HMG Forum "Codebox" Reader
Re: HMG Forum "Codebox" Reader
Jimmy,
Write own date conversion, I think
- mustafa
Hi Jimmy:
possible date conversion?
https://vivaclipper.wordpress.com/2014/01/19/set-date/
#include "HMG.CH"
PROCEDURE MAIN
SET DATE FORMAT TO 'dd/mm/yyyy'
SET DATE ANSI
fecha1 := DTOC( DATE())
hora := TIME()
fecha2 := SUBSTR( fecha1 , 1, 4)
fecha3 := SUBSTR( fecha1 , 6, 2)
fecha4 := SUBSTR( fecha1 , 9, 2)
msginfo( fecha1 + CRLF + CRLF + HORA )
msginfo( fecha2 + "-"+ fecha3 + "-" + fecha4 + CRLF + CRLF + hora )
- AUGE_OHR
have forgot to say that CONFIG.INI was create
1-4 belong to MAIN Window. other are CODE Window
when Row=0 and Col=0 Windows will be CENTER
p.s. minimum Width = 800 and Height = 500
[CONFIGURATIONS]
Row=0
Col=0
Width=1024
Height=800
MemoRow=0
MemoCol=0
MemoWidth=1024
MemoHeight=800
FontSize=16
- AUGE_OHR
hi
this Version can "better" handle "other" PhpBB Forum like Xbase++ Forum or Fivewin Forum ! Note : delete CONFIG.INI as a new enhanced File will be create
- AUGE_OHR
i found a Problem to get "new" Mail of "old" Thread ...
when press F7 it will get "next" 100 Thread but there can be a "New" Message of "old" Thread
so i have to start with "old" Number ... but which "old" Number(s) ...
the only Way seems to start from 1 (it will seek for Dupe Date/Time)
is there any other Way
An interesting project! Useful to understand and get data from internet websites!
- AUGE_OHR
hi Rathinagiri,
I don't dare to publish the CODE which "analyze" a Website ... it is "quick and dirty" from an Internet Dummy
Nothing wrong with 'quick and dirty'!
- AUGE_OHR
i "think" a have a Solution to "analyze" Message
i do ADD all to aBody and sort Position
now i do search for "Marker" and than "strip" HTML from Body / CODE
why that Way :
a Message begin with '<div class="content">' and End is '</div>' ... but there are more
you also can have '<blockquote>' and '</blockquote>' ... "<code>" and "</code>" ...
while it can be many "Quote" and "Code" i had Problem before when try to work with MEMOLINE()
now it seems to work "better" as i got "more than 1 x "Quote" oder "Code" and no "Code" in "Body" any more
Thx Edward for Code to "translate" Body of Message, it work PERFECT !
for this i have add it in CONFIG.INI so please delete "old" Version
please change TranslateCP to your Codepage e.g. EN, ES, PL etc
as i have "new" Entry in HTMLSIGN.DBF please delete "old" DBF, it will be create new
have change Design with bigger "Body" Windows i will clean up Source Code and than release it here in Forum.
here new EXE p.s. most of last Work was for FiveWin Forum. for HMG Forum "old" Concept does not make those Problem
aTopic := MarkerPos( '<h3 class="first">', cMemo )
aAuthor := MarkerPos( '<p class="author">', cMemo )
IF "fivetechsupport" $ LOWER( cWorkURL )
aDateTime := MarkerPos( '»', cMemo )
aDateTime := MarkerPos( '<time datetime="', cMemo )
aContent := MarkerPos( '<div class="content">', cMemo )
aQouteIn := MarkerPos( '<blockquote>', cMemo )
aQouteOut := MarkerPos( '</blockquote>', cMemo )
aCodeIn := MarkerPos( '<code>', cMemo )
aCodeOut := MarkerPos( '</code>', cMemo )
aEndBody := MarkerPos( '<div id=', cMemo )Code: Select all
AADD( aBody, { aContent[ ii ] , "StartBody" } )
AADD( aBody, { aQouteIn[ ii ] , "QouteIn" } )
AADD( aBody, { aQouteOut[ ii ], "QouteOut" } )
AADD( aBody, { aCodeIn[ ii ] , "aCodeIn" } )
AADD( aBody, { aCodeOut[ ii ] , "aCodeOut" } )
AADD( aBody, { aEndBody[ ii ] , "EndeBody" } )
aBody := ASORT( aBody,,, { | aX, aY | aX[ 1 ] < aY[ 1 ] } )---
why that Way :
Size and Font i use same as for "Code" Window[TRANSLATEWINDOW]
TranslateRow=0
TranslateCol=1024
TranslateCP=DE
- AUGE_OHR
i last version i use "in" FILTER
which slow down BROWSE
please wait for next Version include Source Code which i have clean up
!DELETED()please wait for next Version include Source Code which i have clean up
