Hi friends,
I want to know how to use the dll files instead of using static libraries.
Let me tell my use case.
I have the latest sqlite3.dll file. Instead of using the libsqlite3.a, how to use the external sqlite3.dll file? I am not bothered to send my application along with this dll file.
How to use external dll?
Re: How to use external dll?
Hi Rathinagiri,Rathinagiri wrote: ↑Fri May 19, 2023 4:01 am Hi friends,
Please take a look at the attached Sqlite example for HMG 3.6 (64-bit).
The archive contains the necessary sources, dll and make files along with a working executable file.
Note that you must copy the libsqlite3.a library file to your \hmg.3.6\harbour64\lib\win\mingw64\ folder
as a first step to correctly compile this example.
- sqlite-dll-64.zip
- (2.7 MiB) Downloaded 238 times
Thank you very much for the sample Grigory. This is how I use it as of now for all my applications.
What I am asking is exactly opposite of this. ie., is there anyway to avoid libsqlite3.a and use the dll file instead? Like libmysql.dll
Dear Rathi,Rathinagiri wrote: ↑Fri May 19, 2023 4:52 pm This is how I use it as of now for all my applications.
I seem to have expressed myself unclearly.
The provided library libsqlite3.a is similar to libmysql.dll. It was compiled using a batch file def2lib.bat.
Just try to run the application without sqlite3.dll in the same folder.
And you will see a missing DLL error message.
Wow! You are so great Grigory! Thanks a lot!
Thanks to Grigory's guidance, now, we can use SQLCipher latest version (3.4.2) to safely encrypt our entire database!
Attached is the required .dll and .a files for latest HMG 64bit!
- sqlcipher.zip
- (3.94 MiB) Downloaded 251 times
Thanks Rathi & Grigory !
