The SQLRDD library for Harbour and MiniGUI
gisjr134
- DBs Used: DBF,MySQL,PostgreSQL
Re: The SQLRDD library for Harbour and MiniGUI
Hi To all ,
Excelent Work! It Can be used in Hmg ?
Yes, it is.
Sorry, but I only ran tests with MySQL server.
And everything is fine.
Yes, sure.
SQLRDD library is related to SQL database management, so the GUI is not important.
gisjr134
Excelent , One more Question.
Is it compatible With the format 'Use ... Via ' , DbCloseArea(), DbuseArea(),Etc ??
SomeThing Like:
nConnection := RDDINFO( RDDI_CONNECT, { "MYSQL", cServer , cUserDb , cPassDb , "sisdb"} )
If nConnection = 0
MsgInfo("Unable connect to the server!"+Chr(13)+Chr(10)+Str(RDDINFO( RDDI_ERRORNO ))+Chr(13)+Chr(10)+RDDINFO( RDDI_ERROR , .f. ))
Return .f.
End If
If Select(cAlias) > 0
dbSelectArea( cAlias )
Use
End If
dbUseArea( .T.,, cSqlBrw, cAlias )
dbGoTop()
SomeThing Like:
If nConnection = 0
Return .f.
End If
Use
End If
dbGoTop()
Exactly.
Please take a look at the example code below:
* SQLRDD info
* Sample application to get extended database info
* Copyright (c) 2003 - Marcelo Lombardo <lombardo@uol.com.br>
* All Rights Reserved
#define _HMG_OUTLOG
#include <minigui.ch>
#include "sqlrdd.ch"
#include "dbinfo.ch"
#define RECORDS_IN_TEST 100
FIELD CODE_ID, DAYS
FUNCTION MAIN(cRDD, cDsn)
LOCAL aStruct := { ;
{"CODE_ID" , "C", 8, 0}, ;
{"CARDID" , "C", 1, 0}, ;
{"DESCR" , "C", 50, 0}, ;
{"PERCENT" , "N", 8, 2}, ;
{"DAYS" , "N", 6, 0}, ;
{"DATE_LIM", "D", 8, 0}, ;
{"ENABLE" , "L", 1, 0}, ;
{"OBS" , "M", 10, 0}, ;
{"VALUE" , "N", 18, 6} ;
LOCAL i
LOCAL oSql
DEFAULT cRDD := "SQLRDD"
Connect(@cRDD, cDSN) // see connect.prg
? "Connected to ", SR_GetConnectionInfo(, SQL_DBMS_NAME), SR_GetConnectionInfo(, SQL_DBMS_VER)
? "RDD in use :", cRDD
? "Creating table"
oSql := SR_GetConnection()
dbCreate("TEST_TABLE3", aStruct, cRDD)
USE TEST_TABLE3 via cRDD
INDEX ON CODE_ID TO TBL3_INDX
INDEX ON CODE_ID TAG CODE_ID FOR DAYS < 20
IF reccount() < RECORDS_IN_TEST
FOR i := 1 TO RECORDS_IN_TEST
APPEND BLANK
REPLACE CODE_ID WITH strZero(i, 5)
REPLACE DESCR WITH dtoc(date()) + " - " + time()
REPLACE DAYS WITH (RECORDS_IN_TEST - i)
REPLACE DATE_LIM WITH date()
REPLACE ENABLE WITH .T.
REPLACE OBS WITH "This is a memo field. Seconds since midnight : " + alltrim(str(seconds()))
NEXT i
dbGoTop()
i := select()
? "Workarea number :", i
? "RDD Version :", dbInfo(DBI_RDD_VERSION)
? "RDD Build :", dbInfo(DBI_RDD_BUILD)
? "Current table :", dbInfo(DBI_FULLPATH)
? "Is table shared :", dbInfo(DBI_SHARED)
SKIP -1
? "Bof :", dbInfo(DBI_BOF)
? "Eof :", dbInfo(DBI_EOF)
dbGoBottom()
SKIP
dbGoTop()
? "Host Database :", dbInfo(DBI_DB_VERSION), "(see sqlrdd.ch for details)"
? "WorkArea Object :", (i)->(dbInfo(DBI_INTERNAL_OBJECT):classname())
? "Connection Obj :", (i)->(dbInfo(DBI_INTERNAL_OBJECT):oSql:classname())
? "Locking a, b :", SR_SetLocks({"a", "b"})
? "RecSize() :", RecSize()
? "RecNo() :", RecNo()
? "RecCount() :", RecCount()
? "OrdKeyCount() :", OrdKeyCount()
? "SQLRDD Conn ID :", SR_GetnConnection()
SET ORDER TO 2
? "OrdCount() :", OrdCount()
? "IndexOrd() :", IndexOrd()
(i)->(dbCloseArea())
dbUseArea(.F., cRDD, "TEST_TABLE3", "TEST")
EDIT EXTENDED
DbCloseAll()
? "Connection ID :", oSql:GetConnectionID()
? "Kill Connection :", oSql:KillConnectionID(9999)
#include "connect.prg"
Connected to MYSQL NATIVE 80030
RDD in use : SQLRDD
Creating table
Workarea number : 1
RDD Version : MGMNT 1.72
RDD Build : 15
Current table : TEST_TABLE3
Is table shared : .F.
