GIF animation demo
gfilatov
GIF animation demo
Post by gfilatov »
Hello Friends,
I want to present a small GIF animation demo based upon the Harbour TGif class.
 * Copyright 2002-09 Roberto Lopez <harbourminigui@gmail.com>
 * Based upon sample Minigui\Samples\Advanced\AnimatedGif
 * Author: P.Chornyj <myorg63@mail.ru>
 * Harbour TGif class
 * Copyright 2009 Grigory Filatov <gfilatov@freemail.ru>
#include "minigui.ch"
Function Main()
Local oGif
	SET MULTIPLE OFF WARNING
	DEFINE WINDOW Form_Main ;
		WIDTH 0 HEIGHT 0 ;
		TITLE 'Gif89 Demo' ;
		MAIN NOMAXIMIZE NOSIZE ;
		ON INTERACTIVECLOSE OnClose( oGif )
		DEFINE MAIN MENU
			DEFINE POPUP "&File"
				MENUITEM '&Play' ACTION IIF( !oGif:IsRunning(), oGif:Play(), )
				MENUITEM '&Stop' ACTION IIF( oGif:IsRunning(), oGif:Stop(), )
				SEPARATOR
				MENUITEM "E&xit" ACTION OnClose( oGif )
			END POPUP
			DEFINE POPUP "&?"
				MENUITEM "GIF &Info" ACTION IIF( oGif:nTotalFrames > 1, ;
					( oGif:Stop(), MsgInfo( ;
					"Picture name" + Chr(9) + ": " + cFileNoPath( oGif:cFileName ) + CRLF + ;
					"Image Width"  + Chr(9) + ": " + hb_ntos( oGif:nWidth ) + CRLF + ;
					"Image Height" + Chr(9) + ": " + hb_ntos( oGif:nHeight ) + CRLF + ;
					"Total Frames" + Chr(9) + ": " + hb_ntos( oGif:nTotalFrames ) + CRLF + ;
					"Current Frame" + Chr(9) + ": " + hb_ntos( oGif:nCurrentFrame ), ;
					"GIF Info" ), oGif:Play() ), )
			END POPUP
		END MENU
		oGif := TGif():New( 'santa.gif', 20, 20, 120, 350, 95 )
	Form_Main.Width := Max( 180, oGif:nWidth + 2 * GetBorderWidth() + 40 )
	Form_Main.Height := GetTitleHeight() + oGif:nHeight + 2 * GetBorderHeight() + 60
	oGif:nLeft := ( Form_Main.Width - oGif:nWidth - 2 * GetBorderWidth() ) / 2 + 1
	DRAW PANEL IN WINDOW Form_Main ;
		AT oGif:nTop - 2, oGif:nLeft - 2 ;
		TO oGif:nBottom, oGif:nRight
	CENTER WINDOW Form_Main
	ACTIVATE WINDOW Form_Main
Function OnClose( oGif )
	oGif:End()
	ThisWindow.Release()
Your comments are welcome :!:
Tgif image
Tgif image
tgif.zip
Demo application
(439.31 KiB) Downloaded 585 times
luisvasquezcl
Re: GIF animation demo
Post by luisvasquezcl »
Hi Grigory,
excelent demo ...
best regards,
luis vasquez
Vanguarda
Post by Vanguarda »
Hi friends,
Thanks Grigory for share this nice demo.
Thanks for sharing Grigory.
Ricci
Post by Ricci »
gfilatov wrote:Hello Friends,
Where do i get this TGif class ? I can´t compile your source.
Solved :D
And learned: never use a directory name with a space for compiling ("Animated GIFs") !!
But i´m still not able to compile: "DRAW PANEL IN WINDOW ..."
Compiler didn´t know the word PANEL.
Nice!
gfilatov
Post by gfilatov »
Solved :D
Hello,
The command DRAW PANEL exists in the HMG Extended Edition.
The new TGif class will be available at the next buid of HMG EE :arrow:
Ricci
Post by Ricci »
gfilatov wrote:The command DRAW PANEL exists in the HMG Extended Edition.
What is the difference between the Standard and the Extended Edition?
Which one should i use?
At the moment i use HMG 3 Test XII.
gfilatov
Post by gfilatov »
Ricci,
Thanks for your interest :!:
It is an individual preference because the Extended Edition is a fork from the Official HMG and based upon Borland C++ (preferable), MinGW or Pelles C compilers. :idea:
gfilatov wrote: The command DRAW PANEL exists in the HMG Extended Edition.
:mrgreen:
Could be you so kind to post the DRAW PANEL command source code adapted for HMG?
So, I could add in the 'PROPOSED.FEATURES' folder of the next HMG release... or better... you could add the code to HFCL.
TIA.
