HMG 3.0 FORUM TEST XV
Re: HMG 3.0 FORUM TEST XV
Thanks a lot Roberto.
Sudip, go to bed early in the night not early in the morning. :)
sudip
Post by sudip »
Thanks Friend Rathi :)
Hello Master Roberto,
Today I recompiled h_grid.prg (after changing _HMG_INPLACEEDIT return codes and changing path in MAKEHMG.BAT to my hmg installation path, ie., C:\HMGG300).
But, I again I found problem with my existing project, which I sent to you. I assume may be I compiled the HMG source code wrongly. :)
Date:13/01/2010 Time: 10:06:31
Error BASE/1066 Argument error: conditional
Called from _HMG_GRIDINPLACEKBDEDIT_2(1722)
Called from EVENTS(1735)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4560)
Called from DOMETHOD(7277)
Called from ATTEN(17)
Called from (b)MAIN(86)
Called from _DOCONTROLEVENTPROCEDURE(4872)
Called from EVENTS(1328)
Called from _ACTIVATEWINDOW(4514)
Called from MAIN(108)
Now, I am sending a small sample also:
DynamicColor.zip
(2.49 KiB) Downloaded 274 times
Please select 2nd column and select a value from the comobox. Now go to another row. Then press enter or dbl-click on the 1st column.
Thanks in advance. :)
With best regards.
I've got an error while trying to refresh grid in my project:
Date:2010.01.13 Time: 08:13:58
Error BASE/1068 Incorrect argument: Incorrect number of arguments
Called from DATAGRIDREFRESH(2083)
Called from _REFRESH(3639)
Called from DOMETHOD(7357)
Called from POTWIERDZPOZYCJEBUFORAAKORDU(4159)
line 4159: in POTWIERDZPOZYCJEBUFORAAKORDU is calling grid.refresh method
Marek
ps.
to test it, I've modified hmg\samples\grid.02\demo.prg by adding menuitem "Grid Refresh" in main menu and error occurs, too:
* MiniGUI Virtual Grid Demo
* (c) 2003 Roberto Lopez
#include "minigui.ch"
* When using virtual Grids you must avoid to use Item property and additem
* method. It can generate unexpected results.
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Hello World!' ;
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Change ItemCount' ACTION Form_1.Grid_1.ItemCount := Val(InputBox('New Value','Change ItemCount'))
				MENUITEM 'Refresh grid' ACTION Form_1.Grid_1.Refresh
			END POPUP
		END MENU
		@ 10,10 GRID Grid_1 ;
		WIDTH 400 ;
		HEIGHT 330 ;
		HEADERS {'Column 1','Column 2','Column 3'} ;
		WIDTHS {140,140,140};
		VIRTUAL ;
		ITEMCOUNT 100000000 ;
		ON QUERYDATA QueryTest()
	CENTER WINDOW Form_1
Procedure QueryTest()
	This.QueryData := Str ( This.QueryRowIndex ) + ',' + Str ( This.QueryColIndex )
Here is errorlog:
Harbour MiniGui Errorlog File
Date:01/13/10 Time: 08:19:58
Error BASE/1068 Argument error: array access
Called from (b)MAIN(23)
Called from MAIN(40)
I've compiled this sample by hmg test XIV - error occurs, too
Version XIII - everything looks OK.
Marek
I have a peculiar error. :)
While using HMG IDE, if our source code contains an array variable named "lines" and if you assign some value to the array, it gives compilation error, "E0022 Invalid lvalue String"
Add these lines in any of your code and try to compile.
local lines := {}
aadd(lines,1)
lines[1] := 5
Hi Rathi
AFAIK "LINES" is a reserved word for Browse and Grid.
So, you don't have use it as an identifier, IMHO.
Thanks for the explanation Esgici.
sudip wrote: Today I recompiled h_grid.prg (after changing _HMG_INPLACEEDIT return codes and changing path in MAKEHMG.BAT to my hmg installation path, ie., C:\HMGG300).
Ok.
I'll check it ASAP.
mol wrote:I've got an error while trying to refresh grid in my project:
Thanks for the report Marek.
I'm working on it.
rathinagiri wrote:Hi,
local lines := {}
aadd(lines,1)
lines[1] := 5
In 'i_graph.ch' we have the following definition:
#define LINES     2
That is the problem.
Maybe we should change the DRAW GRAPH definition to 'hardcoded' graph type into command itself, since 'bars', 'lines' and 'points' are could be used as variable names by anyone.
