Sorting arrays and storing them as variables.
edk
Post by edk »
Friends, I have two questions/problems regarding arrays and sorting them.
I have a multidimensional array where the first element is a number and the second element is a date. My task is to sort the array by date and within the same date to sort by number.
Below is the code I use.
Function main()
Local aArray := {{772865, 0d20230407}, {773341, 0d20230102}, {773342, 0d20230411}, {773343, 0d20230411}, {773352, 0d20230411}, ;
           {770642, 0d20230329}, {770647, 0d20230329}, {773602, 0d20230412}, {777113, 0d20230426}, {779616, 0d20230510}, ;
           {775479, 0d20230419}, {775481, 0d20230419}, {774897, 0d20230417}, {775777, 0d20230420}, {775779, 0d20230420}, ;
           {770366, 0d20230328}, {772731, 0d20230406}, {773644, 0d20230412}, {773645, 0d20230412}, {777141, 0d20230426}, ;
           {774852, 0d20230417}, {774854, 0d20230417}, {770034, 0d20230327}, {776554, 0d20230424}, {776561, 0d20230424}, ;
           {774147, 0d20230414}, {775800, 0d20230420}, {775802, 0d20230420}, {775803, 0d20230420}, {775805, 0d20230420}, ;
           {775806, 0d20230420}, {779672, 0d20230510}, {775804, 0d20230420}, {775807, 0d20230420}, {775239, 0d20230418}, ;
           {775240, 0d20230418}, {774208, 0d20230414}, {774210, 0d20230414}, {771936, 0d20230403}, {774851, 0d20230417}, ;
           {774856, 0d20230417}, {771260, 0d20230331}, {773973, 0d20230413}, {773971, 0d20230413}, {773317, 0d20230411}, ;
           {778976, 0d20230508}, {772861, 0d20230407}, {773340, 0d20230411}, {773351, 0d20230411}, {773392, 0d20230411}, ;
           {773394, 0d20230411}, {774169, 0d20230414}, {777599, 0d20230428}, {777602, 0d20230428}, {779383, 0d20230509}, ;
           {770942, 0d20230330}, {770944, 0d20230330}, {772014, 0d20230403}, {773737, 0d20230412}, {773739, 0d20230412}, ;
           {776617, 0d20230424}, {776619, 0d20230424}, {773972, 0d20230413}, {777463, 0d20230427}, {770086, 0d20230327}, ;
           {776557, 0d20230424}, {776558, 0d20230424}, {776556, 0d20230424}, {776562, 0d20230424}, {778925, 0d20230508}, ;
           {770367, 0d20230328}, {773390, 0d20230411}, {773391, 0d20230411}, {778110, 0d20230504}, {771058, 0d20230330}, ;
           {771062, 0d20230330}, {773974, 0d20230413}, {773975, 0d20230413}, {777462, 0d20230427}, {777464, 0d20230427}, ;
           {770036, 0d20230327}, {770038, 0d20230327}, {776550, 0d20230424}, {774850, 0d20230417}, {774848, 0d20230417}, ;
           {774849, 0d20230417}, {776553, 0d20230424}, {776559, 0d20230424}, {774228, 0d20230414}, {774229, 0d20230414}, ;
           {774233, 0d20230414}, {774234, 0d20230414}, {777598, 0d20230428}, {777601, 0d20230428}, {775685, 0d20230420}, ;
           {773600, 0d20230412}, {771970, 0d20230403}, {772864, 0d20230407}, {776551, 0d20230424}, {776552, 0d20230424}, ;
           {777596, 0d20230428}, {777597, 0d20230428}, {773668, 0d20230412}, {779681, 0d20230510}, {773318, 0d20230411}, ;
           {775431, 0d20230419}, {775518, 0d20230419}, {770013, 0d20230327}, {776548, 0d20230424}, {775686, 0d20230420}, ;
           {775684, 0d20230420}, {776564, 0d20230424}, {770643, 0d20230329}, {770646, 0d20230329}, {773597, 0d20230412}, ;
           {773599, 0d20230412}, {773601, 0d20230412}, {777137, 0d20230426}, {777143, 0d20230426}, {779038, 0d20230508}, ;
           {770708, 0d20230329}, {770709, 0d20230329}, {775183, 0d20230418}, {774153, 0d20230414}, {774157, 0d20230414}, ;
           {771971, 0d20230403}, {774873, 0d20230417}, {777140, 0d20230426}, {777142, 0d20230426}, {779600, 0d20230510}, ;
