HB_WebView (a cross-platform Webview library)
Re: HB_WebView (a cross-platform Webview library)
serge_girard wrote: Sat Mar 22, 2025 10:41 am Claudio,
Here is a small example (not tested or compiled !) but it gives an idea!
Many thanks, Serge
FUNCTION MAIN()
PUBLIC dbo
PUBLIC dbname
PUBLIC host
PUBLIC user
PUBLIC password
PUBLIC cVersion
PUBLIC aRESULT := {}
IF SQL_Connect()
   cQuery1a  := " SELECT SOME_FIELD "
   cQuery1a  += " FROM   SOME_TABLE "
   cQuery1a  += " WHERE  SOME_REC_NO  = 1  "
   cSQL1    := cQuery1a
   ? cSQL1
   cQuery1a	:= dbo:Query( cQuery1a )
   IF cQuery1a:NetErr()
      MSGINFO( 'SQL DEMO ' + UPPER(cQuery1a:Error()))
   FOR i := 1 to cQuery1a:Lastrec()
      aCurRowa			   := cQuery1a:GetRow(i)
      cNAAM             := Strvalue(aCurRow:fieldGet(1))
      AADD(aRESULT, {cNAAM } )
   SQL_Disconnect()
   ? 'NO CONNECTION'
	WIDTH  1200  ;
	HEIGHT 500 ;
	TITLE '';
	MAIN  ;
   FONT 'Arial' SIZE 15   ;
   @ 10,10 GRID Grid_ZF		;
      WIDTH  1150			;
      HEIGHT 450		;
      HEADERS {'SOME_FIELD'};
      WIDTHS  {250    };
      JUSTIFY { GRID_JTFY_LEFT  } ;
      FONT "Arial" SIZE 09		;
      iTEMS aRESULT
CENTER WINDOW Form_1
FUNCTION SQL_Connect()
dbname      := 'dbname'
host			:= 'host.db.host.xx'
user			:= 'dbname_user'
password		:= 'secret_password'
dbo := tmysqlserver():new(AllTrim(host), AllTrim(user), AllTrim(password))
IF dbo:NetErr()
   ?'R1',  dbo:ERROR()
   RETURN nil
IF!EMPTY(dbname)
   dbo:selectdb(dbname)
   IF dbo:NetErr()
     ?'R2',  dbo:ERROR()
      RETURN nil
cVersion := dbo:sql_Version()
? 'cVersion', cVersion
RETURN dbo
FUNCTION SQL_Disconnect()
dbo:Destroy()
Hi Serge,
I have slightly modified your code, adding the SQL_GetData() function, with two versions, one for a real SQL connection and another for a simulated connection for testing (see comments in the code).
 * HB_WebView Demo
 * Copyright 2025 by Dr. Claudio Soto (from Uruguay).
 * mail: <srvet@adinet.com.uy>
 * blog: http://srvet.blogspot.com
#include "../hb_webview-lib/hb_webview.ch"
// #include "hb_webview-lib/hb_webview.prg"
REQUEST hb_alert
MEMVAR dbo, dbname, host, user, password, cVersion
FUNCTION Main
LOCAL w, html, allowDevTools
LOCAL context
PUBLIC dbo, dbname, host, user, password, cVersion
// aRESULT = SQL_GetData()   // returns an array with subarray like: { { data1 }, { data2 }, ... , { dataN } }
html = ''
html += '<div>'
html += '  <p>Press CTRL+SHIFT+I to open the DevTools window</p>'
html += '  <button onclick="disp()"> SQL_GetData() </button>'
html += '  <pre id="idResult"></pre>'
html += '</div>'
html += '<script>'
html += '   async function disp(){'
html += '      let arrayData = await SQL_GetData();'
html += '      console.log( arrayData );'
html += '      let txt = "";'
html += '      for(let i=0; i < arrayData.length; i++)'
html += '         txt += "Row "+ i + ": " + arrayData[ i ].toString() + "\n";'
html += '      document.getElementById("idResult").textContent = "SQL Response: \n" + txt;'
html += '   }'
html += '</script>'
allowDevTools = .T.
   w = hb_webview_create( allowDevTools, NIL )
      hb_webview_set_size(w, 480, 320, WEBVIEW_HINT_NONE)
      hb_webview_set_title(w, "Harbour WebView - SQL Demo")
   Remember that JavaScript is case sensitive:
   If you bind the HB_ALERT() function as "hb_Alert" in the Harbour environment,
   you must call it as hb_Alert() in JavaScript environment.
   On the other hand, Harbour binding functions are passed as promises to JavaScript.
