Hello Rafael,
I am very much happy to share my code with you all
Here is it :-
(Please remember, I should use new temporary table feature of Harbour in the following code.)
#include "dbstruct.ch"
#include "minigui.ch"
FUNCTION dbCreaChk(fname, adbf)
local aStruct, option, lChange := .f., lNew := .f., i, newrec, oldrec
fname := upper(fname)
if !file(fname+".dbf")
set exclusive on
dbcreate(fname, adbf)
set exclusive off
return .t.
use (fname)
aStruct = dbstruct()
use
if len(aStruct) != len(adbf)
lChange = .t.
i = 1
do while i <= len(aStruct) .and. !lNew .and. !lChange
if len(aStruct[i, DBS_NAME]) != len(adbf[i, DBS_NAME]) ;
.or. upper(aStruct[i, DBS_NAME]) != upper(adbf[i, DBS_NAME]) ;
.or. upper(aStruct[i, DBS_TYPE]) != upper(adbf[i, DBS_TYPE]) ;
.or. aStruct[i, DBS_LEN] != adbf[i, DBS_LEN] ;
.or. aStruct[i, DBS_DEC] != adbf[i, DBS_DEC]
lChange = .t.
i++
enddo
if lChange
if msgyesno(fname+" structure has been changed. Change";
+" the structure ?")
set exclusive on
use (fname)
pack
oldrec = reccount()
use
deletefile("settemp.dbf")
if renamefile(fname+".dbf", "settemp.dbf") != 0
msginfo("Cannot change file structure!",)
QUIT
use (fname)
append from settemp
newrec = reccount()
use
if newrec != oldrec
msginfo("Problem in creating file :"+fname+;
". You can get all records in the file SETTEMP.DBF")
quit
set exclusive off
return .t.
msginfo(fname+" structure mismatch")
quit
return .f.
function NetSelect(cTable)
if select(cTable) = 0
use &cTable shared new
select (cTable)
return nil
I shall be very happy if above code will be helpful
With best regards.
