HMG 3.0 FORUM TEST XVII
Re: HMG 3.0 FORUM TEST XVII
Yes. You might have tried while I was working on it.
Hi Roberto,Roberto Lopez wrote:Hi All,
Changes on this release:
- Fixed problem with scrollbars update in virtual-dimensioned windows (3.0 Test bug). Reported by Sudip.
Thanks a lot for this fix. But there is a similar problem with 5th parameter in the function SetScrollRange() also (it should be TRUE instead of 1).
Sorry for disturbing!
- Roberto Lopez
- HMG Founder
You are absolutely right.gfilatov wrote:Hi Roberto,Roberto Lopez wrote:Hi All,
I've already fixed.
Thanks!
EDIT: Anyway, the problem was not noticeable in my tests with virtual dimensioned windows in the tests prior to XVII publishing. It could be caused because usually SetScrollRange is called previous to window activation, so its very probable that no problems be noticed about this on the current release.
- esgici
Thanks a lot Maestro for this new release,
and thanks Rathi for new download system
Best regards
Best regards
Viva INTERNATIONAL HMG
Hi all,
Thanks Master for this new release.
My best regards,
My best regards,
English
Hello,
First of all a like to say thanks Roberto, for this new version.
I like to report that something is happen with new Grid Control,Samples: Grid.25 and Grid.30.
Grid.25
Select Row15 and Col 1,
Press enter
Change the number 15 for 16
and then press keyDown
Grid.30
Select Row 00015 and Col 1,
Press enter
Change 15 for 16
the rows look like overlap
Eduar
Español
Hola,
Primero que todo quiero agradecer a Roberto,por esta nueva version.
Quiero reportar que algo pasa con el nuevo control Grid, ejemplos Grid.25 y Grid.30.
Grid.25
Seleccionar fila15 y Columna 1,
Presionar enter
modificar el 15 por el numero 16
y presionar la flecha hacia abajo
Grid.30
Seleccionar fila 00015 y Columna 1,
Presionar enter
Cambiar 15 por 16
Y presionar flecha abajo
Las filas lucen como sobrepuestas
Saludos,
Eduar
Hello,
Grid.25
Press enter
Grid.30
Press enter
Change 15 for 16
Eduar
Español
Hola,
Grid.25
Presionar enter
Grid.30
Presionar enter
Cambiar 15 por 16
Saludos,
Eduar
- Roberto Lopez
- HMG Founder
Thanks for the report.Steed wrote:English
Hello,
Grid.25
Press enter
Grid.30
Press enter
Change 15 for 16
I'll take a look at it ASAP.
My friends,
I try recompile one project my on this new version of HMG, but i´ve a message like this "Undefined Reference to 'NOARRAY' ". Please, see the image bellow.
I posted the source code too.
What happen? Where be my mistake?
PS: Sorry my bad english
File Logs.prg
My friends,
File Logs.prg
#include <minigui.ch>
Function Init_Logs_Window()
Load Window Logs
Logs.Center
Logs.Activate
Function Read_Logs(cArea)
if Logs.Check_1.Value
cArea := cArea+"_old"
Abre_Base(cArea)
if Logs.Check_2.Value
edit extended workarea &cArea
edit workarea &cArea
Fecha_Base(cArea)
Return Nil- Attachments
- MyMistake.jpg (104.9 KiB) Viewed 4645 times
- Roberto Lopez
- HMG Founder
It's my fault.Vanguarda wrote:Hi All,
My friends,
I've erroneously deleted such function present in previous releases. It is used by EDIT command.
Function NoArray (OldArray)
Local NewArray := {}
Local i
If ValType ( OldArray ) == 'U'
ELse
Asize ( NewArray , Len (OldArray) )
EndIf
For i := 1 To Len ( OldArray )
If OldArray [i] == .t.
NewArray [i] := .f.
Else
NewArray [i] := .t.
EndIf
Next i
Return NewArray
For which function/property NoArray function is needed?
