Drop files from Explorer to HMG Control
Re: Drop files from Explorer to HMG Control
andyglezl wrote: Mon Mar 23, 2020 5:18 am What makes the difference / advantage when using Drag & Drop instead of
the Technique :idea:
there are many Way and DragDrop is the Windows Way which i can use on Table-PC without Keyboard.
DragAcceptFiles() does exist in FiveWin v1.7 for Cl*pper from 1994 (!) which Code i use now with HMG.
have a look at those Code
so it is no new Windows API Function.
Next was DDE before OLE-DragDrop (what i still search)
i´m sure that
  ON MOUSEMOVE DragMove( ThisWindow.Name ) ;
  ON MOUSEDRAG DragHere( ThisWindow.Name ) ;
does work when 1st HBFM Release ... but since some Time it does not work any more ... hm
so i search for DragAcceptFiles and found c:\MiniGUI\SOURCE\c_winapimisc.c which run under HMG
Demo show that DRAGQUERYFILES work and i can assign it to EditBox or Textbox.
For Media-File you got File-Name to use it as IMAGE or "play" Media-file
as you see Demo work ... but it is only a Demo so what about hole App :?:
in a normal Window i have more than 1 x Control so i need to know "where" i drop.
i got the Tip from Andrés to use "Hover" ... i have to EVAL Sample to find out how to implement it
but even it i found out "where" i drop i need some "extra" to identify if it "allow" on "that" Control
under Xbase++ we have a Property DropZone := .T. so only on those Control User "can" drop.
so i like to ask for new Property "DropZone" in next HMG Release
hi
i made a new Sample with 4 Controls. when Drop it will assign it to "that" Control
i have limited it to EDITbox and Textbox, both are Type "EDIT"
Question : is there a overview for GetControlTypeByIndex() which Type are possible :?:
i have delete MiniGUI Source as i don´t understand how to use it.
DragAccept02.zip
(3.04 KiB) Downloaded 653 times
found in DragDrop Sample from edk, Thx
FUNCTION HMG_ValidControlTypeDragAndDrop( cCtrlType )
RETURN cCtrlType == 'GRID' .OR. cCtrlType == 'MULTIGRID' .OR. cCtrlType == 'EDIT' .OR. cCtrlType == 'LIST' .OR. ;
cCtrlType == 'MULTILIST' .OR. cCtrlType == 'RICHEDIT' .OR. cCtrlType == 'TEXT' .OR. cCtrlType == 'NUMTEXT' .OR. ;
cCtrlType == 'MASKEDTEXT' .OR. cCtrlType == 'CHARMASKTEXT' .OR. cCtrlType == 'TREE'
AUGE_OHR wrote: Tue Mar 24, 2020 6:14 am hi
Hola Jimmy
Gracias por tu ejemplo me es muy útil.
Solo que tengo el problema de que los caracteres acentuados no son interpretados en
el EDITBOX como lo muestra ésta imagen de ejemplo.
Sabrás la razón de este detalle ?
Hi jimmy
Thanks for your example it is very useful to me.
Just that I have the problem that accented characters are not interpreted in the EDITBOX as shown in this example image.
Do you know the reason for this detail?
andyglezl wrote: Thu Nov 26, 2020 6:04 am Just that I have the problem that accented characters are not interpreted in the EDITBOX as shown in this example image.
i just can guess : it is ANSI from Explorer
Ok
La solución está aquí... (de edk)
Okay
The solution is here ... (from edk)
https://www.hmgforum.com/viewtopic.php? ... ode#p63652
Para mí, así funciona:
For me, this is how it works:
		CASE nMsg == WM_DROPFILES
			aFiles := DragQueryFileS( nWParam )
			SET( _SET_CODEPAGE, "DEWIN" )
        			SetProperty( "Win1", "EB_DropHere", "Value", aFiles[ 1 ] )
			SET( _SET_CODEPAGE, "UTF8" )
Thanks edk and Jimmy
mmmm...
De está forma me sirve, pero el valor no es permanente, al cambiar de nuevo
a SET( _SET_CODEPAGE, "UTF8" ), queda igual...
mmmm...
This is how it works, but the value is not permanent, when changing back to
SET (_SET_CODEPAGE, "UTF8"), it remains the same ...
Si lo pongo al inicio del programa, funciona para los nombres pero cambia en otros lados...
If I put it at the beginning of the program, it works for names but changes elsewhere ...
Aquí la solución:
Here the solution:
			SetProperty( "Win1", "EB_DropHere", "Value", Hb_Translate( aFiles[ 1 ], "DEWIN", "UTF8" ) )
			or
			hb_StrToUtf8( aFiles[ 1 ], "DEWIN" )
AidTIC
Post by AidTIC »
AUGE_OHR wrote: Mon Mar 23, 2020 5:02 am hi,
andyglezl wrote: Mon Mar 23, 2020 2:03 am You can see this from EDK...
https://www.hmgforum.com/viewtopic.php? ... fix#p57451
thx for Tip, GREAT Sample
but it use DragDrop "inside" App while i try to get DragDrop from "outside".
most i use DragDrop for new Media-Files to drop them into Playlist.
it is a single Control in a Window so it is easy to find Control where i drop.
the Demo Sample just do that ...
! Note : this DragDrop Style only have a File-List of Media-Files NOT Media itself
but i think about next Step when have many Controls in a Window ...
under HMG i´m not able to restrict it on Control i want ( Xbase++ -> o:DropZone := .T. )
here Source Code i use
DROPFILE_Source.ZIP
Me funciona bien cuando arrastro un archivo guardado, pero cuando lo arrastro desde un correo (outlook) no me deja.
Como se podría implementar?
It works fine for me when I drag a saved file, but when I drag it from an email (outlook) it doesn't let me.
How could it be implemented?
Gracias / Thank you
Skydone Solutions
www.skydone.com
hi.
AidTIC wrote: Wed Nov 29, 2023 4:08 pm It works fine for me when I drag a saved file, but when I drag it from an email (outlook) it doesn't let me.
as i know DragAccept does not support OLE for DragDrop like Outlook Email
under Xbase++ there was a Trick to use a IE Window to drop anything you want. not sure if it still work with EDGE
