HMG Extended Edition version 24.03 is published
gfilatov
Post by gfilatov »
Hi Friends,
The MiniGUI team is pleased to announce the release of the latest version of Harbour MiniGUI Extended Edition.
The installation file for the standard build of Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
A password-protected 7z archive of the professional build for Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/hmg-24.03-pro.7z
The PRO version password is available only to donors.
Upgrading to this build is recommended.
I wish everyone to enjoy programming in HMG.
Best wishes,
[MiniGUI Team]
gfilatov
Re: HMG Extended Edition version 24.03 is published
Post by gfilatov »
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 13.2.0 (packaged on 2024-03-10).
Components versions:
Harbour MiniGUI Extended Edition 24.03 (Release)
Harbour 3.2.0dev (r2403071241)
Harbour Make (hbmk2) 3.2.0dev (r2024-03-07 12:41)
The above distributions have the updated SQLRDD library and MySQL server support
(using the example of УMySql ClientФ), and they are available to all donors.
Thanks for your attention.
Greetings,
Grigory
Thanks !
gfilatov
Post by gfilatov »
serge_girard wrote: Mon Mar 18, 2024 10:33 am Thanks !
Hi Serge,
How are you doing :?:
Thank you for your continued attention and feedback :!:
Hi Grigory,
I'm fine and yesterday I coincidentally passed at Luyksgestel and was thinking of our meeting two years ago ! We made this photo!
Still in Luyksgestel?
grigory and serge.jpg (46.43 KiB) Viewed 11593 times
gfilatov
Post by gfilatov »
serge_girard wrote: Tue Mar 19, 2024 4:10 pm Hi Grigory,
Hi Serge,
Thank you for reminding :!:
Yes, I'm still here. 8-)
See you soon :?: :arrow:
gfilatov
Post by gfilatov »
Hi Friends,
I have prepared a comparison of standard and professional builds of MiniGUI in the form of a table below:
Compiler: Borland C++ 5.8.2 (32-bit)
|                           |  STANDARD  |  PRO-build  |
| Harbour binary            |  Standard  |  Optimized  |
| MiniGUI library           |  Debug     |  Release    |
| Hmgs-Ide binary           |  Supported |  Supported  |
| HMG IDE binary and source |      -     |  Supported  |
| Basic samples             |  Supported |  Supported  |
| Advanced samples          |  Supported |  Supported  |
| Applications samples      |      -     |  Supported  |
| Utils samples             |      -     |  Supported  |
| SQLRDD library and samples|      -     |  Supported  |
Hoping this will be helpful :idea:
Thanks !
ASESORMIX
Post by ASESORMIX »
Muchas Gracias.
