Where is the code for importing a pipe separated file into a table?
- mustafa
Re: Where is the code for importing a pipe separated file into a table?
Franco friend:
Let me disagree with your solution.
if we apply to a txt file with Pipe separators
with your solution : ---> "Sample1.prg"
APPEND FROM FILE.TXT DELIMITED WITH CHR(124)
It only transfers me to the Franchis2.dbf the first
column FROM DATABASE -> "R_SOCIAL"
In my solution "Sample2.prg" the
entire file Franchis.dbf to Franchis2.dbf
via "Sample2.txt" with PIPE "|" Ok!
It is also working with :
APPEND FROM sample2.txt DELIMITED WITH ({, CHR(124) })
Regards/Salam/Saludos
- PIPE.ZIP
- (1.41 KiB) Downloaded 315 times
HGAutomator
Hi mustafa,
did indeed work.
Unfortunately, it didn't seem to pull in any records, if there was a field condition like "CATEGORY='DETAIL'". That isn't serious, because I can work around it.
However, more seriously is that the Harbour version doesn't correctly interpret dates like VFP does. So a date like '06/15/2023'' is pulled in as a blank.
APPEND FROM sample2.txt DELIMITED WITH ({, CHR(124) })Unfortunately, it didn't seem to pull in any records, if there was a field condition like "CATEGORY='DETAIL'". That isn't serious, because I can work around it.
- mustafa
after
put this:
See if it works?
put this:
SET CODEPAGE TO UNICODE
SET CENTURY ON
SET DATE FRENCH
SET DATE FORMAT TO 'dd/mm/yyyy'
Pay attention to the indicated date '06/15/2023'. It is in the American format 'mm/dd/yyyy' and not French (there is no month 15 in the calendarmustafa wrote: ↑Sun Jun 18, 2023 10:05 am after
put this:
See if it works?Code: Select all
SET CODEPAGE TO UNICODE SET CENTURY ON SET DATE FRENCH SET DATE FORMAT TO 'dd/mm/yyyy'
@HGAutomator. Can U upload sample CSV file with a pipe delimiter
When Mustafa uses COPY TO sample2.txt DELIMITED WITH ({,"|"}) it puts double quoted around fields.
So must use APPEND FROM sample2.txt DELIMITED WITH ({,"|"}) to append properly.
If you use
COPY TO sample2.txt DELIMITED WITH chr(124)
or COPY TO sample2.txt DELIMITED WITH "|"
It delimites with |
You can then
APPEND FROM sample2.txt DELIMITED WITH chr(124)
or
APPEND FROM sample2.txt DELIMITED WITH "|"
If you use
It delimites with |
You can then
or
All The Best,
Franco
Canada
Franco
Canada
- mustafa
Franco friend:
Unfortunately your solution is giving me "ERROR"
Look at the sample "Sample1.prg" which creates "sample1.txt"
with Double " and PIPE
Solution in ---> Franxy1.dbf <--- OK!
The sample "Sample2.prg" according to your instructions does not create
Double " , but incorporates "," and no PIPE
The resulting file is missing data, it is mixed up.
Result in ---> Franxy2.dbf , missing the first
registration in R_SOCIAL and ADDRESS
PS: for edk, I didn't notice that the date is American
I don't speak English I'm sorry
- PIPE2.ZIP
- (2.71 KiB) Downloaded 286 times
Mustafa I find you must append with the same item you delimit with.
If you use
or COPY TO sample1.txt DELIMITED WITH "|"
It delimites with |
You can then
APPEND FROM sample1.txt DELIMITED WITH "|"
For some unknown reason ypu can not use capitals on chr in the program
COPY TO sample1.txt DELIMITED WITH CHR(124)
It delimites with C and will not work something in hmg
If you use
COPY TO sample1.txt DELIMITED WITH chr(124) // small chr
It delimites with c // small c seems to be pipe in ascii codes ?
You can then
APPEND FROM sample1.txt DELIMITED WITH chr(124)
It took a bit to find capitals on chr do not work.
If you use
It delimites with |
You can then
If you use
You can then
All The Best,
Franco
Canada
Franco
Canada
- mustafa
By default HMG works in unicode, for this you have to use:
hb_ucode()
hb_uchar()
Instead of asc/chr which works only with Ansi code pages
Save PRG code, UTF-8 encoded
and change chr(124) to HB_UCHAR(124) , but it still goes wrong <---ERROR !
It is only working with:
COPY TO sample1.txt DELIMITED WITH ({ , HB_UCHAR(124 ) })
APPEND FROM sample1.txt DELIMITED WITH ({, HB_UCHAR(124) })
hb_ucode()
hb_uchar()
***** You can try all of the following code I all works for me except capital CHR
***** You will need Franxy1.dbf in folder. This program name is Sample1.prg
***************** I use to compile. and have Franxy.dbf in folder
*@ECHO OFF
*call c:\hmg.3.4.4\build.bat sample1 %*
FUNCTION MAIN()
SET CENTURY ON
USE Franxy NEW
COPY TO Franxy1
DBCloseAll()
*********************** This Works for me with quotes ****************
USE Franxy1 NEW
COPY TO sample1.txt DELIMITED WITH ({, "|" })
DBCloseAll()
USE Franxy1 New
ZAP
APPEND FROM sample1.txt DELIMITED WITH ({, chr(124)})
*********************** This Works for me without quotes ****************
* USE Franxy1 NEW
* COPY TO sample1.txt DELIMITED WITH "|"
* DBCloseAll()
* USE Franxy1 New
* ZAP
* APPEND FROM sample1.txt DELIMITED WITH "|"
*********************** This Works for me without quotes show small c as delimiter in text file but works ****************
* USE Franxy1 NEW
* COPY TO sample1.txt DELIMITED WITH chr(124)
* DBCloseAll()
* USE Franxy1 New
* ZAP
* APPEND FROM sample1.txt DELIMITED WITH chr(124)
******** This Does Not Work for me with Capial CHR show Capital C as delimiter Missing First two Fields****************
* USE Franxy1 NEW
* COPY TO sample1.txt DELIMITED WITH CHR(124)
* DBCloseAll()
* USE Franxy1 New
* ZAP
* APPEND FROM sample1.txt DELIMITED WITH CHR(124)
GO TOP
WIDTH 1000 ;
HEIGHT 550 ;
TITLE 'Test' ;
MAIN ;
BACKCOLOR (200,200,200)
DEFINE BROWSE BR1
ROW 10
COL 10
WIDTH 1000
HEIGHT 400
HEADERS {'R_social','Direccion','Telefono', 'Ciudad', 'Pais', 'Name', 'Date'}
FIELDS {'R_social','Direccion','Telefono', 'Ciudad', 'Pais', 'Name', 'Date' }
WIDTHS {140,140,140,140,140,140,100}
WORKAREA franxy1
BACKCOLOR {180,180,180}
END BROWSE
CENTER WINDOW Form_1
*@ECHO OFF
All The Best,
Franco
Canada
Franco
Canada
Red2
- DBs Used: Visual FoxPro, FoxPro
Thank you Franco,
The command syntax you suggested,
APPEND FROM "....txt" DELIMITED WITH ({, chr(124)}),
works for me and is the "delimited character" hint I wanted.
Thanks again,
Red2
Thanks again,
Red2