   Therefore, they are executed in the JavaScript environment as asynchronous functions.
   For more details on promises in JavaScript, see:
   https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Promise
   For promises to execute synchronously, you must chain the calls in chained .then() statements
   or call them with the await statement inside an asynchronous function.
   For more details see:
   https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Promise/then
   https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/await
      context = hb_webview_bind2(w, "SQL_GetData", HB_CALL_FUNC_DIRECT)
      hb_webview_set_html(w, html)
   hb_webview_run(w)
   hb_webview_destroy_context( context )
   hb_webview_terminate( w )
// Warning, this is a simulate response, please comment out this line in a real SQL connection.
#define SIMULATE_SQL
#ifdef SIMULATE_SQL
FUNCTION SQL_GetData()
LOCAL aRESULT := {}
   aRESULT := Simulate_SQL_GetData_Response()
RETURN aRESULT   // returns an array with subarray like: { { data1 }, { data2 }, ... , { dataN } }
FUNCTION Simulate_SQL_GetData_Response()
LOCAL aRESULT := {}
   AADD( aRESULT, { "data1 A", "data1 B" } )
   AADD( aRESULT, { "data2" } )
   AADD( aRESULT, { "data3" } )
RETURN aRESULT
#else
   dbname      := 'dbname'
   IF dbo:NetErr()
      ?'R1',  dbo:ERROR()
      RETURN nil
   IF!EMPTY(dbname)
      IF dbo:NetErr()
         ?'R2',  dbo:ERROR()
         RETURN nil
RETURN dbo
   dbo:Destroy()
LOCAL cQuery1a, i, aCurRow, cNAAM, cSQL1
LOCAL aRESULT := {}
   IF SQL_Connect()
      cSQL1    := cQuery1a
      ? cSQL1
         aCurRow  := cQuery1a:GetRow(i)
         AADD( aRESULT, { cNAAM } )
      SQL_Disconnect()
      ? 'NO CONNECTION'
#endif
Compile with:
call ..\build_hb_cpp.bat   demo_SQL.prg   -w2 -es2 -lshlwapi demo.hbc
Great ! Many thanks, Serge
Claudio,
How to capture runtime errors? I get "Error BASE/1066 Argument error: conditional". But no line-number. I try DEFERROR function...
Hi Serge,
To test your code, place the following line at the beginning of the Main() function:
msgdebug( SQL_GetData() )
This causes first all MySQL functions to run on Harbour's "side", before creating the Webview. This may make it easier to capture the error.
I get: hbmk2: Error: Referenced, missing, but unknown function(s): MSGDEBUG()
serge_girard wrote: Sun Mar 23, 2025 12:06 pm I get: hbmk2: Error: Referenced, missing, but unknown function(s): MSGDEBUG()
I'm sorry msgdebug() is a HMG function, this version is in pure Harbour.
FUNCTION MsgDebug
LOCAL i, cMsg, cTitle
   #define CRLF CHR(13)+CHR(10)
   cMsg := "Called from: " + PROCNAME(1) + "(" + LTRIM(STR(PROCLINE(1))) + ") --> " + PROCFILE (1) + CRLF + CRLF
   FOR i = 1 TO PCOUNT()
       cMsg := cMsg + HB_VALTOEXP (PVALUE (i)) + IIF (i < PCOUNT(), ", ", "")
   hb_alert (cMsg)
 RETURN cMsg
Hi all,
I have added a new demo (demo5.prg), a SQLite query where the results are displayed in an HTML table.
Download code from: https://www.hmgforum.com/viewtopic.php?p=71617#p71617
Claudio,
The MySQL demo is having a problem in the Javascript...
<script>
alert("xx1");
alert("xx2");
alert("xx3");
let txt = "";
alert("xx4");
alert(arrayData.length);
alert("xx5");
document.getElementById("idResult").textContent = "SQL Response: \n" + txt;   }
</script>
- alert xx1 is reached
- data is retrieved well from database
- alert xx2 is never reached and it is stopped without a message.
Something went wrong somewhere....
Hi Serge,
msgdebug(SQL GetDate()) when run at the start of the Main() function displays the correct result? Does the harbor application crash?
Claudio,
1 - msgdebug(SQL GetDate()) -> works perfect with all MySQL results
2 - app does not crash.
Data is not displayed and
alert(arrayData.length) gives 'undefined'.
I tried : let arrayData = SQL_GetData() without success neither.
My Javascript knowledge is very poor...
I will prepare a kind of demo with real database and send it you at your emailaddress srvet@adinet.com.uy ?
