HMG 3.6 (64 bit version)
Dear HMG friends,
Thanks to Girigory a default 64 bit only version of HMG is created and I am sharing the setup file for your testing and comments.
Please download from here.
Re: HMG 3.6 (64 bit version)
Thanks Rathi/Grigory,
I downloaded and executed setup file.
Do I need more ?
Please test with your existing projects.
If you are using IDE, please select to use IDE for 64 bits. Otherwise use the build64.bat file to build. Any discrepancy please report.
luisvasquezcl
Post by luisvasquezcl »
Hola a todos,
Descargando... cualquier problema informo.
Saludos cordiales,
Luis Vásquez.
Rathi,
I get this error
_temp.rc:163: unrecognized escape sequence
Harbour 3.2.0dev (r2304211101)
Copyright (c) 1999-2023, https://harbour.github.io/
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/Users/Serge/AppData/Local/Temp/hbmk_puyxgw.dir/DB_GEN_CAP.o:DB_GEN_CAP.c:(.data+0x6d10): undefined reference to `HB_FUN___HBEXTERN__HBSSL__'
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/Users/Serge/AppData/Local/Temp/hbmk_puyxgw.dir/DB_GEN_CAP.o:DB_GEN_CAP.c:(.data+0x76d0): undefined reference to `HB_FUN_TMYSQLSERVER'
hbmk2[DB_GEN_CAP]: Error: Running linker. 1
gcc.exe C:/Users/Serge/AppData/Local/Temp/hbmk_puyxgw.dir/DB_GEN_CAP.o C:/Users/Serge/AppData/Local/Temp/hbmk_puyxgw.dir/hbmk_1twlvq.o P:/hmg.3.0.44/DB_GEN/_temp.o    -pthread  -static-libgcc  -static-libstdc++  -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lwinmm -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib   -Wl,--end-group -oDB_GEN_CAP.exe  -LP:/hmg.3.6/harbour64/lib/win/mingw64 -L"P:/hmg.3.6/lib-64"
hbmk2: Hint: Add option 'hbmysql.hbc' for missing function(s): TMySQLServer()
hbmk2: Hint: Add option 'hbssl.hbc' for missing function(s):
       __HBEXTERN__HBSSL__()
I have hbssl.hbc in my HBC file but IDE deletes it every time...!
luisvasquezcl
Hello everyone,
Thanks for the new version.
I'm testing the new version, everything works fine but the memory problem continues, as you open modules the application increases memory consumption and does not release it.
Is there any possibility to correct this error?
kind regards
Hola a todos,
Gracias por la nueva versión.
estoy probando la nueva version, todo funciona bien pero sigue el problema con la memoria, a medida que vas abriendo modulos la aplicación aumenta el consumo de memoria y no la libera.
Hay alguna posibilidad de corregir ese error?
saludos cordiales
I can't link my project because I'm using LetoDBF library. I should compile it in 64 bit, but I don't know how to do it...
tonton2
Post by tonton2 »
merci beaucoup pour cette délicieuse nouvelle Merci a vous deux :Merci Rathi - Grigory, et bien sûr a toous les HMG_ISTES
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
huiyi_ch
Post by huiyi_ch »
Rathinagri
I am a Chinese mainland user, for other reasons, cannot access https://drive.google.com website, can I put HMG 3.6 (64 bit version) on this site to facilitate download.
