gr8 Marek. :)
A creative and logical approach to the problem.
jparada
Post by jparada »
Thanks for your answers.
Esgici:
The problem is I need the title bar.
Czarny_Pijar
I already knew
Marek
Sorry, I personally do not like this "trick"
Thanks
Best Regards
Javier
jparada wrote:
Marek wrote:You can prevent moving the window in this way:
Hola Javier
In my opinion, the suggestion of Marek is cool. Though you don't like, take a look at this :
#include "minigui.ch"
FUNC Main()
   nWindWidth  := 500
   nWindHeight := 400
   nUnMWinCol := ( GetDesktopWidth() - nWindWidth ) / 2
   nUnMWinRow := ( GetDesktopHeight() - nWindHeight ) / 2
   DEFINE WINDOW frmUnMoveable ;
      WIDTH 500 ;
      HEIGHT 400 ;
      TITle "Unmoveable Window" ;
      ON KEY ESCAPE ACTION frmUnMoveable.Release
      DEFINE TIMER Timer_1 ;
                 INTERVAL 100 ;
                 ACTION { || thisWindow.Row := nUnMWinRow, thisWindow.Col := nUnMWinCol }
   frmUnMoveable.CENTER
   ACTIVATE WINDOW frmUnMoveable
RETU
Hopefully, a friend may achieve this by a less "tricky" way ;)
Hi friend Esgici,
very nice your code ;)
I would add
ON MAXIMIZE (thisWindow.restore)
best regards,
Claudio Soto
Hola a todos,
les dejo un par de funciones generales para bloquear el movimiento de una determinada ventana, para un mejor funcionamiento seria preferible para no interferir con el botón de maximizar que la misma fuese difinida como NOMAXIMIZE o en su defecto con
ON MAXIMIZE (thisWindow.Restore), de lo contrario cuando pulsan el botón de maximizar la ventana permanece con el mismo tamaño
pero el sistema toma como que se maximizo y cambia dicho botón a RESTORE, y viceversa.
Pueden comprobarlo en el ejemplo que les dejo abajo.
Saludos,
Claudio Soto.
* SINTAXIS:
* MOVE_WINDOW_F (<cWindowName>) // BLOQUEA movimiento de la ventana
* MOVE_WINDOW_T (<cWindowName>) // DESBLOQUEA movimiento de la ventana
* MOVE_WINDOW (<cWindowName>) // Retorna .T. MOVIBLE --- Retorna .F. NOMOVIBLE
* PROGRAMA: NO MOVE WINDOW
* LENGUAJE: HARBOUR-MINIGUI 3.0.26
* FECHA:    28 MARZO 2010
* AUTOR:    CLAUDIO SOTO
* PAIS:     URUGUAY
* E-MAIL:   srvet@adinet.com.uy
* SINTAXIS:
* DEFINICION DE LOS COMANDOS
#xtranslate MOVE_WINDOW_FALSE (<cWindowName>);
#xtranslate MOVE_WINDOW_TRUE (<cWindowName>);
//     MOVE_WINDOW (<cWindowName>)
declare window form_2
		WIDTH 400 ;
		HEIGHT 500 ;
		TITLE 'NO MOVE WINDOW' ;
		MAIN  //ON MAXIMIZE (thisWindow.Restore)
        @ 10,10 LABEL Label_1 VALUE IF (MOVE_WINDOW ("Form_1"),"MOVER SI","MOVER NO")
        @ 100, 100 BUTTON boton_1 CAPTION "NO MOVER" ACTION {|| MOVE_WINDOW_FALSE ("Form_1"), Form_1.Label_1.Value := IF (MOVE_WINDOW ("Form_1"),"MOVER SI","MOVER NO")}
        @ 100, 250 BUTTON boton_2 CAPTION "MOVER"    ACTION {|| MOVE_WINDOW_TRUE  ("Form_1"), Form_1.Label_1.Value := IF (MOVE_WINDOW ("Form_1"),"MOVER SI","MOVER NO")}
        @ 200, 100 BUTTON boton_3 CAPTION "Ventana 2" ACTION ventana2 (1)
        @ 200, 250 BUTTON boton_4 CAPTION "NO MOVER 2" ACTION ventana2 (2)
	Form_1.Center
	Form_1.Activate
Procedure Ventana2 (n)
IF n = 1
    IF IsWindowDefined (form_2)
    DEFINE WINDOW Form_2 ;
		AT 10,10 ;
		WIDTH 300 ;
		HEIGHT 300 ;
		TITLE 'Vent2' ;
		CHILD
    Form_2.Activate
IF n = 2 .AND. IsWindowDefined (form_2)
   MOVE_WINDOW_FALSE ("Form_2")
* DEFINICION DE LAS FUNCIONES
Procedure MOVE_WINDOW_F (vent)
Local y := GetProperty (vent , "ROW")
Local x := GetProperty (vent , "COL")
Local h := GetProperty (vent , "HEIGHT")
Local w := GetProperty (vent , "WIDTH")
Local ctrl := "tmr_"+vent
   IF .NOT. (IsControlDefined (&ctrl , &vent))
       DEFINE TIMER &ctrl OF &vent INTERVAL 50 ACTION NO_MOV_WIN_C (GetFormHandle(vent), y, x, h, w)
Procedure MOVE_WINDOW_T (vent)
   IF  IsControlDefined (&ctrl , &vent)
       DoMethod (vent ,ctrl ,"Release")
Function MOVE_WINDOW (vent)
Return .NOT.(IsControlDefined (&ctrl , &vent))
*   FUNCION EN C
#pragma begindump
#include <shlobj.h>
#include <winuser.h>
#include <windows.h>
#include "hbapi.h"
// NO_MOV_WIN_C (hWND, y, x, h, w)
HB_FUNC (NO_MOV_WIN_C)
   HWND hWND;
   int x, y, h, w;
   hWND = (HWND) hb_parnl (1);
   y    =  hb_parni (2);
   x    =  hb_parni (3);
   h    =  hb_parni (4);
   w    =  hb_parni (5);
   SetWindowPos (hWND, HWND_TOP, x, y, w, h, SWP_NOZORDER | SWP_NOACTIVATE);
#pragma enddump
