HMG 3.0.21
- Roberto Lopez
- HMG Founder
HMG 3.0.21
- HMG 3.0.21 Changelog:
English:
- Fixed: build.bat incorrect in various samples.
- Fixed: Misc. data-bound Grid problems: Filtered and conditional
indexed tables, SQLMIX and POSTGRE RDD locking bugs and some other
minor bugs. Thanks to raumi75, Mol and Vanguarda for reports on
problems.
- Fixed: Problem with Player control. Reported by Vanguarda.
- New: GRID.31, GRID.32 samples.
- Updated: HFCL. Contributed by Rathinagiri.
Español:
- Solucionado: 'build.bat' incorrecto en varios ejemplos.
- Solucionado: Varios problemas en Grid: Tablas filtradas y con
índices condicionales, bloqueo con SQLMIX y POSTGRE y varios bugs menores.
Gracias a Raumi75, Mol y Vanguarda por los reportes.
- Solucionado: Problema con el control Player. Reportado por Vanguarda.
- Nuevo: Ejemplos GRID.31 y GRID.32.
- Actualizado: HFCL. Gracias a Rathinagiri.
Download / Descarga: www.hmgforum.com/site
English:
problems.
Español:
Re: HMG 3.0.21
Hi friends,
Thanks Master for this new version
My best regards,
My best regards,
Re: HMG 3.0.21
Thank you Roberto for the new release.
I tested the new Samples GRID.31 and GRID.32 and I am not sure, if the behaviour is intentional.
GRID.31 (SET DELETED Test)
I select the first row and click chose "RecNo" from the menu. Message: 1
I select the second row (Value 3, because row 2 is deleted). Recno is 3
I select the third row (Value 5, because row 4 is deleted). Recno IS 3 ALSO!
The Rows with the value 7 and 9 are both Recno 5.
The Rows with the value 10 and 11 are both Recno 7.
That was the sample without any modifications.
When I change the sample to SET DELETED OFF, the deleted rows are greyed out. Nice! I like that. The Recno-Function works right, when deleted is off.
Sample GRID.32 also gives wrong RecNos.
I tried to change the Sample to allow editing, but now got the error:
GRID: Editing filtered / condidtional indexed tables is not allowed. Program terminated
This error makes it a lot clearer, why the program misbehaves.
Raumi75 http://raumi75.jimdo.com
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.21
You are right.raumi75 wrote:Thank you Roberto for the new release.
I've discovered the problem many hours after publishing.
It's already fixed.
The fix will be included in the next release.
Here is it. You must replace the following functions in h_grid.prg and recompile the library.
function setdatagridrecno ( i , nRecNo )
Local cRecordSource := ''
Local aValue
Local nLogicalPos := 0
Local j := 1
cRecordSource := _HMG_SYSDATA [ 40 ] [ i ] [ 10 ]
nBakReNo := &cRecordSource->(RecNo())
aValue := _GetValue ( , , i )
if ( empty ( &cRecordSource->( dbFilter () ) ) ) .and. ( .Not. Set ( _SET_DELETED ) )
&cRecordSource->( dbGoTo ( nRecNo ) )
nLogicalPos := &cRecordSource->( OrdKeyNo () )
MsgMiniGuiError("GRID: Set RecNo property not allowed for filtered tables. Program terminated" )
&cRecordSource->( DbGoTo ( nBakReNo ) )
_SetValue ( , , { nLogicalPos , aValue [2] } , i )
DataGridRefresh(i)
return nil
function getdatagridrecno(i)
Local nItemCount
Local nHandle
Local aColumnFields := {}
Local lRet := .T.
Local j
Local aValue
Local nLogicalPos
Local nRecNo
Local nTopIndex
Local nBakReNo
aColumnFields := _HMG_SYSDATA [ 40 ] [ i ] [ 11 ]
nHandle := _HMG_SYSDATA [ 3 ] [ i ]
&cRecordSource->( OrdKeyGoTo ( aValue[1] ) )
&cRecordSource->( dbGoTop() )
&cRecordSource->( dbSkip( aValue[1] - 1 ) )
nRecNo := &cRecordSource->(RecNo())
return nRecNo
Re: HMG 3.0.21
Thanks Roberto.
Re: HMG 3.0.21
Thank you. I replaced the functions and now it works.
Raumi
Raumi
Re: HMG 3.0.21
Thanks a lot Roberto for this version
It works fine. It takes 2/3 seconds only to open a large .dbf table with 522,813 records using my Celeron 1.66 laptop with 760mb ram and XP SP2. It's really very good
I used following code for testing:
With best regards.
local mTable := GetFile ( { {'DBF Files','*.DBF'} } , "Select DBF File"), mAlias := ""
local aFldnm := {}, aWidth := {}, aStruct := {}
if empty(mTable)
return nil
use &mTable
mAlias := alias()
aStruct := dbstruct()
for i = 1 to len(aStruct)
aadd(aFldnm, aStruct[i, 1])
aadd(aWidth, aStruct[i, 3]*10)
next
define window main at 0, 0 width 500 height 500 title mTable main
@ 10,10 GRID Grid_1 ;
WIDTH 470 ;
HEIGHT 440 ;
HEADERS aFldnm ;
WIDTHS aWidth;
VALUE { 1 , 1 } ;
ROWSOURCE mAlias ;
COLUMNFIELDS aFldnm
end window
Main.Center
Main.Activate
ReturnSudip
Re: HMG 3.0.21
Hello my friends,
Roberto, i´ve a little doubt about activeX control.
I´ve a little project that i did for tests (is attached in this post).
Well, in this project i have a main ("Main.FMG") window with a button that call another window ("Test.FMG") that have a activex control. When a close the second window ("Test.FMG") i got error message of windows OS. When i not have the error on close the Test.FMG window, i click on the button of my MAIN window for call the second window again, so i got the same error again. Please, so kind, see the image bellow.
My doubt is: I can´t call a window with activeX control defined more than one time?!
I´ve use Windows 7 Ultimate version with theme Aero Default.
PS: Sorry for disturbing, and sorry my bad english.
With kind regards,
With kind regards,
- ActiveX.JPG (54.36 KiB) Viewed 5067 times
- Test_ActiveX.rar
- (584.54 KiB) Downloaded 329 times
Re: HMG 3.0.21
Hi friends,
Roberto, i´ve a little wishe for HMG IDE.
When us added a new module (.PRG) the same is created like this:
Exist some way for add new module function, create a new module with this initial lines?
Please, it is a little wishe. If i say stupid things, let me know, ok?!
My best regards,
PS: Sorry my bad english
Load Window Main
Main.Center
Main.Activate
ReturnCode: Select all
* Program......: <Name of program>
* Programmer...:
* Created at...: <currently date> / <currently time>
* Finished at...:
*Description:
Load Window Main
Main.Center
Main.Activate
ReturnMy best regards,
