it sounds good and interesit, Daniel!
Now I'm using my simple module for checking version of app installed in user's computer with version number placed on my web server.
If there is new version, client is asked for downloading and installing new one. I'm using InnoSetup to create installation file.
Actualización del Ejecutable.
Re: Actualización del Ejecutable.
mol wrote: ↑Sun Sep 13, 2026 7:55 pm it sounds good and interesit, Daniel!
Hola Mol, todas mis pruebas estan hechas contra el servidor Rebex Tiny que incluyo.
leer : UniversalUpdater_Guia_Principiantes.md
perdon por no traducir el documento, tambien hay un documento para la ayuda de una IA (pueden usar Zcode con una cuenta google, no pide numero telefonico )
IA : UniversalUpdater_Integracion_IA.md
compilar con HBMK2 agregando las rutas Harbour64 y MinGW64 (HMG) , los ejemplos corren en CMD.
dejo los fuentes +Rebex tiny Tfpt Server para pruebas.
documentacion en Español e Inlges
- UniversalUpdater.rar
- (12.38 MiB) Downloaded 27 times
Daniel,
Can you please explain in short how it works?
Thanks, Serge
Thanks, Serge
In the "Test" folder, there is an app (DemoApp.prg) designed to be part of your application or project; its function is to check a server for updates. If an update is found, it notifies the user; otherwise, your application continues running as usual.serge_girard wrote: ↑Thu Sep 17, 2026 6:57 am Daniel,
Thanks, Serge
Your app launches the update process either upon completion or whenever you choose.
Your app generates a JSON file, launches UniversalUpdater as an external application, and then closes itself.
UniversalUpdater handles the entire app update process (the content is packaged in a ZIP file, which can be digitally signed if desired).
UniversalUpdater verifies the package's integrity and performs the update; if any issues arise, it reverts everything to its previous state (thanks to a prior backup).
Full documentation is available in both Spanish and English, and a Markdown document is included to help an AI integrate UniversalUpdater into your app.
To run a test on your computer, you can use the Rebex Tiny FTP server included in the example. This allows you to execute
C:\Proyectos\UniversalUpdater\TEST\Demo.cmden la carpeta Test hay una app (DemoApp.prg) que sera parte de su aplicacion o proyecto , esta lo que hace es verificar contra un servidor si hay una actualizacion. si la hay informa. sino su aplicacion sigue como si no hubiese pasado nada.
su app al terminar de ejecutarse o cuando ud quiere lanza la actualizacion.
su app genera un json lanza UniversalUpdater como aplicacion externa y se cierra.
UniversalUpdater hace todo el trabajo de actualizar la app (el contenido esta en un ZIP con firma digital si usted quiere)
UniversalUpdater verifica la integridad del paquete, y realiza la actualizacion, si hay algun problema regresa todo como estaba (porque hubo un backup anteriormente).
tiene toda la documentacion en español e ingles para leer, tambien tiene un documento Markdown para hacer que una IA integre UniversalUpdate a su app.
si quiere correr un test en su computadora puede usar Rebex Tiny TFP que agregue al ejemplo y ejecutarlo. de esta manera puede desde la consola cmd ejecutar
C:\Proyectos\UniversalUpdater\TEST\Demo.cmd*´¨)
