ToolBar position in a form
Source code related resources
I can't find if it's a way to position toolbar anywhere I want on the form.
Do anybody have an idea how to move it?
Re: ToolBar position in a form
Marek,
I don't think it is possible. Anyway I never found it!
Is the only way building own toolbar? Strange..
gfilatov
Post by gfilatov »
mol wrote: Thu Mar 07, 2024 7:58 am Is the only way building own toolbar? Strange..
Hi Marek,
If you are talking about floating toolbar, this feature is available in MiniGUI Ex build.
The source code to define the above toolbar is below.
      DEFINE WINDOW Form_Fl ;
         WIDTH 200 HEIGHT 80 ;
         TITLE 'ToolBar Float Small Buttons';
         PALETTE ;
         ON SIZE flResizeTb();
         ON INIT AdjustFloatToolbar( GetFormHandle('Form_1'), GetFormHandle('Form_fl'), GetControlHandle ('ToolBar_i' , 'Form_fl' ) )
         DEFINE TOOLBAREX ToolBar_i BUTTONSIZE 16,16 IMAGELIST IDB_STD_SMALL_COLOR  CAPTION 'Small Buttons from DLL' FLAT
            BUTTON Button_1 ;
               PICTUREINDEX STD_FILENEW ;
               TOOLTIP 'New file';
               ACTION MsgInfo('Click! ')
            BUTTON Button_2 ;
               PICTUREINDEX STD_FILEOPEN ;
               TOOLTIP 'File open';
            BUTTON Button_3 ;
               PICTUREINDEX STD_FILESAVE ;
               TOOLTIP 'Save file';
               ACTION MsgInfo('Click! ');
            BUTTON Button_4 ;
               PICTUREINDEX STD_PRINTPRE ;
               TOOLTIP 'Print Preview';
            BUTTON Button_5 ;
               PICTUREINDEX STD_PRINT ;
               TOOLTIP 'Print ';
            BUTTON Button_6 ;
               PICTUREINDEX STD_PROPERTIES ;
               TOOLTIP 'Properties';
            BUTTON Button_7 ;
               PICTUREINDEX STD_REPLACE ;
               TOOLTIP 'Replace';
            BUTTON Button_8 ;
               PICTUREINDEX STD_FIND ;
               TOOLTIP 'Find';
            BUTTON Button_9 ;
               PICTUREINDEX STD_CUT ;
               TOOLTIP 'Cut';
            BUTTON Button_10 ;
               PICTUREINDEX STD_DELETE ;
               TOOLTIP 'Delete';
            BUTTON Button_11 ;
               PICTUREINDEX STD_PASTE ;
               TOOLTIP 'Paste';
            BUTTON Button_12 ;
               PICTUREINDEX STD_UNDO ;
               TOOLTIP 'Undo';
            BUTTON Button_13 ;
               PICTUREINDEX STD_REDOW ;
               TOOLTIP 'Redo';
            BUTTON Button_14 ;
               PICTUREINDEX STD_HELP ;
               TOOLTIP 'Help';
         END TOOLBAR
   CENTER WINDOW Form_Fl
   ACTIVATE WINDOW Form_Fl
You can see possible processing of this toolbar in the following picture:
Great Grigory !
It's useful, but I thought about placing ordinary toolbar at the of the form
Post by EduardoLuis »
Hi Mol:
The best place to put a Toolbar is at the top of the form.-
As it is a container, you can define many toolbars in diferent modal windows, so as it is, its absolutly versatile.-
I remember that somebody long time ago, put the toolbar at the bottom of the form, but its not usefull.-
As lots of app manages toolbar at the top, end users are familiarized looking options at the op of form.-
Just an opinion.-
With regards. Eduardo
I agree that the best place of toolbar is at the top. But, my form has two functions: one to add cheque and second - list of clients with texboxes of its properties and possibilities to edit and add new one.
It's my client request.
gfilatov
Post by gfilatov »
mol wrote: Sat Mar 09, 2024 3:32 pm I agree that the best place of toolbar is at the top. But, my form has two functions: one to add cheque and second - list of clients with texboxes of its properties and possibilities to edit and add new one.
Hi Marek,
How about using a vertical toolbar as shown in the image below :?:
