change "Section" in CONFIG.INI
if i add "Section" in INI i have to delete old INI else change will not appear in INI :(
it have to do with
   IF !FILE( "Config.ini" )
      // write File
      SET Section ...
      // read File
      GET ...
is there a Way to enhance INI "Section" without delete INI :?:
Re: change "Section" in CONFIG.INI
Jimmy,
This should work:
   cDNLPath := 'c:\'
   cUPLPath := 'c:\'
   BEGIN INI FILE ( "c:\test\dirselect.ini")
      SET SECTION "General" ENTRY "DNLPath" to cDNLPath
   END INI
