Photos
Photos
Hi there,
Does somebody know how to put autograph (some text) on a JPG/BMP/PNG file. Preferably in batch, complete folder...
Thx/Serge
gfilatov
Re: Photos
Post by gfilatov »
serge_girard wrote: Thu Jun 15, 2023 12:22 pm Hi there,
Hi Serge,
I think it's possible with the great BosTaurus library.
Please take a look at the simple procedure below:
DECLARE WINDOW _HMG_SPLASHWINDOW
Procedure textout()
LOCAL hDC, BTstruct
LOCAL hBitmap, hBitmap_aux
LOCAL nTypeText
LOCAL nAlingText
LOCAL nOrientation
LOCAL nW := BT_BitmapWidth(_HMG_SPLASHWINDOW.IMAGE.hBitmap)
LOCAL nH := BT_BitmapHeight(_HMG_SPLASHWINDOW.IMAGE.hBitmap)
   // Create bitmap in memory
   hBitmap := BT_BitmapCreateNew (nW, nH, WHITE)
   // Create hDC to a bitmap
   hDC := BT_CreateDC (hBitmap, BT_HDC_BITMAP, @BTstruct)
     // Paste image
     hBitmap_aux := BT_BitmapLoadFile ("Splash")  // load from resource
        BT_DrawBitmapTransparent (hDC, 0, 0, nW, nH, BT_SCALE, hBitmap_aux, NIL)
     BT_BitmapRelease (hBitmap_aux)
     // Draw Text
     nTypeText    := BT_TEXT_TRANSPARENT + BT_TEXT_BOLD + BT_TEXT_ITALIC
     nAlingText   := BT_TEXT_LEFT + BT_TEXT_TOP
     nOrientation := BT_TEXT_NORMAL_ORIENTATION
     BT_DrawText (hDC, 450, 350, "EXTENDED", "Times New Roman", 18, BLACK, WHITE, nTypeText, nAlingText, nOrientation)
      BT_BitmapSaveFile( hBitmap, "test.png", BT_FILEFORMAT_PNG )
   // Release hDC bitmap
   BT_DeleteDC (BTstruct)
   _HMG_SPLASHWINDOW.IMAGE.hBitmap := hBitmap
   _HMG_SPLASHWINDOW.IMAGE.Refresh()
The splash screen resource before conversion is shown below:
and the result image with added text is
Re: Photos
Thanks Grigory, I will try !
Red2
Re: Photos
Post by Red2 »
Hello All,
I am very interested in this but could not run the code in "Official HMG".
The sample code eventually compiled when I changed "dot separated" syntax such as
into GetProperty(...) syntax.
However I cannot fix the following _HMG_SPLASHWINDOW error:
Any help on what I am missing would be greatly appreciated!
Thank you!
gfilatov
Re: Photos
Post by gfilatov »
Hello Spencer,
Thanks for your interest.
You can find the source code for this example along with the executable in the attachment below.
But the above code is for use with MiniGUI Extended Edition. :o
SPLASHDEMO.ZIP
Splash demo example
(1.24 MiB) Downloaded 112 times
Red2
Re: Photos
Post by Red2 »
Thank you very much Gregory!!!
Re: Photos
I'm adapting to my needs: row, col, text, color, font, size,.... will all be variable and to be edited on form.
Next step is to 'stamp' all (or some) photo with this text.
Re: Photos
Grigory,
Any idea how to 'undo' or reset some mistaken text (when not yet save of course) ?
gfilatov
Re: Photos
Post by gfilatov »
Serge,
Please take a look at the updated sample with Undo effect in the attachment.
Hope that give you some idea :idea:
SPLASHDEMO_2.ZIP
Show some text on the image and then reset this text
(1.24 MiB) Downloaded 128 times
Re: Photos
can not open ZIP Files as Windows Defender give a Error Message about "Trojan_WACATAC.B!ML"
