Form with paging
dragancesu
DBs Used: DBF, MySQL, Oracle
Form with paging
Post by dragancesu »
The big problem is when the table has many rows, how to show it and make it fast
I found data for countries and cities of the world, 250 countries and 94000 cities, I think it is good for example
Download, unzip, then build demo.prg
I know the example is simple, if you have time take a look and write a comment so it could be better
paging.zip
(739.59 KiB) Downloaded 1344 times
Re: Form with paging
Hola Dragan :
yo use en mi POS (point of sale) la identificacion GS1 de cada pais para ubicar de que pais pertenece ese producto con el prefijo y asi poder mostrar su origen con un icono de la bandera del pais... nose como concatenar las cuidades a esos paises .
When the number or rows/records are huge, use VirtualGrid.
Virtual grid is a great solution!
ASESORMIX
Post by ASESORMIX »
Os recomiendo este ejemplo, puede ayudar a muchos
PRUEBA.zip
(1.71 MiB) Downloaded 1281 times
Virtual GRID works with arrays or only with DBF?
I seldom work with DBF: always MySQL.
