Does anyone use MiniGUI IDE to create a project.
There is no sample code that really uses the a FORM created by the IDE.
Does any one have a PORJECT that is built using the IDE that:
In the code
Opens a form.
gets data from a TextBox
Looks up a record in a DBF table,
Display’s the results on the form
The project would only have to have:
2 TextBox, one for input, one for the results
1 button to perform the lookup
1 button to terminate
the DBF only needs 2 fields, a key field and a data field.
A NewBe just needs a small example that actually does something, to get started!
All examples are just snip lets, not enough to tie anything together as far as the IDE goes.
Thanks,
Robin
Does anyone use MiniGUI IDE to create a project?
Re: Does anyone use MiniGUI IDE to create a project?
first, run IDE...
Create new project File-New Project (or simply press blank page icon)
Next - create new form Project->New Form
New form will get name "MAIN"
You can change it for "WINDOW_EXAMPLE"
Draw two TextBox: and name them: T_Search, T_Result
Draw two buttons "EXIT" "Search"
for button "EXIT":
select button "EXIT"
In window Object Inspector click on the page Events
If field "Action" write: WINDOW_Example.Release
this action will close main window
For button "Search" set action to FUN_SEARCH()
Below you have a simple program:
(I hope I didn't make any mistake... )
#include <minigui.ch>
use SearchedDataBase
Load Window WINDOW_EXAMPLR
WINDOW_EXAMPLE.Center
WINDOW_EXAMPLE.Activate
function FUN_SEARCH
WhatToSearch := WINDOW_EXAMPLE.T_Search.Value
SearchDataBase->(DbSeek(WhatToSearch))
// now you can put your result
WINDOW_EXAMPLE.T_Result.Value := SearchDataBase->(SearchResult)
return
Have a fun with HMG and HMG IDE its great and wonderful tool!
Marek
for button "EXIT":
function FUN_SEARCH
return
Marek
I tried to create a project on my own (see attachment), taking full advantage of the IDE and bound fields…..(used DATA_BOUND sample program to get some insight, it does not use the IDE, I reproduced the minimum amount to see if it would work). Please look at my attachment, it fails trying to put data in the fields, I think..)
If the bound fields worked, it would be great….
Thanks,
Robin
Thanks,
Robin
- esgici
Hi Robinrcain wrote:I tried to create a project on my own (see attachment)...
Can't see your attachment
Viva INTERNATIONAL HMG
Sorry, I had the EXE file in the ZIP, it was to big, I did not notice.
Please look at it now...
- MAIN.zip
- (8.6 KiB) Downloaded 719 times
- esgici
Hi Robinrcain wrote:I tried to create a project on my own (see attachment), taking full advantage of the IDE and bound fields…..(used DATA_BOUND sample program to get some insight, it does not use the IDE, I reproduced the minimum amount to see if it would work). Please look at my attachment, it fails trying to put data in the fields, I think..)
Thanks,
Robin
Your work like a good start, congrats.
Before all, don't panic
"Taking full advantage" isn't like a good perspective for beginning. Instead, running by little steps may be better.
You have correct this two points on your form :
- DATATYPE property of "Text_1" (Code) textbox must be "NUMERIC"
- DATATYPE property of "Text_4" (Birth) textbox must be "DATE"
After this correction "Error BASE/1100 Argument error: TRIM" error will go away
But another error waiting for you: You have control names conflicts in "Refresh" and "Save" procedures:
like Date_4 -> Text_4
You have another problem : USE'ing a table with "shared" option require "lock" ing while "save"ing.
Surely you will resolve all of them. Only need is a little patience.
Happy HMG'ing
Thank you for your help, some times I get a little ahead of my self....
I made the correction and it worked!
I did Clipper (5.3 for DOS) programming back in 1993 thru 1996, when you had to program everything.
I have been doing M/S Visual Basic since 96/97, it's been a long time since my Clipper days, we did not have IDE’s and Graphics.
Where can I get documentation on Harbour and MiniGUI? I still have my CA-CLIPPER books. That will help on some things, but not DEFINE WINDOW” and MENU, etc…
Again Thanks,
Robin
Again Thanks,
Robin
- esgici
Hi Robin
Good news
Since Harbour is quickly grown up, we have some difficulty on documentation.
On the HMG side, you may find some useful infos and sources in my web page:
Full and newest reference comes always with HMG itself (see hmg\doc folder).
Many thanks to "Le Roy" Roberto Lopez
Again, welcome to community.
rcain wrote:I made the correction and it worked!
Good news
For Harbour please look at first Harbour official sitercain wrote:Where can I get documentation on Harbour and MiniGUI?
Nice explanation to Robin. Thanks Esgici.
