HMG Forum "Codebox" Reader
Re: HMG Forum "Codebox" Reader
did "translate" via Google still work :?:
i got oHttp:Status Error 429 ... what does it mean
but i can download Message from Forum so i guess it is not a "MSXML2.ServerXMLHTTP" Problem, or :idea:
Jimmy,
Google: The HTTP 429 Too Many Requests response status code indicates the user has sent too many requests in a given amount of time ("rate limiting")
Put some
   hb_idleSleep( 1.0 )
in your code!
hi Serge,
YES, you are right
i made too much Request to Google Translate which are "limited" when not pay for API Key
as i have no more Idea / Problem so i release latest Source and EXE (32 Bit)
// 28.09.2022 v0.4.5 IsInternet() on other Place
// 03.10.2022 v0.4.6 ReleaseAllWindows()
// 04.10.2022 v0.4.7 lTranslate
// 06.10.2022 v0.4.8 RELEASE Source and EXE
since using ReleaseAllWindows() App will not "hang" in Taskmanager any more
Google Translate are "limited" and will give Error 429 when request too much
when lTranslate = .F. it will show no Translation until re-start App
! Note : you need to reset Router to get a new IP to "fake" Google
i have include *.RC as Sample but NO Image or Icon (possible Copyright Problem)
FORUMHMG_74.zip
EXE 32 Bit
(1.83 MiB) Downloaded 406 times
FORUM_SOURCE_74.ZIP
HMG Source
(47.88 KiB) Downloaded 358 times
BUG :
Info2 for (File) Attachment are not shown when IMAGE was before
DLFORUM.PRG line 732
731	REPLACE FORUM->INFO1 WITH "Have Image"
732     // LOOP
FORUMHMG.PRG line 1734
1733	REPLACE FORUM->INFO1 WITH "Have Image"
1734	// LOOP
please change lines with LOOP and run "clean all from HTML"
next Version : download (all) Attachment from Forum
v0.5.3.81
New:
// 07.10.2022 v0.4.9 GetAllAttachment() download form Forum
// !isdir() -> add \DOWNLOAD Folder
// 08.10.2022 v0.5.0 GetAttachment() : click on LABEL Info2
// 09.10.2022 v0.5.1 Attachment Download Time left, Progressbar
// 10.10.2022 v0.5.2 CHECKBOX : Override Attachment
// 11.10.2022 v0.5.3 RELEASE EXE : download Attachment
FORUMHMG_81.zip
(1.83 MiB) Downloaded 384 times
new Version to download (File) Attachment from Forum
in Menu you will find new MenuItem "Download Attachment" ( look at CHECKBOX "Override Attachment")
when LABEL Info2 is "green" you can click on it
HMG Forum have about 2673 Files and need 1.700 MB (!) and take about 35 min to download all Attachment
when click on "green" LABEL you will get Attachment only from "this" Message
! note : if possible it will download "fresh" Version
there are many Files call TEST.ZIP ... but only "latest" Version is "valid"
when got a Error while Download Attachment you will get Error Log Window.
now do NOT press "re-read" Button as it does NOT download Attachment
click on Item in Listbox -> will navigate to Message
now click on "green" Info2 Label to download Attachment
than use next Item on Listbox
to "open" Attachment i use
   SHELLOPENFILE(cFile)
it will open ZIP with Explorer but for RAR or 7z File Windows will ask for App to open (if not installed)
HMG, Xbase++ and Express++ have Attachment but FiveWin does not allow Attachment
p.s. only File Attachment with this Extension
IF ".zip" $ LOWER( cFile ) .OR. ;
   ".rar" $ LOWER( cFile ) .OR. ;
   ".7z"  $ LOWER( cFile ) .OR. ;
   ".prg" $ LOWER( cFile )
not a BUG ... just missunderstood
STATIC PROCEDURE FindReplRTFProc( cFind )
LOCAL lMatchCase      := .T.
should be
LOCAL lMatchCase      := .F.
here Modul to download Attachment
DLATTACH.ZIP
(3.27 KiB) Downloaded 366 times
add in Menu
   MENUITEM "Download &Attachment" IMAGE "MYATTACHMENT" ACTION GetAllAttachment()U
add to
   DEFINE LABEL Label_2INFO
      ACTION GetThisAttachment()
STATIC PROCEDURE GetThisAttachment()
LOCAL cAttach := FORUM.Text_2INFO.Value
   IF !EMPTY( cAttach )
      ORDSETFOCUS( "DUPECHECK" )
      ResetFiles()
      GetAttachment()
      DoGetFiles( .T. )
      ORDSETFOCUS( "MSGDATE" )
BUG :
Msg. No for LINK
when press LINK Button i want to go to Original Message but it is wrong Msg. No :o
a "New" Thread begin with 0 (zero) not with Msg. No. 1
in POPUP Menu we have : "clean all from HTML" which also "re-number" Message
other are in "Download" which i have to look for a Solution, sorry
next BUG
when use FILTER and have "Result-Box" on right Side and call AGAIN to set new FILTER it will not show new Result :o
you have to close "Result-Box" before set new FILTER which will open new "Result-Box"
change Code
PROCEDURE DoSetFilterTo( nOrder )
LOCAL cTitle, nPosi
   SELECT 1
   IF !USED()
      MsgInfo( "need DBF" )
   IF isWindowDefined( "DoShowFilterWin" )
      Domethod("DoShowFilterWin","Release")
about nMsgNo
look into FORUMHMG.PRG and DLFORUM.PRG that nMsgNo start with 0
change in FORUMHMG.PRG
DEFINE BUTTON Button_Link
   ACTION DoShellLink()
STATIC PROCEDURE DoShellLink()
LOCAL lRet
   IF FORUM->NOOFMSG = 0
      lRet := SHELLOPENFILE( TRIM( FORUM->LINK )  )
      lRet := SHELLOPENFILE( TRIM( FORUM->LINK ) + "&start=" + LTRIM( STR( FORUM->NOOFMSG ) ) )
   IF lRet = .F.
      MsgInfo( "fail to open link " + TRIM( FORUM->LINK ) )
