DOS command
DOS command
Hello,
Does anybody know if there is some DOS command in order to 'safely remove hardware and eject media'.
Under Notification Area, choose Select which icons appear on the taskbar. Scroll to Windows Explorer: Safely Remove Hardware and Eject Media and turn it on.
I did a search on google 'windows 10 safely remove hardware and eject media' but nothing matches my needs...
Re: DOS command
i have build a Tool to "eject" USB-Stick
USBEJECT.ZIP
(1.5 MiB) Downloaded 174 times
SvargasD
Re: DOS command
Post by SvargasD »
Saludos:
Depende del escenario, si quieres expulsar una USB que sera siempre la misma, por ejemplo: alguna memoría que utilizan para respaldar datos. O por el contrario, quieres desconectar cualquier memoría USB que se conecte al dispositivo. Tambien existe la posibilidad de que tengas varias unidades conectadas y solo una en particular es la que requieres desconectar.
Encontre un par de opciones, te comparto los link:
1.
https://learn.microsoft.com/es-es/windo ... s/mountvol
https://www.youtube.com/watch?v=L-lVdoPDVZ0
2.
https://spanish.getusb.info/expulsar-la ... r-version/
https://www.getusb.info/eject-usb-flash ... y-version/
Re: DOS command
Thanks all!
I will look at it in the days coming.
Re: DOS command
Jimmy,
OS.CH is missing while compiling....
Re: DOS command
serge_girard wrote: Thu Nov 09, 2023 8:00 am OS.CH is missing while compiling....
you are right, it s from Xbase++
but it is not need in Sample so please also delete it and line
LOCAL nVersion  := VAL( OS( OS_VERSION ) )
Re: DOS command
Oops... now DLL.CH is missing!
Re: DOS command
hi Serge,
serge_girard wrote: Fri Nov 10, 2023 7:32 am Oops... now DLL.CH is missing!
sorry, it is also from Xbase++
try for DLL.DH :
// Konstanten der Aufrufkonventionen
#define  DLL_SYSTEM               4
#define  DLL_CDECL                8
#define  DLL_STDCALL             32
#define  DLL_XPPCALL            128
#ifdef   __OS2__
  #define DLL_OSAPI             DLL_SYSTEM
#else
  #define DLL_OSAPI             DLL_STDCALL
#endif
Re: DOS command
Thanks! Now it works and so I can loof for my needs!
