Hello All,
How to add or remove controls in a window on the fly?
May be it's very elementary or it was already discussed in the forum. In that case please send the url of the discussion.
Thanks in advance.
With best regards.
How to add or remove controls on the fly?
Re: How to add or remove controls on the fly?
It is very easy to add/remove a control once the window is active.
Either add "OF" or "PARENT" keyword to the definition.
For example,
The above code should create a new button on the fly.
Suppose you want to remove a particular control, give the following command.
For example,
define button button_1
row 100
col 100
parent form_1
caption "New Button"
action msginfo("You have pressed the new button!")
end button
Form_1.Button_1.release()
Thanks a lot friend
I should have checked it
With best regards.
With best regards.
- Alex Gustow
Yes - I'm using this technique in my apps often (in one situation I need one group of controls, in another - another group etc.) It's very easy and useful trick.
For example - I use it when I create controls in "auto-zoom'ed" apps (I wrote about this some time ago): I define main window in Main() function, and define controls into this window only after initialization of main window (in function called from ON INIT clause).
And it´s the only way to define controls when you don´t know if or how many you will need during runtime.Alex Gustow wrote:Yes - I'm using this technique in my apps often (in one situation I need one group of controls, in another - another group etc.) It's very easy and useful trick.
Then you can work with the &-operator to define:
FOR nPos := 1 TO xx // xx was calculated during runtime
@ 10, 20*nPos ;
LABEL &("LabelY" + STR( nPos, 4, 0 ) ) ;
PARENT Form_5 ;
VALUE STR( nPos, 2 ) ;
WIDTH 20 HEIGHT 10 ;
FONT "ARIAL" SIZE 07
- Alex Gustow
Yes - I use exactly this way very often in such cases.Ricci wrote:Then you can work with the &-operator to define:
