Migration from HMG to HMG Minigui
tonton2
Re: Migration from HMG to HMG Minigui
Post by tonton2 »
ou puis je trouver les codes d'erreurs comme ici c''est Error E0030 merci
where can I find the error codes like here it's Error E0030 thank you
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
E0030 is wrong syntax
you have
Standard Syntax (xBase Style):
DEFINE WINDOW <WindowName>
AT <nRow> ,<nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ VIRTUAL WIDTH <nVirtualWindth> ]
[ VIRTUAL HEIGHT <nVirtualHeight> ]
[ TITLE <cTitle> ]
[ ICON <cIconName> ]
[ MAIN | CHILD | MODAL | SPLITCHILD | PANEL ]
[ NOSHOW ]
[ TOPMOST ]
[ NOAUTORELEASE ]
[ NOMINIMIZE ]
[ NOMAXIMIZE ]
[ NOSIZE ]
[ NOSYSMENU ]
[ NOCAPTION ]
[ CURSOR <CursorName> ] ...
or
Alternate Syntax:
ROW <nRow>
COL <nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
WINDOWTYPE MAIN | CHILD | MODAL | SPLITCHILD | STANDARD | PANEL
[ VIRTUALWIDTH <nVirtualWindth> ]
[ VIRTUALHEIGHT <nVirtualHeight> ]
[ TITLE <cTitle> ]
[ VISIBLE <lValue> ]
[ TOPMOST [<lValue>] ]
[ AUTORELEASE <lValue> ]
[ MINBUTTON <lvalue> ]
[ MAXBUTTON <lValue> ]
[ SIZABLE <lValue> ]
[ SYSMENU <lValue> ]
[ TITLEBAR <lValue> ]
but you mix this syntax, look line SYSMENU
you must make decision: Strandad or Alternate syntax
tonton2
Post by tonton2 »
dragancesu wrote: Wed Jan 25, 2023 2:57 pm E0030 is wrong syntax
you have
AT <nRow> ,<nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ TITLE <cTitle> ]
[ NOSHOW ]
[ TOPMOST ]
[ NOAUTORELEASE ]
[ NOMINIMIZE ]
[ NOMAXIMIZE ]
[ NOSIZE ]
[ NOSYSMENU ]
[ NOCAPTION ]
or
Alternate Syntax:
ROW <nRow>
COL <nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ TITLE <cTitle> ]
I understand , i'm going to fix it step by step Thank's
Y.TABET
step by step ! That's what I did too!
tonton2
Post by tonton2 »
Bonsoir,
can you to do this example in HMG.3.4.4 to HMG extended Minigui Thank's
@ 40,10 GRID Grid_Creance_Cli_NEW ; // 10,10
WIDTH 720 ; // 770 ;
HEIGHT 420 ;
HEADERS {'Gestion ','Montant TTC ','T.v.a','Avances Esp','Autres Avances','Representation', 'Solde'} ;
WIDTHS {70,110,100,110,110,100,110};
EDIT ;
VALUE { 1 , 1 } ;
justify {0,1,1,1,1,1,1};
COLUMNCONTROLS { aCrCtrl_1 , aCrCtrl_2 , aCrCtrl_3 , aCrCtrl_4 , aCrCtrl_5 , aCrCtrl_6, aCrCtrl_7 } ;
ROWSOURCE "GEST_ANT" ;
COLUMNFIELDS { 'Gestion' , 'Mont_ht' , 'Mont_Tva' , 'AvancEsp' , 'AutreAva', 'Represent' , 'SoldeAva'} ;
ALLOWAPPEND ;
ALLOWDELETE ;
DYNAMICDISPLAY { creaDisplay_1 , creaDisplay_2 , creaDisplay_3 , creaDisplay_4 , creaDisplay_5 , creaDisplay_6 , creaDisplay_7 } ;
it's working (I changed GRID to BROWSE)
Y.TABET
tonton2
Post by tonton2 »
tout se compile bien avec compile.bat ,aucune erreur n'est signalée par DOS ,mais pas de fichier en exe ,Demain je verrais ça
Bonne nuit a tous .
everything compiles fine with compile.bat, no error is reported by DOS, but no exe file, tomorrow I will see that
Good night all
Y.TABET
tonton2
Post by tonton2 »
Bonsoir,
En compilant avec IDE Minigui ==> (Error Gestion.Rc 35 33: Invalid bitmap format),
et par "compile.bat" , j'ai le même problème a ci joint l'image de la compilation.
est ce un problème de fichier.rc.
est il différent du fichier de HMG.3.4.4.
By compiling with IDE Minigui ==> (Error Gestion.Rc 35 33: Invalid bitmap format),
and by "compile.bat" , I have the same problem attached ( the image of the compilation.)
is this a file.rc problem.
is it different whith file.rc of HMG.3.4.4
gestion.rar
(472 Bytes) Downloaded 356 times
Y.TABET
gfilatov
Post by gfilatov »
tonton2 wrote: Wed Feb 01, 2023 6:28 pm Bonsoir,
It seems that your bitmap image in Gestion.Rc file is not like to the Borland resource compiler.
You have two options now:
1) replace this bitmap with another one;
2) replace BCC compiler with MinGW C compiler which used in HMG.3.4.4.
What help do you need :?:
tonton2 wrote: Wed Feb 01, 2023 6:28 pm is it different whith file.rc of HMG.3.4.4
if try instead of
use
#define RCDATA 10
tonton2
Post by tonton2 »
gfilatov wrote: Wed Feb 01, 2023 7:38 pm
mon programme fonctionne très bien dans HMG.3.4.4 , ,maintenant j'ai migré vers HMG EXTENDED (MINIGUI) , tout va bien sauf gestion.rc.
comment compiler avec Borland ce fichier.
encore merci beaucoup de votre précieuse aide
my program works fine in HMG.3.4.4, now i migrated to HMG EXTENDED (MINIGUI), everything is fine except management.rc.
how to compile with Borland this file.
Thanks again for your precious help.
Compile.rar
(383 Bytes) Downloaded 350 times
Y.TABET
