gisjr134
- DBs Used: DBF,MySQL,PostgreSQL
Post
by gisjr134 »
Hi EveryOne ,
A Class in wich you can Select One or more itens in a Graphical Window. Similar to ListBox . You can Easily modify to Behave lilke a ListBox.
- Arquivo1.png (42.14 KiB) Viewed 45162 times
[/centre]
- Arquivo3.png (47.07 KiB) Viewed 45162 times
In case You have Difficult to Compile , remove the NOBORDER Directive.Or See The Thread 'Window Without Border' Created by me
- tMultiChoice.rar
- (188.46 KiB) Downloaded 594 times
- PrtScr capture_95.png (41.85 KiB) Viewed 45162 times
edk
Post
by edk »
Steed
Post
by Steed »
Post
by Rathinagiri »
Super! Thank you for sharing.
Post
by serge_girard »
Thanks !
gisjr134
Post
by gisjr134 »
Thank´s all for The FeedBack.
Post
by serge_girard »
Hi!
I miss dll.ch ....
gisjr134
Post
by gisjr134 »
You may Remove from the .prg , there won´t be any problem
Post
by AUGE_OHR »
i want to try it but not sure which MiniGUI Version are need
i got these Error
AuxFunc1.Prg(57) Error E0030 Syntax error "syntax error at 'WINDOW'"
AuxFunc1.Prg(76) Error E0030 Syntax error "syntax error at 'WINDOW'"
AuxFunc1.Prg(92) Error E0030 Syntax error "syntax error at 'WINDOW'"
AuxFunc1.Prg(473) Error E0030 Syntax error "syntax error at 'WINDOW'"
AuxFunc1.Prg(512) Error E0030 Syntax error "syntax error at 'WINDOW'"
AuxFunc1.Prg(529) Error E0030 Syntax error "syntax error at 'WINDOW'"
6 errors
i saw some Macro ... and "all" Parameter even if NIL
i think i have a "old" Version of MiniGUI (how to find out which Version ? )
gisjr134
Post
by gisjr134 »
I used HMG To Develop It , don´t know if works in Minigui.
-HMG 3.4.4 2017/03/29
Try remove NOBORDER directive.
