Creating Data bases
Creating Data bases
Hello friends
I present a small application that I use
to create my databases and modify its structure.
A small share contrubucion
Greetings to all
Hola amigos
Les presento una pequeña aplicación que yo utilizo
para crear mis Bases de Datos y Modificar su Estructura.
Una pequeña contrubucion para compartir
Un saludo a todos
Mustafa :lol:
dBu_ML_in.zip
(879.3 KiB) Downloaded 802 times
Re: Creating Data bases
Muy buena la aplicación Mustafa, tanto en lo visual como en lo funcional.
FELICITACIONES !!!
Saludos,
Claudio.
Hola Claudio
Haber si nos comemos un asado ja.... ja...
En tu magnifico Pais
Un abrazo
Mustafa :P
Por supuesto, lo comeremos cuando tu quieras Mustafa.
Mis únicos dos sobrinos son catalanes, viven en Barcelona.
Viva la Madre Patria !!!.
Un fuerte abrazo,
Claudio.
Vanguarda
Post by Vanguarda »
Hi friends,
Thanks for share Mustafa. Nice app.
My best regards,
Hello friends
Here are the Spanish version
A greeting
Hola amigos
Aqui tienen la versión en Español
Un saludo
Mustafa :lol:
dBu_ML.zip
(880.51 KiB) Downloaded 614 times
swapan
Post by swapan »
Xcellent Work Mustafa!
Thanks for sharing.........
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
sudip
Post by sudip »
Hello Mustafa,
Thanks a lot.
Good utility :) (I just tried it)
When I try click on "Seek DBF" button and selected a dbf file, it always shows following message:
I have to use Ctrl+Alt+Del key to come out of the program.
With best regards.
Hi Sudip
In Dbf SEEK button, in principle, I created for
Dbf view found in the [New] in folder
Main Program [dBu_ML_in]
This error is not how to fix?
Not long dominated the issue of search folders and directories
of all Forms I managed to not give you the error message
and not to leave the program.
Sorry but I thought that only visionary Files
Folder dbf [New] what not to do in the search is
only have access to this folder.
Excuse the problems created
Greetings
I leave you in the corrections Zip
Hola Sudip
En el Boton Seek Dbf , en principio lo he creado para
ver los Dbf que se encuentran en la carpeta [ New ]de la Carpeta
principal del Programa [dBu_ML_in]
Este error no se como solucionarlo ?
No domino mucho el tema de la Busqueda entre carpetas y directorios
de todas Formas ya he logrado que no te de el error del Mensaje
y que no se pueda salir del programa.
Lo siento pero yo lo pense para que solo se visionara los Ficheros
Dbf de la Carpeta [New] lo que no se hacer en la Busqueda es que
solo se tenga acceso a esta carpeta.
Disculpar los Problemas creados
Un saludo
Les dejo en el Zip las correcciones
dBu_ML_in.zip
(879.32 KiB) Downloaded 575 times
Hello Friends
Here I leave the corrections version
Spanish
Greetings
Hola Amigos
Aqui les dejo las Correcciones en la version
Española
Un saludo
dBu_ML.zip
(880.77 KiB) Downloaded 656 times
