Harbour MiniGUI IDE 2.6.4
English:
- Fixed: Problems when 'Name' property value is changed in various
controls. Reported by Esgici.
Español:
- Solucionado: Problemas al cambiar la propiedad 'Name' en varios
controles. Reportado por Esgici.
rcain
Re: Harbour MiniGUI IDE 2.6.4
Post by rcain »
Does anyone use MiniGUI IDE to create a project.
There is no sample code that really uses the a FORM created by the IDE.
Does any one have a PORJECT that is built using the IDE that:
In the code
Opens a form.
gets data from a TextBox
Looks up a record in a DBF table,
Display’s the results on the form
The project would only have to have:
2 TextBox, one for input, one for the results
1 button to perform the lookup
1 button to terminate
the DBF only needs 2 fields, a key field and a data field.
A NewBe just needs a small example that actually does something, to get started!
All examples are just snip lets, not enough to tie anything together as far as the IDE goes.
Thanks,
Robin
Hi Robin,
Welcome aboard :)
rcain wrote:Does anyone use MiniGUI IDE to create a project.
Personally, I am building almost all my project ( including console applications) by IDE.
Why you don't look at HmgIDE\Samples folder ? Actually there are 21 samples and all of them are FORM based (see .fmg files).
Does any one have a PROJECT that is built using the IDE
Please look at this tutor page :
http://vivaclipper.googlepages.com/ide_sample1_eng
Not include all of your requests, but surely respond most of your questions and may be a good starting point for you.
Happy HMG'ing :)
esgici wrote: Please look at this tutor page :
An IMPRESSIVE tutorial.
Thanks!!!!
Roberto.
Thanks!!!!
Roberto.
All thanks about HMG are to you, Roberto.
As I denoted in the first announce, this tutor page need
a translation aid :(
At least correction for this Google translated text.
Best Regards
IDE_Sample.zip
(4 KiB) Downloaded 381 times
Thanks!!!!
Roberto.
Best Regards
Ok. I can`t tell you when, but i'll do it.
Roberto.
rcain
Post by rcain »
I tried to create a project on my own (see attachment), tacking full advantage of the IDE and bound fields…..(used DATA_BOUND sample program to get some insight, it does not use the IDE, I reproduced the minimum amount to see if it would works). Please look at my attachment, it fails trying to put data in the fields, I think..)
If the bound fields worked, it would be great….
Thanks,
Robin :o
MAIN.zip
(8.6 KiB) Downloaded 376 times
