HMG-Linux warning of sample hmglow.c are removed...
marcobra
I use only Linux so i need http://harbourminigui.googlepages.com/linux harbour_minigui to works...
I dressed the warnings of hmg/source/hmglow.c, and it works, in attach the hmglow_marcobra.c modified...
Open a terminal and type:
cd $HOME/hmg/source
mv hmglow.c hmglow_old.c
mv hmglow_marcobra.c hmglow.c
and build the test.prg
cd ../samples/
./compile.sh test
Still some warning to dress into hmghigh.prg
But cannot attach the file here or i don't see the attached file so i put the file also here:
http://www.elart.it/harbour/hmg-linux/hmglow_marcobra.c
Thank you
cd $HOME/hmg/source
cd ../samples/
./compile.sh test
Thank you
marcobra
Re: HMG-Linux warning of sample hmglow.c are removed...
I added all the hmg for linux structure with latest Harbour in it dev version..
No more warnings and it compile and run...
I have put the entire tar.gz file here...
http://www.elart.it/harbour/hmg-linux/h ... 01a.tar.gz
Please try, open a terminal and type:
wget http://www.elart.it/harbour/hmg-linux/h ... 01a.tar.gz
tar -xvzf hmg-linux-001a.tar.gz
cd hmg/samples
./compile.sh test
./test
i have only a terminal issue after exit from test so i must to (blind) type:
reset
into terminal window to reset it...
Thank you
cd hmg/samples
./compile.sh test
./test
reset
Thank you
- apais
Can you post some screenshots.
I'd like to see how HMG looks like under linux.
Thanks in advance !
Thanks in advance !
Angel Pais
marcobra
Here a screenshot of test app:... the hmg/samples/test running...
- Screenshot.png (64.91 KiB) Viewed 29647 times
- apais
very nice !!
will have to put my ubuntu notebook partition to do something productive
Angel Pais
marcobra
Yes i suggest you to install the Ubuntu 8.04 LTS (Long Time Support) standard desktop 32 bit, dont' install it using Wubi ( Windows UBuntu Installer ) simply boot from your self made Ubuntu cd here the torrent files http://torrent.ubuntu.com:6969/
Here the easy steps to install Ubuntu 8.04.1 https://help.ubuntu.com/community/GraphicalInstall
Download and burn your Ubuntu live install cd from the ubuntu-8.04.1-desktop-i386.iso
Or if you want the latest Ubuntu 8.10 the ubuntu-8.10-desktop-i386.iso
Please refer for any questions and to submit bugs to the wonderful Launchpad platform https://launchpad.net/
For Ubuntu --- https://launchpad.net/ubuntu
and for your questions and answers to https://answers.launchpad.net/ubuntu
Thank you
Thank you
Just great to see HMG in Linux.
Can you connect a MySQL database?
- apais
I have ubuntu 8.04 installed since months, and even have compiled harbour itself on it.
The only thing i've not done is testing either gui library on it yet.
Hwgui is only available from svn i I don't undestand it.
xhGTK remains a mistery for me.
HMG on its linux version could be a starting point to gui programming under ubuntu.
Let's see what can be done...
Angel Pais
- Roberto Lopez
- HMG Founder
I've made HMG-LINUX two years ago, when I've discovered Ubuntu (6.06 at that time).marcobra wrote:I use only Linux so i need http://harbourminigui.googlepages.com/linux harbour_minigui to works...
cd $HOME/hmg/source
cd ../samples/
./compile.sh test
Thank you
It was a mere experiment. I've worked on it by about two weeks.
It was a very big surprise to me how easy and powerful is GTK compared to Win32API.
A basic MiniGUI library compatible version for GTK could be done in relatively short time.
Roberto.
marcobra
@Roberto i will glad to help you (i use only Linux) it in my spare time, but i need some starting point to begin. Do you have some suggestion...
My skill are (Unix, dos, clipper->visual object->harbour some c and other...)
My fav Linux distribution, which i contribute every day (answering to the users on Launchpad) is Ubuntu ( Gnome Desktop Environment )
Is about 3 year that i use it, i'm very glad and i don't use Window anymore.
I think porting your lib under Gnu Linux will be wonderful.
Here my question on about HMG_Linux on the Harbour developer mailing list:
http://lists.harbour-project.org/piperm ... 13570.html
Thank you
@rathinagiri Yes with Ubuntu using Harbour i'm able to connect to, in order of interest:
Postgresql
sqllite
mysql
Take a look into harbour/contrib/... sources there are contrib library with samples.
Here from harbour trunk svn:
http://harbour-project.svn.sourceforge. ... r/contrib/
Thank you
Thank you
Postgresql
sqllite
mysql
Thank you