Bof : .T.
Eof : .F.
Bof : .F.
Eof : .T.
Host Database : 12 (see sqlrdd.ch for details)
WorkArea Object : SR_WORKAREA
Connection Obj : SR_MYSQL
Locking a, b : .F.
RecSize() : 131
RecNo() : 1
RecCount() : 100
OrdKeyCount() : 100
SQLRDD Conn ID : 1
OrdCount() : 2
IndexOrd() : 2
Connection ID : 38
Kill Connection : 1
could you place compiled library here? (for HMG - MinGW)
Yes, sure. Here it is.
- libsqlrdd-mgw32.zip
- (326.73 KiB) Downloaded 1446 times
I have prepared a simple example showing how to migrate from DBFCDX to SQLRDD using the standard BROWSE control (see attachment).
You can compare the codes to see the difference.
Using SQLRDD requires the following changes:
1) adding a connection to the SQL server (MySQL in that case) and
2) calling the dbunlock() function after adding a record.
Thank you for your attention.
- cdx2sql.zip
- Examples source code
- (2.63 KiB) Downloaded 1443 times
I have prepared the following SQLRDD example showing how to retrieve data from an existing 'Country' table in the MySQL database 'World' that is distributed with the MySQL installation.
Since the above table is not a native SQLRDD table, we need to run a SQL query on this table using the built-in SQLRDD SQL parser and SQL code generator.
Please look at the following OpenTable procedure code:
The result of the program is shown below.
Your feedback is welcome.
PROCEDURE OpenTable
LOCAL cRDD
LOCAL cComm
LOCAL apCode
LOCAL nErr
LOCAL nPos
LOCAL n
Connect( @cRDD ) // see connect.prg
// Request data for Chart 1
cComm := "SELECT * FROM Country ORDER BY Population DESC"
apCode := SR_SQLParse( cComm, @nErr, @nPos )
cComm := SR_SQLCodeGen( apCode )
dbUseArea( .F., "SQLRDD", cComm, "t1" )
// One serie data
aSer1 := Array( 10, 1 )
aSerVal1 := Array( 10 )
aSerName1 := Array( 10 )
n := 0
t1->( dbGoTop() )
DO WHILE t1->( RecNo() ) <= 10 // top 10 values
aSer1[ ++n, 1 ] := t1->Population / 1000
aSerVal1[ n ] := t1->NAME
aSerName1[ n ] := aSerVal1[ n ]
t1->( dbSkip() )
ENDDO
dbCloseArea()
// Request data for Chart 2
cComm := "SELECT * FROM Country ORDER BY SurfaceArea DESC"
dbUseArea( .F., "SQLRDD", cComm, "t2" )
// One serie data
aSer2 := Array( 10 )
aSerName2 := Array( 10 )
n := 0
t2->( dbGoTop() )
DO WHILE t2->( RecNo() ) <= 10 // top 10 values
aSer2[ ++n ] := Round( t2->SurfaceArea / 1000, 2 )
aSerName2[ n ] := Trim( t2->Name )
t2->( dbSkip() )
ENDDO
dbCloseArea()
// Request data for Chart 3
cComm := "SELECT Name, Population / SurfaceArea as off FROM Country WHERE SurfaceArea > 250 ORDER BY off DESC"
dbUseArea( .F., "SQLRDD", cComm, "t3" )
// One serie data
aSer3 := Array( 20, 1 )
aSerVal3 := Array( 20 )
aSerName3 := Array( 20 )
n := 0
t3->( dbGoTop() )
WHILE t3->( RecNo() ) <= 40 .AND. t3->Off > 5000
t3->( dbSkip() )
END
DO WHILE t3->( RecNo() ) <= 40 // top 40 values
IF n > 19
EXIT
aSer3[ ++n, 1 ] := Round( t3->OFF, 3 )
aSerVal3[ n ] := t3->NAME
aSerName3[ n ] := Transform( aSer3[ n, 1 ], "9 999.999" ) + ' ' + aSerVal3[ n ]
t3->( dbSkip() )
ENDDO
dbCloseArea()
// First chart drawing
DrawChart_1( aser1 )
