HMG 3.0 FORUM TEST XVII
Vanguarda
Re: HMG 3.0 FORUM TEST XVII
Post by Vanguarda »
Roberto Lopez wrote: I've erroneously deleted such function present in previous releases. It is used by EDIT command.
You can ad the code anywhere and recompile the library.
Thanks Master for solve my problem.
My best regards,
mol wrote:For which function/property NoArray function is needed?
Vanguarda
Post by Vanguarda »
Hello friends,
Master, I´ve a wish, please, exist some way for that the function "Import File" be able import a lot of file of the same type? Currently the function allow only one file per time.
Sorry my bad english.
My best regards,
Vanguarda wrote:Hello friends,
My best regards,
It is possible and could be very useful.
I'll consider for post 3.0 release.
Thanks for the suggestion.
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote: It is possible and could be very useful.
Thanks a lot Master.
I've reached such an error in IDE:
Harbour MiniGui Errorlog File
Date:2010.01.21 Time: 08:10:21
Error: HMG 3.0.0 Forum Test XVII (2010.01.16)
Non top modal windows can't be released. Program terminated
Called from _RELEASEWINDOW(3097)
Called from DOMETHOD(7296)
Called from (b)SHOWLOG(42094)
Called from _DOCONTROLEVENTPROCEDURE(4884)
Called from EVENTS(562)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4548)
Called from DOMETHOD(7287)
Called from SHOWLOG(42270)
Called from NEWBUILD(38573)
Called from (b)HMGMAKE(38486)
Called from _PROCESSINITPROCEDURE(4723)
Called from _ACTIVATEWINDOW(4547)
Called from HMGMAKE(38500)
Called from BUILDPROJECTM(35865)
Called from RUNAPPLICATION(30611)
Called from (b)NEWBUILD(38558)
Called from _ACTIVATEWINDOW(4526)
Called from MAIN(928)
It happens when I pressed ESCAPE key to close window with build.log
mol wrote:I've reached such an error in IDE:
[/quote]
Thanks for the report. I'll review it ASAP.
I'm not able to reproduce here.
Any other detail is welcome.
TIA.
I've got this error only one time: I've tried to compile small sample (activex.7) by pressing F5. An compilation error occured (I didn't add phrase object). Then I pressed ESC key to close errorlog window. and IDE crashed.
Simple thinks, which we are doing many times while trying to compile project...
mol wrote:I've got this error only one time: I've tried to compile small sample (activex.7) by pressing F5. An compilation error occured (I didn't add phrase object). Then I pressed ESC key to close errorlog window. and IDE crashed.
Thanks. I'll keep trying...