           {770015, 0d20230327}, {776560, 0d20230424}, {774151, 0d20230414}, {774156, 0d20230414}, {777600, 0d20230428}, ;
           {775473, 0d20230419}, {775476, 0d20230419}, {775477, 0d20230419}, {775478, 0d20230419}, {775482, 0d20230419}, ;
           {773629, 0d20230412}, {773631, 0d20230412}, {775241, 0d20230418}, {775242, 0d20230418}, {775243, 0d20230418}, ;
           {779574, 0d20230510}, {772687, 0d20230406}, {775432, 0d20230419}, {771211, 0d20230331}, {771214, 0d20230331}, ;
           {773344, 0d20230411}, {777238, 0d20230426}, {776555, 0d20230424}, {773690, 0d20230412}, {770018, 0d20230102}, ;
           {770016, 0d20230327}, {772533, 0d20230405}, {773643, 0d20230412}, {775434, 0d20230419}, {775435, 0d20230419}, ;
           {776808, 0d20230425}, {776809, 0d20230425}, {777563, 0d20230428}, {773319, 0d20230411}, {775480, 0d20230419}, ;
           {770463, 0d20230328}, {779978, 0d20230511}, {774188, 0d20230414}, {776455, 0d20230424}, {776454, 0d20230424}, ;
           {775475, 0d20230419}, {776563, 0d20230424}, {772322, 0d20230404}, {775148, 0d20230418}, {775731, 0d20230420}, ;
           {775732, 0d20230420}, {775733, 0d20230420}, {773648, 0d20230412}, {772863, 0d20230407}, {774853, 0d20230417}, ;
           {774855, 0d20230417}, {772323, 0d20230404}, {772324, 0d20230404}, {772325, 0d20230404}, {770380, 0d20230328}, ;
           {770381, 0d20230328}, {773403, 0d20230411}, {776954, 0d20230425}, {776955, 0d20230425}, {770365, 0d20230328}, ;
           {770368, 0d20230328}, {773708, 0d20230412}, {774927, 0d20230417}, {773393, 0d20230411}, {776871, 0d20230425}, ;
           {776874, 0d20230425}, {770084, 0d20230327}, {773647, 0d20230412}, {776549, 0d20230424}, {774186, 0d20230414}, ;
           {774231, 0d20230414}, {774235, 0d20230414}, {775952, 0d20230421}, {775953, 0d20230421}, {775980, 0d20230421}, ;
           {770037, 0d20230327}, {770040, 0d20230327}, {775118, 0d20230418}, {775119, 0d20230418}, {779033, 0d20230508}, ;
           {772862, 0d20230407}, {774230, 0d20230414}, {774232, 0d20230414}, {777183, 0d20230426}, {771938, 0d20230403}, ;
           {774874, 0d20230417}, {775785, 0d20230420}, {774187, 0d20230414}, {778978, 0d20230508}, {775474, 0d20230419}, ;
           {773642, 0d20230412}, {775120, 0d20230418}, {773598, 0d20230412}, {777112, 0d20230426}, {779615, 0d20230510}, ;
           {773632, 0d20230412}, {777138, 0d20230426}, {774298, 0d20230414}, {775956, 0d20230421}, {779894, 0d20230511}, ;
           {775801, 0d20230420}, {779675, 0d20230510}, {779841, 0d20230511}, {779842, 0d20230511}, {779893, 0d20230511}, ;
           {778323, 0d20230505}, {778909, 0d20230508}, {778892, 0d20230508}, {773743, 0d20230412}, {776618, 0d20230424}, ;
           {778117, 0d20230504}, {779067, 0d20230508}, {773633, 0d20230412}, {775429, 0d20230419}, {778893, 0d20230508}, ;
           {773604, 0d20230412}, {779968, 0d20230511}, {774209, 0d20230414}, {775428, 0d20230419}, {775433, 0d20230419}, ;
           {779552, 0d20230510}, {773596, 0d20230412}, {777139, 0d20230426}, {775430, 0d20230419}, {775437, 0d20230419}, ;
           {776600, 0d20230424}, {779037, 0d20230508}, {779553, 0d20230510}, {773749, 0d20230412}, {777184, 0d20230426}, ;
           {779614, 0d20230510}, {778995, 0d20230508}, {774148, 0d20230414}, {774149, 0d20230414}, {774150, 0d20230414}, ;
           {774152, 0d20230414}, {774154, 0d20230414}, {774155, 0d20230414}, {777237, 0d20230426}, {773689, 0d20230412}, ;
