List of all defined controls in a form
Hi at all,
I don't know if exist (I don't find / don't read about), but is there a function that return an array with the names of all defined controls in a form?
Luigi from Italy
www.L3W.it
www.L3W.it
Re: List of all defined controls in a form
and sorry
: after I've inserted this post I understand that it's not so clear the use.
I want execute a loop to disable all the controls in a form. Example:
Bye
and sorry
aControl := MiniGuiFunction()
FOR n := 1 TO LEN(aControl)
aControl[n].Enabled := .F.
NEXT n
Luigi from Italy
www.L3W.it
www.L3W.it
Yes. You can do easily.
Please consider the example below using GetWindowControls(cForm) user defined function.
# include "minigui.ch"
function main
define window sample at 0,0 width 800 height 600 main
define label label1
row 10
col 10
width 100
value "Label 1"
end label
define textbox text1
row 10
col 110
width 120
value "Sample Text Box 1"
end textbox
define label label2
row 40
col 10
width 100
value "Label 2"
end label
define textbox text2
row 40
col 110
width 120
value "Sample Text Box 2"
end textbox
define label label3
row 70
col 10
width 100
value "Label 3"
end label
define textbox text3
row 70
col 110
width 120
value "Sample Text Box 3"
end textbox
define button action1
row 100
col 10
width 100
caption "Press here"
action dolisting()
end button
define listbox list1
row 130
col 10
width 200
height 200
end listbox
end window
sample.center
sample.activate
return nil
function dolisting
local aControls := GetWindowControls("sample")
local i := 0
sample.list1.deleteallitems()
for i := 1 to len(aControls)
sample.list1.additem(aControls[i])
next i
if sample.list1.itemcount > 0
sample.list1.value := 1
return nil
function GetWindowControls(cForm)
local aControlList := {}
local i := 0
for i := 1 to len(_HMG_SYSDATA[4])
if _HMG_SYSDATA[4,i] == GetFormHandle(cForm)
aadd(aControlList,_HMG_SYSDATA [ 2,i])
next i
return aclone(aControlList)
Hi Rathinagiri,
many, many thanks: I've used your information
Every day I discover
the capabilities of MiniGui.
Bye
Bye
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Rathinagiri,
I compiled and tested your program and it works fine. I applied your suggestion to my program, using the "setProperty", but I found some anomaly; in the vector, which should contain the names of the active controls, there are some invalid entries, please, can you compile the source that I've posted and tell me if you have the same like me?
A) select the "Menu" and then " GetControl" on the main menu: three times in succession, the message returns Empty values and then (correctly) "lb_ prgcodice " and "prgcodice";
B) select the "Modal" and then "TestWindow" on the main menu and then the " GetControl", I get this sequence of messages: "StatusTimer", "StatusBar", "toolbar1", "bt_exit", Empty, "bt_save" , Empty, "lb_prgcodice", "prgcodice";
There are a lot of unused functions, but this source is a little "skeleton" of my sorurces.
I made mistakes? Have you the same?
Many thanks in advance
- mytest.zip
- simple source
- (969 Bytes) Downloaded 819 times
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi,
You didn't make any mistakes. I had made.
For menu items and toolbar separators, we don't have names. But, they are also controls.
Now please consider this function.
STATIC FUNCTION GetWindowControls(cForm)
local i := 0
if len(alltrim(_HMG_SYSDATA [ 2,i])) > 0
next i
for i := 1 to len(aControlList)
msgstop(aControlList[i])
next i
waiting your answer, I do the same
Luigi from Italy
www.L3W.it
www.L3W.it
Wise men think alike.
