GIF animation demo
gfilatov
Re: GIF animation demo
Post by gfilatov »
Roberto Lopez wrote:
gfilatov wrote: The command DRAW PANEL exists in the HMG Extended Edition.
The new TGif class will be available at the next buid of HMG EE :arrow:
:mrgreen:
Could be you so kind to post the DRAW PANEL command source code adapted for HMG?
So, I could add in the 'PROPOSED.FEATURES' folder of the next HMG release... or better... you could add the code to HFCL.
Roberto,
No problem. Kindly take a look for the sample below:
 * Copyright 2002-2009 Roberto Lopez <harbourminigui@gmail.com>
 * http://harbourminigui.googlepages.com/
#include "minigui.ch"
#xcommand DRAW PANEL IN WINDOW <parent> ;
		AT <frow>,<fcol> ;
		TO <trow>,<tcol> ;
		DrawWindowBoxRaised( <"parent">, <frow>, <fcol>, <trow>, <tcol> )
#xcommand DRAW BOX IN WINDOW <parent> ;
		AT <frow>,<fcol> ;
		TO <trow>,<tcol> ;
		DrawWindowBoxIn( <"parent">, <frow>, <fcol>, <trow>, <tcol> )
function main
	define window x ;
		at 0,0 ;
		width 640 ;
		height 480 ;
		title "Draw Box And Panel Sample By Grigory Filatov" ;
		main nomaximize nosize ;
		on init x.Button_1.Setfocus
		DRAW BOX			;
		IN WINDOW x			;
		AT 20,20			;
		TO 200,300
		@ 110, 140 LABEL Label_1 VALUE "Box In" AUTOSIZE
		DRAW PANEL			;
		IN WINDOW x			;
		AT 20,320			;
		TO 200,610
		@ 110, 440 LABEL Label_2 VALUE "Panel" AUTOSIZE
		@ 220,20 FRAME Frame_1 ;
			CAPTION "Frame Title" ;
			WIDTH 280 ;
			HEIGHT 180 ;
			OPAQUE
		@ 220,320 FRAME Frame_2 ;
			WIDTH 290 ;
			HEIGHT 180 ;
			OPAQUE
		@ 310, 410 LABEL Label_3 VALUE "Frame without title" AUTOSIZE
		@ 414, 530 BUTTON Button_1 ;
			CAPTION "&Close" ;
			ACTION ThisWindow.Release ;
			WIDTH 78 HEIGHT 26
	end window
	x.center
	Activate Window x
function DrawWindowBoxIn(window,row,col,rowr,colr)
   Local i := GetFormIndex ( Window )
   Local FormHandle := GetFormHandle ( Window )
   Local hDC := GetDC( FormHandle )
   WndBoxIn( hDC, row, col, rowr, colr )
   aadd ( _HMG_SYSDATA [ 102 ] [i] , { || WndBoxIn( hDC := GetDC( FormHandle ), row, col, rowr, colr ), ReleaseDC( FormHandle, hDC ) } )
return nil
function DrawWindowBoxRaised(window,row,col,rowr,colr)
   aadd ( _HMG_SYSDATA [ 102 ] [i] , { || WndBoxRaised( hDC := GetDC( FormHandle ), row, col, rowr, colr ), ReleaseDC( FormHandle, hDC ) } )
return nil
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include "hbapiitm.h"
void WndDrawBox( HDC hDC, RECT * rct, HPEN hPUpLeft, HPEN hPBotRit )
   HPEN hOldPen = ( HPEN ) SelectObject( hDC, hPUpLeft );
   POINT pt;
   MoveToEx( hDC, rct->left, rct->bottom, &pt );
   LineTo( hDC, rct->left, rct->top );
   LineTo( hDC, rct->right, rct->top );
   SelectObject( hDC, hPBotRit );
   LineTo( hDC, rct->right, rct->bottom );
   LineTo( hDC, rct->right, rct->top - 1 );
   SelectObject( hDC, hOldPen );
void WindowBoxIn( HDC hDC, RECT * pRect )
   HPEN hWhite = CreatePen( PS_SOLID, 1, GetSysColor( COLOR_BTNHIGHLIGHT ) );
   HPEN hGray = CreatePen( PS_SOLID, 1, GetSysColor( COLOR_BTNSHADOW ) );
