Any samples to retrieve a nested array of folders and files?
HGAutomator
Post by HGAutomator »
I've been working on this for several days, and am getting nowhere.
hb_DirScan seems to be the closest function to returning what I want. But it returns a flat array.
I'm looking for something that will use Directory() recursively, or some other function and result with a nested array that matches the directory structure?
Just the folder and filenames, not the sizes or attributes.
Re: Any samples to retrieve a nested array of folders and files?
your "wanted" Array look like a TREE using XML Format
i "think" i have seen XML -> TREE "somewhere" ... have to search for it
HGAutomator
Auge_Ohr,
Thanks, but no. I need specifically a nested array. Not xml, although that might be needed in the future.
AUGE_OHR wrote: Mon Oct 03, 2022 9:23 pm hi,
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
dir /s /b > files.txt
As Dragan say: dir /s /b > files.txt
Is the easiest way out. Just examing files.txt !
HGAutomator
Ok, thanks everyone. I think the short answer is no, there isn't an existing module that converts a folder structure to an equivalent nested array.
I'll dope this out, with time, and share it here when it's done.
Hola a todos :
hace muchisimo en el grupo trabajamos con objectos de windows y creo la solucion esta en usar "Scripting.FileSystemObject"
no ando muy memorioso pero dejo un ejemplo nose si funcional ya que no tengo HMG instalado en mi nueva computadora :?
Public oFSO, oFile, oFolder
oFSO    := createobject("scripting.Filesystemobject")
oFolder := oFSO.getfolder("c:\HMG.3.5")
for each oFile in oFolder.oFiles
   ?"Name Of File : ", oFile.name
   ?"Size         : ", oFile.size
   ?"Date created : ", oFile.DateCreated
   ?"Last modified: ", oFile.DateLastModified
https://hmgforum.com/viewtopic.php?f=5& ... ing#p61850
HGAutomator
Thanks Daniel,
But I already know how to do this. It returns a flat list of information.
I'm looking for a routine that returns a nested array which is structured in essentially the same way as the folders.
Anyway, I found a way to do it. I need to break from this for a few days, to prepare for a sql and .net interview. But I have a basic strategy for getting the array, and will share it on the forum after it's done.
There are existing modules that come close to this. There's one in the Xailer distribution, but it returns the info in a treeview, which isn't what I'm looking for. There's also several legacy modules that list files or directories, like XD_PICKDIR from the XDot clipper library. But they don't seem to return the directory in the format I'm looking for.
Here's an example of the type of structure I'm trying to generate. It's NOT from a folder structure, it's from a menu structure that I'm working on. But ultimately, this is the kind of nested array I'm trying to generate, from a folder and subfolders.
As I said, I'm close to a solution, and will post it when completed.
	{"Office","Excel, Word, Dummy", ;
			{"Excel",     "Microsoft Excel", {|| ExecuteApp( Chr(34) + "c:\Program Files (x86)\Microsoft Office\Office12\Excel.exe" + Chr(34) ) }},;
			{"Word",     "Microsoft Word", {|| ExecuteApp( Chr(34) + "c:\Program Files (x86)\Microsoft Office\Office12\WinWord.exe" + Chr(34)) }},;
			{"Dummy", "Dummy Menu Item", {||qout("Third SubItem from First") } } ;
	{ "Utilities","Temp folder, Second SubItem, Third SubItem", ;
			{"Temp folder","Generate Working folder", {||popupstring("Enter anything")}},;
			{"Second SubItem", "Second SubItem from Second",  {||qout("What the...?")}},;
			{"Third SubItem", "Third SubItem from Second",  {||qout("Third SubItem from Second")}} ;
	{ "Other Apps","PDF Viewer, Notepad, NotePad++, Dummy", ;
			{"Sumatra", "Sumatra PDF Viewer", {|| ExecuteApp( "C:\PortableApps\SumatraPDFPortable\SumatraPDFPortable.exe" ) }},;
			{"Notepad", "Run Notepad", {|| ExecuteNotepad() }},;
			{"Notepad++",     "Run Notepad++", {|| ExecuteApp( Chr(34) + "g:\PortableApps\Notepad++Portable\Notepad++Portable.exe" + Chr(34)) }},;
			{"Thunderbird", "Thunderbird Portable", {|| ExecuteApp( "G:\PortableApps\ThunderbirdPortable\ThunderbirdPortable.exe" ) }},;
