Migration from HMG to HMG Minigui
tonton2
Re: Migration from HMG to HMG Minigui
Post by tonton2 »
AUGE_OHR wrote: Wed Feb 01, 2023 11:35 pm hi,
tonton2 wrote: Wed Feb 01, 2023 6:28 pm is it different whith file.rc of HMG.3.4.4
if try instead of
use
#define RCDATA 10
Merci mon ami je vais essayer
Thank you my friend ,I'm tried it
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
tonton2
Post by tonton2 »
Bonjour ,
maitenant j'ai supprimé le fichier.rc(GESTION.RC) , et les bitmap sont dans le même répertoire et ça a l'air d'avancer, voila les nouvelles erreurs qui apparaisse.
Hello ,
Now I have deleted the file.rc(GESTION.RC), and the bitmaps are in the same directory and it seems to be progressing, here are the new errors that appear.
Y.TABET
Pcmodula
Post by Pcmodula »
tonton2 wrote: Fri Feb 03, 2023 11:08 am Bonjour ,
Hello ,
d'après ce que je vois, il vous manque quelques lib. et le compilateur ne parvient pas à assembler le programme
Salut.
Pcmodula
you are missing SQLite and HPDF LIB
show us you *.HBP or *.HBC which LIB you are using
which BCC Version are you using :?:
! Note : LIB must be "match" Compiler Version else you "might" get Problem
tonton2
Post by tonton2 »
Bonjour ,
j'utilise Borlanc BCC58 et extended edition 23 , et voici ci joint *.hbb et *.hbc
Où puis je avoir ces SQLITE et et autres
I use Borlanc BCC58 and extended Edition 23 01, and here is attached *.hbb and *.hbc
Where can I get these SQLITE lib and others
Thank you for your HELP
File_HBP_HBC.rar
(596 Bytes) Downloaded 226 times
Y.TABET
tonton2
Post by tonton2 »
hbmysql.lib and libmysql.lib are in th directory c:\minigu\harbour\lib
Y.TABET
you are using Sqlite 3, or :?:
hbMYsql.lib and libMYsql.lib are for MYsql :!:
have a look at Sample c:\minigui\Samples\Sqlite_2
it include demo.hbc
libs=sqlite3 hbsqlit3 winreport hbhpdf libhpdf png hbzebra
seems it use those LIB which you need
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi !
While HMG have libs. BossTaurus, HPDF, HbZebra, etc. for default... HMGex no...
take a look in: C:\hmg.3.4.4\INCLUDE\hmg.ch ( -> MiniGUI.ch) and C:\MiniGUI\Include\minigui.ch
you can put include manually this libs. in Main.prg and .prg's who need them, just below #include <minigui.ch>
tonton2
Post by tonton2 »
Claudio Ricardo wrote: Sun Feb 05, 2023 5:57 pm Hi !
thank you I'm goin to try your method
Y.TABET
tonton2
Post by tonton2 »
AUGE_OHR wrote: Sun Feb 05, 2023 12:02 am hi,
it include demo.hbc
Je crois qu'il vaudrais mieux refaire tout mon programme depuis le debut , c'est a dire passer de hmg.3.4.4 vers hmg extended module par module .
Merci a tous de votre aide
Good evening
I believe that it would be better to remake all my program from the beginning, ie to pass from hmg.3.4.4 towards hmg extended module by module.
Thank you all for your help :D
Y.TABET
