On error...
On error...
In HMG, can we have some error catching blocks (like try...catch... in Java) that shall be executed before the application is closed abruptly?
For operations like saving some files, closing the database connections, re-encrypt the decrypted files?
Re: On error...
That is a question I have asked myself many times.
Is use the clipper command
To log real serious errors.
How do you guys catch errors?
Raumi
ERRORBLOCK({ |oErr| MyOnError(oErr)})How do you guys catch errors?
Raumi
Raumi75 http://raumi75.jimdo.com
- esgici
Re: On error...
Hi Rathi and Raumi
Did you tried BEGIN/END SEQUENCE structure ?
Viva INTERNATIONAL HMG
Re: On error...
Nope Esgici. I will try.
- Roberto Lopez
- HMG Founder
Re: On error...
I use this in IDE to report preview and works perfectly (I've adapted from an old Clipper sample.
bSaveHandler := errorblock( { |x| break(x) } )
BEGIN SEQUENCE
* This is the code to execute that could fail
EXECUTE REPORT _TempReport PREVIEW
DELETE FILE RePreviewSemaforo.Txt
RECOVER USING oError
* This is the code to execute if the above code fails
MSGSTOP( oError:Description + " " + oError:Operation , "Report Error:" )
Exit Program
END
errorblock( bSaveHandler )Regards/Saludos,
- Roberto Lopez
- HMG Founder
Re: On error...
A more useful sample is shown in Clipper manual:
This example demonstrates an error handler returning an error
object to the variable specified in the USING clause of the RECOVER
statement:
LOCAL objLocal, bLastHandler
// Save current and set new error handler
bLastHandler := ERRORBLOCK({ |objErr| ;
MyHandler(objErr, .T.) })
BEGIN SEQUENCE
. <operation that might fail>
RECOVER USING objLocal
// Send messages to objLocal and handle the error
? "Error: "
IF objLocal:genCode != 0
?? objLocal:description
END
// Restore previous error handler
ERRORBLOCK( bLastHandler )
FUNCTION MyHandler( objError, lLocalHandler )
// Handle locally returning the error object
IF lLocalHandler
BREAK objError
. <other statements to handle the error>
RETURN NILRegards/Saludos,
Re: On error...
Thanks Roberto. I will go through and use it.
Re: On error...
I'm using errorblock and begin/end sequence.
In one of my latest projects I've added sending e-mail with error to me, when something wrong is going on...
- esgici
Re: On error...
Hi Rathi
A little (!?) late answer (because just added) : a short compilation about error handling
I hope that will be useful
Re: On error...
Hello all,
This interests me
It would be possible to assemble a complete example to demonstrate this new method using error control and the old ?
Best Regards,
Rossine.
This interests me
Best Regards,
Rossine.
