i know that harbour can use DBF > 2 GB under 64 Bit using DB_DBFLOCK_HB64
but how to create a DBF > 2 GB ?
How to build DBF > 2 GB
- AUGE_OHR
Re: How to build DBF > 2 GB
- AUGE_OHR
thx for the Link.danielmaximiliano wrote: ↑Thu Jun 20, 2024 9:19 pm Hi Daniel,
http://harbourlanguage.blogspot.com/201 ... r-rdd.html
but how to setup DBF to use DB_DBFLOCK_HB64
i´m not able to create a DBF to use more than 2 GB
This code below creates a dbf file over 4 GB in size, I set the locking scheme to DB_DBFLOCK_HB64 and did not notice any problems with accessing the records. I compiled in 64 bits using hmg 3.6.
#include "dbinfo.ch"
proc main()
local i, n := int(2^22) + 10, nStep := int ( n / 50 ), cF1, nId, nRow, nCol
SET DBFLOCKSCHEME TO DB_DBFLOCK_HB64
if !file("tst4GB.dbf")
? "Building tst4GB.dbf..., be patient ..."
? REPLICATE ( Chr ( 177 ), 50 )
DevPos( ROW(), COL()-50 )
dbcreate("tst4GB.dbf",{{"F1","C",1023,0}, {"id","+",4,0}})
use tst4GB exclusive
for i:=1 to n
dbappend()
replace F1 with str(i,10)
IF i%nStep = 0
?? Chr ( 219 )
next i
close
?? " 100% done"
use tst4GB shared alias tst1 new
use tst4GB shared alias tst2 new
? "records:", tst1->(lastrec()), ;
", size:", tst1->(header())+tst1->(lastrec())*tst1->(recsize())
? "Alias tst1 goto:", lastrec(), tst1->(dbgoto(lastrec()))
? "Alias tst1 recno():", tst1->(recno()), "->", alltrim(tst1->(fieldget(1))), "->" , tst1->(fieldget(2))
? "Alias tst2 goto:", lastrec(), tst2->(dbgoto(lastrec()))
? "Alias tst2 recno():", tst2->(recno()), "->", alltrim(tst2->(fieldget(1))), "->" , tst2->(fieldget(2))
? "Alias tst1 FLOCK: ", tst1->(flock())
? "Testing reading of alias tst2 records when the file is locked in alias tst1 ..."
for i:=1 to n
tst2->(dbgoto(i))
cF1 := alltrim(tst2->(fieldget(1)))
nId := tst2->(fieldget(2))
IF i%nStep = 0
?? Chr ( 219 )
nCol := Col()
nRow := Row()
? "RecNo:", tst2->(recno()), "F1:", cF1, "Id:", nId
DevPos( nRow, nCol )
next i
?? " 100% done"
? "Press any key to exit ..."
close all
inkey ( 0 )
return
- AUGE_OHR
hi Edward,
you are absolute right.
i was not aware that Field Type C can have more than 256 length under Harbour 64 BIt
Thx for your Demo to make it clear to me
The code below shows what effect the choice of locking scheme has when working with large DBF files:
REQUEST HB_GT_WIN_DEFAULT
proc main()
ErrorBlock( { | oError | NewError( oError ) } )
? "DBF lock scheme is DB_DBFLOCK_HB64."
for i:=1 to n
dbappend()
IF i%nStep = 0
?? Chr ( 219 )
next i
close
?? " 100% done"
MakeTest ( n, nStep )
tst1->(dbUnlock())
close all
? "DBF lock scheme is default."
? "Same test with default DBF lock scheme ..."
close all
inkey ( 0 )
return
Function MakeTest ( n, nStep )
Local i, cF1, nId, nRow, nCol
nCol := Col()
nRow := Row()
for i:=1 to n
tst2->(dbgoto(i))
if i%nStep = 0
?? Chr ( 219 )
nCol := Col()
nRow := Row()
next i
?? " 100% done"
RETURN Nil
FUNCTION NewError( oError )
LOCAL cMessage
LOCAL n
#include "error.ch"
#INCLUDE "COMMON.CH"
// By default, division by zero results in zero
IF oError:genCode == EG_ZERODIV
RETURN 0
// Set NetErr() of there was a database open error
IF oError:genCode == EG_OPEN .AND. ;
oError:osCode == 32 .AND. ;
oError:canDefault
NetErr( .T. )
RETURN .F.
// Set NetErr() if there was a lock error on dbAppend()
IF oError:genCode == EG_APPENDLOCK .AND. ;
oError:canDefault
NetErr( .T. )
RETURN .F.
cMessage := ErrorMessage( oError )
IF ! Empty( oError:osCode )
cMessage += " " + "(DOS Error " + LTRIM( STR( oError:osCode ) ) + ")"
n := 2
cMessage += CHR(13) + CHR (10) + CHR(13) + CHR (10)
WHILE ! Empty( ProcName( n ) )
cMessage += "Called from " + ProcName( n ) + "(" + ALLTRIM( STR( ProcLine( n++ ) ) ) + ")" +CHR(13) +CHR(10)
ENDDO
? cMessage
? "Press any key..."
inkey ( 0 )
quit
RETURN .F.
STATIC FUNCTION ErrorMessage( oError )
LOCAL cMessage, n
// start error message
cMessage := iif( oError:severity > ES_WARNING, "Error", "Warning" ) + " "
// add subsystem name if available
IF ISCHARACTER( oError:subsystem )
cMessage += oError:subsystem()
cMessage += "???"
// add subsystem's error code if available
IF ISNUMBER( oError:subCode )
cMessage += "/" + LTRIM( STR( oError:subCode ) )
cMessage += "/???"
// add error description if available
IF ISCHARACTER( oError:description )
cMessage += " " + oError:description
// add either filename or operation
IF !Empty( oError:filename )
cMessage += ": " + oError:filename + CHR( 13 ) + CHR( 10 )
IF !Empty( oError:operation )
cMessage += ": " + oError:operation + CHR( 13 ) + CHR( 10 )
// add oError:Args
if ValType( oError:Args ) == "A"
cMessage += " Arguments :" + CHR( 13 ) + CHR( 10 )
FOR n = 1 to Len( oError:Args )
cMessage += " [" + Str( n, 4 ) + "] = " + ValType( oError:Args[ n ] ) + ;
" " + hb_valToExp( oError:Args[ n ] ) + CHR( 13 ) + CHR( 10 )
IF !Empty ( Alias () )
cMessage += " Alias: " + Alias()
RETURN cMessage
