add "temporary" TAG in Index ?
i want to create a temporary Index TAG and "add" it to existing CDX
i "think" i have to use ADDITIVE when create new Index TAG, but how to "remove TAG" :?:
Re: add "temporary" TAG in Index ?
hi
new Idea
ORDLIST()
but it fail when compile :o
harbour have ORDLISTADD() and ORDLISTCLEAR() but no ORDLIST() :(
under Xbase++ i have ORDLIST() so i can ask
   ? LEN(ORDLIST())
how under harbour / HMG to find out how man Index are SET to working DBF :?:
Maybe this...
Description
DBINFO() retrieves information about a database file. By default, this
function operates on the currently selected work area. It can be made
to operate on an unselected work area by specifying it within an aliased
expression.
Examples
. The following examples return work area information:
#include Dbinfo.ch
? DBINFO(DBI_GETHEADERSIZE) // Same as HEADER()
? DBINFO(DBI_LASTUPDATE) // Same as LUPDATE()
? DBINFO(DBI_GETRECSIZE) // Same as RECSIZE()
? DBINFO(DBI_FILEHANDLE) // DOS file handle for
// the current database
// file
Files Library is CLIPPER.LIB, header file is Dbinfo.ch.
MY SAMPLE...
FUNCTION CKAliasBD()
    LOCAL cAliasAct:=Alias(), i1, i2, cPso:=""
    FOR i1=1 TO 150   // Bases de Datos abiertas
        cAlias:=ALIAS( i1 )
        IF LEN( cAlias ) > 0
            SELE (cAlias)
            FOR i2:= 1 TO FCOUNT() ; cPso+=DBFIELDINFO(DBS_TYPE, i2) ; NEXT
            F_Debug.G_Dbs.AddItem( { DBINFO(DBI_FULLPATH)+IF( "M" $ cPso, "  +DBT", "" ), ;
                                     DBINFO(DBI_ALIAS),DBINFO(DBI_DBFILTER), ;
                                     &cAlias.->(ordSetFocus()), ;
                                     TRANSFORM( ( (RECSIZE()*LASTREC()) + HEADER() + 1), "99,999,999"), ;
                                     StrValue(DBINFO(DBI_GETLOCKARRAY)), StrValue(DBINFO(DBI_ISFLOCK))  ;
            cPso:=""
    SELE (cAliasAct)
RETURN( Nil )
SALINETAS24
Post by SALINETAS24 »
AUGE_OHR wrote: Tue Nov 01, 2022 12:41 am hi,
Hola AUGE_OHR, yo trabajo así.
		SELECT fichero
                // Genero nombre aleatorio
                cFileInd:="I"+cStrZero(INT(HB_RANDOM(1,99999)),5)
                // Elijo campo para nuevo indice
                cb:=FieldName(3)
                // Creo indice por el 3er campo
                INDEX ON &cB TO (cFileInd) ADDITIVE
Ya puedo trabajar usando DBSETORDER.
Para eliminarlo
		(cAlias)->(ORDDESTROY(cFileInd))
		FERASE(cFileInd)
Vamos con una cervecita fresquita!!
franco
Post by franco »
Maybe,
INDEX ON recno() TO (cFileInd) ADDITIVE
All The Best,
Franco
Canada
edk
Post by edk »
AUGE_OHR wrote: Tue Nov 01, 2022 12:53 am hi
new Idea
ORDLIST()
   ? LEN(ORDLIST())
For n := 1 To OrdCount()
  msgdebug ( n, OrdName( n ), OrdKey( n ), OrdBagName ( n ) )
Next
thx all for Answer.
i have test temporary Index and "other" Concept when "search" in Forum Message.
FILTER or Index is like Online where you "just" get "Result"
but often you need hole Thread which include the Message to understand "hole Story"
i do have, on right side, Window for "Thread-Error" when download and also use for Attachment
now i use same Style for "FILTER" and present "Result" on right side
when navigate on right side it will "sync" Main so i can read Message.
i use Index TAG "DUOECHECK" which does sort Thread-No so i can "see" hole Thread
here last Version of Modul SETFILTER.PRG
you need to delete all SET FILTER in ChangeFilter() except for Radio-Button
SETFILTER_056.ZIP
(2.83 KiB) Downloaded 226 times
tonton2
Post by tonton2 »
Bonjour voila le nouveau OuvrirFbf
/* I want to create of the Caisse_Extend file.ntx for all items in the Caisse_Extend->Field_Name
// This form
Use Caisse
copy structure extended to Caisse_Extend
use CAISSE_EXTEND
DO WHILE NOT EOF()
for n=1 to HMG_len(CAISSE_EXTEND)
index on Caisse_Extend->Field_Name to xItem+str(n)
xitem =: ????str(n) // Xitem+","+xitem
next
skip
ENDDO
set index to ( Xitemstr+(n)+","Xitemstr+(n) for n=1 to HMG_len(CAISSE_EXTEND)
OUVRIR_DBF.rar
(1.77 KiB) Downloaded 194 times
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
SALINETAS24
tonton2 wrote: Tue Jan 24, 2023 9:08 pm Bonjour voila le nouveau OuvrirFbf
Hola, no entiendo bien lo que quieres hacer. Creo entender que quieres crear un indice para cada campo de la DBF. Este código que te paso no lo he probado, igual tienes que ajustarlo pero en principio debera crearte un Indice para cada uno de los campos de la DBF.
PROC CreaIndices
LOCAL aExtructura, nFor, cCampo, cIndice, Cais, cBase, cIndice
	Cais:=(cDossier+"\"+cFichier)
	cBase:=cDossier+"\Ind"
	USE &cais
	aExtructura:=DBSTRUCT()
	FOR nFor=1 TO LEN(aExtructura)
		cCampo :=FIELNAME(nFor)
		cIndice:=cBAse+StrZero(nFor,2)
		INDEX ON &cCampo TO (cIndice) ADDITIVE
tonton2
Post by tonton2 »
SALINETAS24 wrote: Wed Jan 25, 2023 8:03 pm
PROC CreaIndices
	USE &cais
Bonjour,
OUI, c'est ça que je veux ,Creer pour chaque champ un fichier ntx .
merci pour votre code je vais l'essayer
Buenos dias,
SÍ, eso es lo que quiero, crear un archivo ntx para cada campo.
gracias por tu codigo lo intentare
Y.TABET