           {773646, 0d20230412}, {775436, 0d20230419}, {776810, 0d20230425}, {779932, 0d20230511}, {773709, 0d20230412}, ;
           {779979, 0d20230511}, {775730, 0d20230102}, {773630, 0d20230412}, {773642, 0d20230412}, {773710, 0d20230412}, ;
           {775120, 0d20230418}, {779039, 0d20230508}, {773603, 0d20230102}}
Local aSortedByNumber, aSortedByDate, aSortedByDateAndNumber
aSortedByNumber := ASort( aArray, , , { | x, y | x [ 1 ] < y [ 1 ] } )
msgdebug ( '1 SortedByNumber', aSortedByNumber )
aSortedByDate := ASort( aArray, , , { | x, y | x [ 2 ] < y [ 2 ] } )
msgdebug ( '2 SortedByDate', aSortedByDate )
aSortedByDateAndNumber := ASort( aArray, , , { | x, y | x [ 2 ] < y [ 2 ] .And. x [ 1 ] < y [ 1 ] } )
msgdebug ( '3 SortedByDateAndNumber', aSortedByDateAndNumber )
On my PC everything works as expected, but on some computers the same code, the same executable returns strange results. The resulting array is not sorted by date or number.
I don't understand it at all, and I don't know what the problem is, I thought it might be a hardware problem, e.g. it is different on AMD and Intel (I had a similar case with rounding floating-point numbers in the times of clipper), but it behaves differently on the same processor family.
The second question is how to store a sorted array in a variable to be able to use it later in the code?
The example below doesn't work as I would like.
Function main()
Local aArray := { "B", "A", "C" }
Local aArrayAscend, aArrayDescend
/* Why does changing the sort affect another array variable?
   How to keep a sorted array variable for use later in the code? */
ASort ( aArray, , , { | x, y | x < y } )
aArrayAscend := aArray
msgdebug ( 'aArrayAscend', aArrayAscend, 'aArrayDescend', aArrayDescend, "aArrayAscend should be sorted ascending, aArrayDescend should be Nil")
ASort ( aArray, , , { | x, y | x > y } )
aArrayDescend := aArray
msgdebug ( 'aArrayAscend', aArrayAscend, 'aArrayDescend', aArrayDescend, "aArrayAscend should be sorted ascending, aArrayDescend should be sorted in descending order. Why is aArrayAscend equal to aArrayDescend?" )
I would expect aArrayAscend to contain an ascending sorted array and aArrayDescend to contain a descending sorted array, but surprisingly they both have the same last sorted array, so ASort works by reference?
edk
Re: Sorting arrays and storing them as variables.
Post by edk »
I found a solution to my first problem: I converted the array data to a string and sort by string.
aSortedByDateAndNumber := ASort( aArray, , , { | x, y | hb_TtoS( x [ 2 ] ) + StrZero ( x [ 1 ], 10 ) < hb_TtoS( y [ 2 ] ) + StrZero ( y [ 1 ], 10 ) } )
Now works on all computers. I wonder why the native solution doesn't work?
The second problem is still not solved.
edk
Post by edk »
Solving the second issue (the dirty way):
aArrayAscend := &(hb_valToExp ( aArray ))
aArrayDescend := &(hb_valToExp ( aArray ))
The question remains why ASort changes the order of values in other array variables.
branislavmil
Post by branislavmil »
Hello
Try this way:
aArrayAscend := aClone(aArray)
PeteWG
Post by PeteWG »
regarding question 2:
aArrayAscend := AClone( ASort ( aArray, , , { | x, y | x < y } ) )
aArrayDescend := AClone( ASort ( aArray, , , { | x, y | x > y } ) )
// always use AClone to keep a copy of array to avoid any changes in original array to be "reflected" in your copy,
// because when you assigning an array to a variable in fact you assign references to its elements).
regards,
Pete
edk
Post by edk »
PeteWG and branislavmil: thanks guys, I completely forgot about AClone :idea: :oops:
