TMultChoice
Red2
Re: TMultChoice
Post by Red2 »
Thank you gisjr134. I did what you suggested.
Once I replaced NOBORDER with /* NOBORDER */ the project compiled and ran.
The two .PRG files that need this replacement are:
AuxFunc1.PRG and
LstMultChoice.PRG
Red2
Re: TMultChoice
thx, i got it running now :D
i was confuse while in AuxFunc1.PRG i found
#include <minigui.ch>
and thought Minigui is used
tip : use a CODE "Formatter"
https://www.hmgforum.com/viewtopic.php?t=6223
p.s. put all HB_FUNC into HB_FUNC.PRG as CLICK can not handle "C" Code
gisjr134
Re: TMultChoice
Post by gisjr134 »
Hi To All ,
I use Ultra Edit , so i dont have how to indent\formatter the Code. And the Tools i Know does not recognize the 'Define window' , In order to Formatter the code i need a Tool for Hmg Syntax. But Thank´s for the Sugestion. There is a Formatter in VS Code , But It Has This problem descrived Above.I Didn´t Know This CLICK Tool.
Re: TMultChoice
HI!
I've compiled your project in HMG344 and every time when I use wheel on my mouse I get an error:
Date:10/05/23 Time: 17:09:55
Error BASE/1003 Variable does not exist: NWPARAM
Called from XMULTCHEVEN(499)
Called from EVENTPROCESS(159)
Called from DOMESSAGELOOP(0)
Called from DOMETHOD(9003)
Called from MAIN(46)
gisjr134
Re: TMultChoice
Post by gisjr134 »
LOCAL nWParam := EventWPARAM() ,
Just Add in The Begin of the Function XMULTCHEVEN.
tonton2
Re: TMultChoice
Post by tonton2 »
I've compiled your project in HMG344 and HMG3.6, but I have got this error
C:\Users\Youcef\OneDrive\Bureau\MULTICHOIX\AuxFunc1.Prg(1) Error F0029 Can't open #include file 'dll.ch'
L'Algerie vous salut
Y.TABET
tonton2
Re: TMultChoice
Post by tonton2 »
after removing dll.ch it gives me this error:
C:\hmg.3.4.4\SAMPLES\MULTICHOIX\LstMultChoice.Prg(238) Error E0030 Syntax error "syntax error at 'WINDOW'"
Y.TABET
tonton2
Re: TMultChoice
Post by tonton2 »
It's OK thank you Merci beaucoup
Y.TABET
