A Funny Thing Happened In The Way To The Browse :)
Re: A Funny Thing Happened In The Way To The Browse :)
rathinagiri wrote:Unfortunately I can't compile the samples. :(
This is the error log.
hbmk2: Processing configuration: C:\hmg\harbour\bin\hbmk.cfg[/quote]
mmm... I've changed high level (.prg) code only.
Your linker error messages looks like you are using libraries compiled with different Harbour versions.
Since it worked for Ricci, I guess that the problem is in your system. Please, check it.
Ok Roberto. I will check. :)
It's just fantastic. Thanks Roberto!
sudip
Post by sudip »
Hello Master Roberto,
Excellent work :D Thanks a lot :D
I don't know whether I made any mistake or not. I tried to add a record. Type "100001" in the first column. After pressing enter key, it took me to the 2nd column. Then I typed something instead of pressing enter again. And it took me to the top of the grid. :)
With best regards.
rathinagiri wrote:It's just fantastic. Thanks Roberto!
The better part is just coming :)
sudip wrote:Hello Master Roberto,
With best regards.
Please, indicate the exact steps you made and the results in each one.
Thanks.
sudip
Post by sudip »
I ran the program and press Alt+A. Then typed 100001 in the first column and pressed enter (following image)
Then I typed some letters eg., "asdf" and the grid took me to the top! (following image)
I can't understand what I made mistake :?
With best regards.
sudip
Post by sudip »
Great news :D
With best regards.
I ran the program and press Alt+A. Then typed 100001 in the first column and pressed enter (following image)...
This behavior is by design :)
The new added record behaves the same as any other record, so to edit a selected cell you must press <enter> first.
The other thing (pressing a key leaves you to the first record is a BIG BUG :)
Thanks for reporting!
Please publish a new "clean", (full setup) version, if possible.
I have some difficulties and can't succeed installing and using data grid :cry:
Best regards
