The SQLRDD library for Harbour and MiniGUI
gfilatov
Re: The SQLRDD library for Harbour and MiniGUI
Post by gfilatov »
Hi Friends,
More good news :!:
I tried to rewrite the MySqlCli example of Minigui using the SQLRDD library.
You can see the result of this program in the picture below:
Your feedback is welcome. :)
gisjr134
Post by gisjr134 »
Hi All ,
For insert records into the DataBase Table(MySql) , Will DbAppend() Work This Way ? Or Will i Have To Execute a Insert into Command?
Using This SQLRDD
Greetings to All
gfilatov
Post by gfilatov »
gisjr134 wrote: Sat Dec 30, 2023 9:33 pm Hi All ,
Using This SQLRDD
Yes, sure.
DbAppend() function works fine with SQLRDD.
For an example, see the first post in this discussion. :idea:
gisjr134
Post by gisjr134 »
Thank's ,
Happy New Year For EveryOne.
gisjr134
Post by gisjr134 »
I Got This Error When Compiling and Building The Demo Project described above With the libsqlrdd.a avaible for download here in this thread.
c:/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/8.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible c:/hmg/lib-64\libsqlrdd.a when searching for -lsqlrdd
c:/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/8.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lsqlrdd
I Think it might be The b4 bit Version of habour and mingw i'm using. Some kind of confilct , i don't Know.
gfilatov
Post by gfilatov »
gisjr134 wrote: Sun Dec 31, 2023 7:33 pm I Got This Error When Compiling and Building The Demo Project described above With the libsqlrdd.a avaible for download here in this thread.
You are correct.
This libsqlrdd.a file is for a 32-bit HMG, but your environment is 64-bit.
BTW I also have a 64-bit version of SQLRDD for all MiniGUI Ex donors.
For details, see viewtopic.php?p=70595#p70595. :arrow:
Hope this was helpful. :idea:
gisjr134
Post by gisjr134 »
Hi ,
Can I Compile It in Harbour\MingW 64 Bits ? The SQLRDD ..
gfilatov
Post by gfilatov »
gisjr134 wrote: Tue Jan 02, 2024 2:51 pm Hi ,
Yes, sure.
You will need the following software: :arrow:
1) the sources of the SQLRDD library have been updated to work with MySQL versions above 5.1;
2) Harbour make tool hbmk2 project file to create this library with a 64-bit version of \MingW.
That's all :idea:
gisjr134
Post by gisjr134 »
Hi ,
What is This Error ? Bison?
Build64 /n /b SqlRdd.Hbp
lder\xHarbour-SQLRDD\source>buildexe release
Compilando..
hbmk2: Processando opções do ambiente: -comp=mingw64
hbmk2[SqlRdd]: plugin: HB_BISONPATH not set, could not autodetect 'bison.exe'
executable
gfilatov
Post by gfilatov »
gisjr134 wrote: Tue Jan 02, 2024 10:07 pm Hi ,
Compilando..
executable
You should set the HB_BISONPATH environment variable to determine the path to the required bison.exe application, i.e.
SET HB_BISONPATH=%ProgramFiles%\GnuWin32\Bin
