Codepage, hb_Translate(), OEM <-> ANSI
Re: Codepage, hb_Translate(), OEM <-> ANSI
if substr(cText_Path, -1) <> "\"
cText_Path += "\"
jozef
Post by jozef »
Hi Jimmy,
I started to move from ANSI version to UNICODE version of HMG. Your convert program is very usefull.
Thank you,
Jozef
here full Source of App
CONVERT_Source.ZIP
(23.99 KiB) Downloaded 142 times
franco
Post by franco »
You could put it ahead of the extra procedure.
  cDir := GetFolder( cTitle, TRIM( cInitPath ),, lNewFolderButton )
   IF !EMPTY( cDir )
       IF RAT( "\", cDir ) <> LEN(cDir)
                 cDir += "\"
      ExportDbf.Text_Path.value := cDir                                //+ "\"  // add "\"
All The Best,
Franco
Canada