			{"Dummy", "Dummy Menu Item", {||qout("Dummy Menu Item")} } ;
	{"Clipboard","Send to Clipboard?.txt, Manipulate Clipboard, Common Strings", ;
			{ "SendToFile", "SendToFile1, SendToFile2", ;
					{"SendToFile1","Send Contents of Clipboard to C:\Clips\Clipboard1.txt", {|| CopyClipboardToFile1() } },;
					{"SendToFile2","Send Contents of Clipboard to C:\Clips\Clipboard2.txt", {|| CopyClipboardToFile2() } } ;
			{ "Manipulate Clipboard", "Sort, LowerCase, UpperCase, Remove Trailing Strings, Surround Clipboard list, DXXX Insert, Dummy", ;
					{"Sort", "Sort Lines in Clipboard",  {|| CopyStringToClipBoard( SortClipboardLines( GetSystemClipBoard() ) )}},;
					{"LowerCase", "Convert Clipboard to LowerCase",  {|| CopyStringToClipBoard( Lower( GetSystemClipBoard() ) ) }},;
					{"UpperCase", "Convert Clipboard to UpperCase",  {|| CopyStringToClipBoard( Upper( GetSystemClipBoard() ) ) }},;
					{"Remove Beg/End", "Removing Beginning and Ending Strings",  {|| CopyStringToClipBoard( RemoveRemainingCharacters( RemoveFromStringUpTo( GetSystemClipBoard(), "[![CDATA[" ), "]]></ns1" ) ) }},;
					{"Surround", "Prefix and Afix each String in a List",  {|| CopyStringToClipBoard( SurroundLinesWithCustomStrings( GetSystemClipBoard(), 'BEFORE', 'AFTER' ) ) }},;
					{"DXXX INSERT", "Generate INSERT Sql for DXXX License list", ;
					{|| CopyStringToClipBoard( SurroundLinesWithCustomStrings( GetSystemClipBoard(), ;
					"INSERT INTO DXXX_LIC.[dbo].[LicenseTBL] ( [IsActive], [CreatedDate], [CreatedBy], [ModifiedDate], ;
					[ModifiedBy], [LicenseId],[ReprintRequestUser], [ReprintRequestDate] ) VALUES ( 1, GETDATE(), 'SYSTEM', GETDATE(),'SYSTEM', ;
					( SELECT LId FROM Licenses WHERE LNumber = '"  , ;
					"' ), 'SYSTEM', GETDATE() );" + Chr(59) ) ) }},;
			{ "Common Strings", "My Email, Date, Function Doc, Dummy", ;
					{"Email", "My email XXXXX@gmail.com - to ClipBoard",  {|| CopyStringToClipBoard( "XXXXX@gmail.com" ) } },;
					{"Date", "Today MM/DD/YYYY",  {|| CopyStringToClipBoard( hb_DtoC(DATE(), 'MM/DD/YYYY' ) ) } },;
					{"Function Doc", "Generate Function Documentation",  {|| CopyStringToClipboard( GenerateFunctionDocumentation( "ThisFunction" ) ) } },;
					{"Dummy", "Dummy Menu Item",  {||qout("Dummy Menu")}}
			{"Dummy SubItem", "Dummy SubItem from Second",  {||qout("Fourth SubItem from Second")}},;
			{"Fifth SubItem", "Fifth SubItem from Second",  {||qout("Fifth SubItem from Second")}}
	{ "Web Searches", "Google Search with Clipboard, DuckDuckGo Search with Clipboard, WolFram Alpha, Dummy", ;
				{"Google Search", "Google Search with Clipboard",  {|| GoogleSearch( GetSystemClipboard() ) } },;
				{"DuckDuckGo", "DuckDuckGo Search with Clipboard",  {|| DuckDuckGoSearch( GetSystemClipboard() ) } },;
				{"Wolfram Alpha", "Wolfram Alpha Search with Clipboard",  {|| WolframAlphaSearch( GetSystemClipboard() ) } },;
	{ "TODO","Generate, Insert, Current, List, DONE, Third Subitem", ;
			{"Generate","Generate Today's TODO XXX_DAILY_DDMMYYYY.TXT file", {||qout("In Development") }},;
			{"Insert","Insert TODO item", {||qout("In Development") }},;
			{"Select", "Select Current TODO item",  {||qout("In Development") }},;
			{"DONE", "Set Selected TODO item to DONE",  {||qout("In Development") }},;
			{"List", "List Active TODO items",  {||qout("In Development") }},;
	{"Dummy Menu", "Dummy Menu, Dummy Menu 2, Dummy Menu 3", ;
				{"Dummy Menu", "Dummy 11, Dummy 12, Dummy 13", ;
						{"Dummy 11", "Check Today's ToDo path",  {|| GetTodayToDoFilePath() } },;
						{"Copy Open", "Copy Clipboard and Open file",  {|| CopyClipBoardToFile_and_OpenInEditor( "DTFOCM_DAILY_" + hb_DtoC( DATE(), "DDMMYYYY" ) + ".XML", "NOTEPAD" ) } },;
						{"Dummy 13", "Dummy Menu Item", {||qout("Dummy Menu Item")} } ;
				{"Dummy Menu 2", "Dummy Menu Item",  {|| DuckDuckGoSearch( GetSystemClipboard() ) } },;
				{"Dummy Menu 2", "Dummy Menu Item", {||qout("Dummy Menu Item")} } ;
danielmaximiliano wrote: Thu Oct 06, 2022 1:34 am Hola a todos :
HGAutomator
If the above nested array in the last post were from a folder, the folder might look something like the attachment.
As mentioned above, I'll post the solution when it's completed.
