FROM XML TO DBF
tomtagaris
FROM XML TO DBF
Post by tomtagaris »
I have e file xls
How can I extract its contents and pass them to a DBF file
Thanks for help
Request.zip
(105.12 KiB) Downloaded 295 times
HGAutomator
Re: FROM XML TO DBF
Post by HGAutomator »
Hi Tom,
I searched around for xml to dbf code, but so far could only find a dbf_to_xml routine.
I used the commercial CoolUtils XML converter, to generate the attached.
Converted_XML.zip
(608.58 KiB) Downloaded 324 times
HGAutomator
Re: FROM XML TO DBF
Also this, from WhiteRock software. It's a single dbf as opposed to several in the last sample.
It looks like there are some string conversion problems, perhaps related to Unicode.
WhiteRock_XML_to_DBF.zip
(79.49 KiB) Downloaded 294 times
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: FROM XML TO DBF
Post by Claudio Ricardo »
Hi... Try open with LibreOffice Calc (Similar to MsOffice Excel but open source and free !)
fix column width, and save to " dBase .dbf " I always do it, never fail !
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: FROM XML TO DBF
Post by dragancesu »
XML is an interesting format, basically an TXT file that you read as text
but you can see the structure in it, in this case the record is INVOICE
    <invoice>
      <uid>767DE28C469B8930A2262FC9660FBC93E5E6CB08</uid>
      <mark>400000000090274</mark>
      <issuer>
        <vatNumber>300950992</vatNumber>
        <country>GR</country>
        <branch>0</branch>
      </issuer>
      <counterpart>
        <vatNumber>029690710</vatNumber>
        <branch>0</branch>
        <address>
          <postalCode>25001</postalCode>
          <city>ΚΑΛΑΒΡΥΤΑ</city>
        </address>
      </counterpart>
      <invoiceHeader>
        <series>0</series>
        <aa>7465</aa>
        <issueDate>2020-10-11</issueDate>
        <invoiceType>1.1</invoiceType>
        <vatPaymentSuspension>false</vatPaymentSuspension>
        <currency>EUR</currency>
        <movePurpose>1</movePurpose>
      </invoiceHeader>
      <paymentMethods>
        <paymentMethodDetails>
          <type>5</type>
          <amount>0</amount>
        </paymentMethodDetails>
      </paymentMethods>
      <invoiceDetails>
        <lineNumber>1</lineNumber>
        <netValue>96.6</netValue>
        <vatCategory>2</vatCategory>
        <vatAmount>12.56</vatAmount>
      </invoiceDetails>
      <invoiceSummary>
        <totalNetValue>96.6</totalNetValue>
        <totalVatAmount>12.56</totalVatAmount>
        <totalWithheldAmount>0</totalWithheldAmount>
        <totalFeesAmount>0</totalFeesAmount>
        <totalStampDutyAmount>0</totalStampDutyAmount>
        <totalOtherTaxesAmount>0</totalOtherTaxesAmount>
        <totalDeductionsAmount>0</totalDeductionsAmount>
        <totalGrossValue>109.16</totalGrossValue>
      </invoiceSummary>
    </invoice>
notepad++ displays xml nicely
the problem is that the tags are long and the dbf fields are limited to 10 characters
I think it is not difficult to write a program that will write this data into the appropriate structure
IMATECH
Re: FROM XML TO DBF
Post by IMATECH »
M., Ronaldo
By: IMATECH
Imation Tecnologia
edk
Re: FROM XML TO DBF
Post by edk »
See this tool:
XmlToPrg.7z
(3.09 KiB) Downloaded 274 times
You can generate a prg which can be helpful for parsing the xml and writing the read data to the DBF.
You can also put the read data in an array and then process its contents.
Your sample xml file contains 999 invoices, but I "don't like" the Greek city and street names written in it. The xml file is declared as UTF-8, but Greek letters appear strangely for me.
greek utf8.png (82.88 KiB) Viewed 7924 times
Re: FROM XML TO DBF
IMATECH wrote: Sat Jan 14, 2023 2:50 pm hb_mxml ! read and write XML files
is hbmxml avaiable for HMG :?:
i did found hbmxml.LIB but that is for BCC or MSVC
IMATECH
Re: FROM XML TO DBF
Post by IMATECH »
for sure:
sources
c:\hmg\harbour\contrib\hbmxml
lib
c:\hmg\harbour\lib\libhbmxml
M., Ronaldo
By: IMATECH
Imation Tecnologia
Re: FROM XML TO DBF
hi
IMATECH wrote: Sat Jan 14, 2023 11:00 pm lib
found it, thx