   WndDrawBox( hDC, pRect, hGray, hWhite );
   DeleteObject( hGray );
   DeleteObject( hWhite );
void WindowRaised( HDC hDC, RECT * pRect )
   WndDrawBox( hDC, pRect, hWhite, hGray );
HB_FUNC ( GETDC )
   hb_retnl( (ULONG) GetDC( (HWND) hb_parnl(1) ) ) ;
HB_FUNC ( RELEASEDC )
   hb_retl( ReleaseDC( (HWND) hb_parnl(1), (HDC) hb_parnl(2) ) ) ;
HB_FUNC( WNDBOXIN )
   RECT rct;
   rct.top    = hb_parni( 2 );
   rct.left   = hb_parni( 3 );
   rct.bottom = hb_parni( 4 );
   rct.right  = hb_parni( 5 );
   WindowBoxIn( ( HDC ) hb_parnl( 1 ), &rct );
HB_FUNC( WNDBOXRAISED )
   RECT rct;
   WindowRaised( ( HDC ) hb_parnl( 1 ), &rct );
#pragma ENDDUMP
BTW The C-code is available in the file c_graph.c at the folder hmg\source\graph ;)
Demo screenshot
Demo screenshot
Thanks!
I've already added to 'PROPOSED.FEATURES' folder in HMG distribution.
The idea to put it there is that it be widely tested and discussed prior to adding as an standard component of HMG.
Thanks again.
gfilatov
Post by gfilatov »
Roberto Lopez wrote:...
Roberto,
Thanks a lot!
One more suggestion. :o
This sample needs the following addition in the procedure _RefreshDataControls for proper showing a panel at the application's startup:
Procedure _RefreshDataControls (i)
Local SplitIndex
Local x
Local w
   If Len ( _HMG_SYSDATA [ 102 ] [i] ) > 0
      SendMessage( _HMG_SYSDATA [ 67 ] [i] , WM_PAINT , 0 , 0 )
   EndIf
I hope that helps :idea:
gfilatov wrote: One more suggestion. :o
Ok.
Thanks again!
Hola Grigory
Ante todo felicidades por esta aportación
Una cuestión he compilado tu ejemplo para HMG con la versión 2.9.5
con el compile.bat y cuando arranca la aplicación no salen los
recuadros undido , ni el realzado , entonces si hago minimizar la aplicacion
y otra vez regreso a la misma ya aparecen los cuadros.
Un Cordial Saludo
Hello Grigory
First of all congratulations for this contribution
One question I have compiled your example for HMG to version 2.9.5
with compile.bat and when you boot the application does not leave the
sunken boxes nor enhanced, then if I minimize the application
and again return to it and the boxes appear.
Error :?:
gfilatov
Post by gfilatov »
mustafa wrote:Error :?:
Hello Mustafa,
It is a known behaviour (take a look for my aboved suggestion to Roberto for fixing this problem).
I hope that helps :!:
Grigory Thanks for the reply
Mustafa :oops:
mustafa wrote: ... cuando arranca la aplicación no salen los
... when you boot the application does not leave the
Codigo Original:
function main
   define window x ;
      at 0,0 ;
      width 640 ;
      height 480 ;
      main nomaximize nosize;
Cambiar el ON INIT original de la ventana por:
on init {||SendMessage (GetFormHandle (ThisWindow.Name),15,0,0), x.Button_1.Setfocus}
Esto envía un mensaje WM_PAINT a la ventana cuando arranca y hace que los cuadros se vean como deberían verse, sin
necesidad de minimizar la ventana.
Saludos,
Claudio Soto
Otro Truquillo para los adornos
Another trick for the ornaments
Box.zip
(851 Bytes) Downloaded 364 times
