Grid issues
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Grid issues
Post by Claudio Ricardo »
Hello Friends !!! Sorry for the absence... today it brings me a problem with a grid control !
And I turn for help to the wise men of the forum who have always helped me so much !!!
The first column comes from a MariaDB "Int" field... and grid add decimals only in the first col when len > 1 :o
It had never happened to me... If any have a solution I'll be very greatful !!!
Screenshot of Heidi SQL table "articulos":
And grid definition code:
			DEFINE GRID Grid_Articulos
				ROW    124
				COL    1
				WIDTH  719
				HEIGHT 517
				ITEMS { {"","","","","","","","","","","",""} }
				VALUE Nil
				WIDTHS { 50,240,80,70,80,80,50,80,80,90,30,50 }
				HEADERS {'C.Int.','Articulo','Costo $','Margen %','Neto $','Imponible $','IVA %','PVP $','Impuesto $','BarCode','V','Rubro'}
				FONTNAME "Arial"
				FONTSIZE 9
				TOOLTIP ""
				ONCHANGE Nil // Grid_Articulos_OnDblClick ()
				ONGOTFOCUS Nil
				ONLOSTFOCUS Nil
				FONTBOLD .F.
				FONTITALIC .F.
				FONTUNDERLINE .F.
				FONTSTRIKEOUT .F.
				ONDBLCLICK Nil // Grid_Articulos_OnDblClick ()
				ONHEADCLICK Nil
				ONQUERYDATA Nil
				MULTISELECT .F.
				ALLOWEDIT .F.
				VIRTUAL .F.
				DYNAMICBACKCOLOR Nil
				DYNAMICFORECOLOR Nil
				COLUMNWHEN Nil
				COLUMNVALID Nil
				COLUMNCONTROLS Nil
				SHOWHEADERS .T.
				CELLNAVIGATION .F.
				NOLINES .F.
				HELPID Nil
				IMAGE Nil
				JUSTIFY { , , GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT, , GRID_JTFY_CENTER, }
				ITEMCOUNT Nil
				BACKCOLOR NIL
				FONTCOLOR NIL
				HEADERIMAGES Nil
				ROWSOURCE Nil
				COLUMNFIELDS Nil
				ALLOWAPPEND .F.
				ALLOWDELETE .F.
				BUFFERED .F.
				DYNAMICDISPLAY Nil
				ONSAVE Nil
				LOCKCOLUMNS 0
			END GRID
martingz
Re: Grid issues
Post by martingz »
Claudi i use in grid popierty
COLUMNCONTROLS {aCtrl_3,aCtrl_3,aCtrl_2,aCtrl_2,aCtrl_7}
where
aCtrl_1:={'TEXTBOX','NUMERIC','999,999,999.99'}
aCtrl_2:={'TEXTBOX','CHARACTER'}
aCtrl_3:={'TEXTBOX','NUMERIC','9999999999'}
aCtrl_4:={'DATEPICKER','UPDOWN'}
aCtrl_5:={ 'CHECKBOX' , 'Si' , 'No' }
aCtrl_6:={ 'EDITBOX' }
aCtrl_7:={'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_8:={'TEXTBOX','NUMERIC','999.9999'}
aCtrl_9:={'TEXTBOX','NUMERIC','99999999999999999'}
Claudio Ricardo
Re: Grid issues
Gracias Martin por tu rápida respuesta pero este grid no es editable ni lleva controles es sólo para mostrar los artículos.
En el array se vé que es numérico ese item y su valor correcto pero el grid le agrega decimales no sé porqué...
Thank you Martin for your quick response but this grid is not editable nor does it have controls, it is only to display the articles.
In the array you can see that this item and its correct value are numeric, but the grid adds decimals to it, I don't know why...
Re: Grid issues
If columncontrols are not defined then it is safe to convert the values to string before adding to the grid. If you can send a sample code, we can see what to do.
jorge.posadas
Re: Grid issues
Post by jorge.posadas »
Claudio
¿Cuál es la estructura de tu tabla?
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Grid issues
Post by dragancesu »
I don't use mysql this day but database is database, try
SELECT round(code,0), articulo, cost ...
or better
SELECT truncate(code,0), articulo, cost ...
Re: Grid issues
Anyway: convert to string!
martingz
Re: Grid issues
Post by martingz »
Claudio mi grid tampoco es editable, solo lo uso para desplegar la informacion de la manera que quero, te envie todo el codigo pero mas que nada lo uso para desplegrar tipos numericos
saludos
Claudio Ricardo
Re: Grid issues
Thank you all for response !!!
I knew that the first column cannot be justified to the right but I did not know that I would have
problems if I want to load it with a numerical data...
Rathinagiri: I did that to fix it, convert the value to character, see screenshot below.
Jorge: In the second screenshot you can see part of the table opened with Heidi SQL,
the field in question is Integer and the array with which I load the grid shows it like this.
Dragancesu: It didn't work because in the array it already came in numerical format without decimals,
see first screenshot ( MsgDebug(aTable) ), but it gave me the idea of how to solve it.
Serge: Yes... the best idea... "SELECT CONVERT (Code, CHAR), Item, Cost, Margin, Etc. It Work... :P
Martin: I'm going to study your method more time... for now I found a solution...
dragancesu
Re: Grid issues
Why not
you have [ JUSTIFY <anJustifyValue> ] in GRID definition
