HMG 3.0.25
sudip
Re: HMG 3.0.25
Post by sudip »
Roberto Lopez wrote:
Roberto Lopez wrote: Another very interesting thing are the 'clips'. This feature are similar to Intellisense and the definition files are in PsPad\Context. Sadly there is no Harbour nor HMG definitions there, so, we should do one :)
Volunteers for this? :)
Hello Roberto,
I installed PSPad a few months ago. I found Harbour.ini in C:\Program Files\PSPad editor\Syntax folder.
I first unchecked "Foxpro" in Settings -> Highlighter Settings.
Then I load "Harbour.ini" from Settings -> User Highliter Settings. Then changed necessary keywords.
In most cases it runs fine.
I want to volunteer this ... :)
With best regards.
claudiotedesco
Re: HMG 3.0.25
Post by claudiotedesco »
Hola
Queria saber porque me da el siguiente error el PsPad, yo estoy usando Windows 2000 con SP4
Gracias.
Claudio
Adjunto error
error PsPad.jpg (42.16 KiB) Viewed 5353 times
claudiotedesco
Re: HMG 3.0.25
Hola
Estuve probando el Ejemplo: \samples\grid.34 y cuando hago alguna modificacón y luego aplico ONSAVE no me guarda la modificacion realizada. El ejemplo anterior Ejemplo: \samples\grid.33 si funciona perfectamente.
Estoy usando Windows 2000 con SP4,
Gracias.
Claudio
Hello
I try the example: \ samples \ grid.34 and when do I apply some OnSave modificacón then saving changes I made. The above example Example: \ samples \ grid.33 if it works perfectly.
I'm using Windows 2000 with SP4,
Thank you.
Claudio
Re: HMG 3.0.25
Hi Roberto,
Thanks for including PsPad. I had tried the editor. 'On init' I liked the automatic parenthesis/quote set insertion. If it can be extended to
'{ }' and '[ ]', it would be great.
Steed
Re: HMG 3.0.25
Post by Steed »
Hello Roberto,
Will be nice and more naturally, modify cell in a grid without press enter, like Excel or access (you only press any key -char or val- and the cell pass to edit mode adding the char or value that you have pressed)
Nice idea Sudip
Ed
Re: HMG 3.0.25
Steed wrote:Hello Roberto,
Nice idea Sudip
Ed
Fine option, but I think, it should be switchable...
Marek
Re: HMG 3.0.25
sudip wrote:
Roberto Lopez wrote:...
I'm not sure of fully understand your request...
Do you mean to set a different key that <enter> to entering edit mode?
Hello Roberto,
I want to say that, presently edit mode of the grid is activated only by pressing Enter key or DblClick. Is there any way to activate edit mode when user will press any key (other than navigation keys). For example Excel or VFP grid.
With best regards.
Ok.
Currently, no. The only way to edit a cell is using <enter> or double clicking it.
Re: HMG 3.0.25
Yes, I make it.
Give some time, ok?!
My best regards,
Ok!!!
Re: HMG 3.0.25
With best regards.
Good!
Re: HMG 3.0.25
claudiotedesco wrote:Hola
Gracias.
Claudio
Hello
Thank you.
Claudio
That sample do not save data.
It only shows how to use buffered changes to create your own 'save' procedure.
