hbCURL and Email ?
Re: hbCURL and Email ?
I do send MASS emailing with CURL:
#include "hbcurl.ch"
#require "hbtip"
#require "hbssl"
PUBLIC cApiUrl     := "https://mandrillapp.com/api/1.0"   // API_URL
PUBLIC cAPIKey     := "somekey-d4590fdi90fdg80435rttt"    // API_KEY
PUBLIC cFromEmail  := "someome@website.com"               // MAN_FRMAIL
PUBLIC cFromName   := "Some One"                          // MAN_FRNAME
PUBLIC HTML_TEXT   := 'HTML'                              // MAN_HT_TXT
PUBLIC h, curlHandle, i, haTO, haTO_1, aTO, ahResp
// now begin sending
curlHandle := curl_easy_init()
IF EMPTY(curlHandle)
   Write_Trace('Error while init cURL lib '    )
 	MsgStop("Error while init cURL lib.")
   QUIT
// loop or something
      cID := Send_Mandrill(cTo2, cSubject, cHTML_XX, '' )
      IF cID # "!ERROR!"
         ? 'error'
//endloop
curl_global_cleanup( curlHandle )
FUNCTION Send_Mandrill(xTO, xSubject, xHtmlMess, xTextMess)
LOCAL cURL, aTO, i,  h, cFromEmail, cSubject, cFromName
 ? 'Send_Mandrill : Prepare for send message'
cURL        := cApiUrl + "/messages/send.json"
 ? 'cURL', cURL
IF cMAN_HT_TXT == 'HTML'
   cTextMess   := ""
   cHtmlMess   := xHtmlMess
   cTextMess   := xTextMess
   cHtmlMess   := ''
cSubject    := xSubject
cFromEmail  := cMAN_FRMAIL
cFromName   := cMAN_FRNAME
aTO         := {}
AADD(aTO, {xTO, xTO })
// add cc or bcc
haTO        := {}
FOR i = 1 TO LEN( aTO )
	haTO_1 := { => }
	haTO_1 [ "email" ] := aTO [i] [1]
	haTO_1 [ "name" ]  := aTO [i] [2]
	AADD (haTO , haTO_1)
NEXT i
cHtmlMess := hb_StrDecodEscape( cHtmlMess )
h                 := { => }
h [ "key" ]       := cAPIKey
h [ "message" ]   := {  "html"                        => hb_StrToUtf8( cHtmlMess, "FRWIN"), ;
				            "subject"                     => hb_StrToUtf8( cSubject , "FRWIN"), ;
                        "from_email"                  => cFromEmail, ;
                        "auto_text"                   => .F. , ;
                        "auto_html"                   => .T. , ;
                        "from_name"                   => cFromName, ;
                        "to"                          => haTO ,;
                        "headers"                     => {"Reply-To" => cFromEmail} }
h [ "async" ]     := .F.
h [ "ip_pool"]    := "Main Pool"
cPOSTdata         := hb_jsonEncode( h , .T. )
cResp             := SendMandrill( cUrl, cPOSTdata, curlHandle )
IF cResp = "!ERROR!"
   cID      := "!ERROR!"
	Write_Trace(   'Report errors ', cResp )
	hb_jsonDecode( cResp , @ahResp)
	Write_Trace(  'ahResp' , ahResp )
	Write_Trace(  'cResp ',  cResp )
   FOR i := 1 TO LEN( ahResp )
      cID := hb_HGet( ahResp [i] , "_id" )
RETURN cID
Code is not 100% written by me! CURL-Json by Edward(EDK)
Hope this can help.....
hi Serge,
serge_girard wrote: Wed Aug 24, 2022 6:58 amI do send MASS emailing with CURL:
thx for your Code.
i want to "test" it but don´t understand "how" it work
you point to JSON ... how does it look like :?:
PUBLIC cAPIKey
is it a UUID to use :?:
Hi Jimmy,
Most of the code was written by EDK (Edward) and JSON is beyond my knowledge.
First of all you need a Mandrill account+key. (see https://mailchimp.com/) Then it will give you access to the Mandrill API.
The aTO{} will contain (in my example) always 1 address.
I now see a function is missing in my example...Sorry, here it comes:
Function SendMandrill (cUrl, cPOSTdata, curlHandle)
Local curlErr, cReturn
curl_easy_reset( curlHandle )
curl_easy_setopt( curlHandle, HB_CURLOPT_URL, cUrl )
curl_easy_setopt( curlHandle, HB_CURLOPT_FOLLOWLOCATION, .T. )
curl_easy_setopt( curlHandle, HB_CURLOPT_SSL_VERIFYPEER, .F. )
curl_easy_setopt( curlHandle, HB_CURLOPT_DOWNLOAD )
curl_easy_setopt( curlHandle, HB_CURLOPT_DL_BUFF_SETUP )
curl_easy_setopt( curlHandle, HB_CURLOPT_USERAGENT, "Mandrill-Curl/1.0" )
curl_easy_setopt( curlHandle, HB_CURLOPT_POST, .T. )
curl_easy_setopt( curlHandle, HB_CURLOPT_POSTFIELDSIZE, LEN( cPOSTdata ) )
curl_easy_setopt( curlHandle, HB_CURLOPT_POSTFIELDS, cPOSTdata )
curlErr := curl_easy_perform( curlHandle )		/* Do everything */
IF !EMPTY( curlErr )	/* Report any errors */
	cReturn := "!ERROR!" + CRLF + curl_easy_strerror(curlErr)
	cReturn := curl_easy_dl_buff_get( curlHandle )
RETURN cReturn
Just signin to Mandrill (is MailChimp), create account etc, get an API-key and just try with this code (it works fine since almost 5 years now).
Remember it is not free although the website says 'Sign Up Free' (Sign Up is Free but using it is not...)
Hi Serge. Can u write which libraries are needed to compile this sample?
Marek,
I use this in my HBP file:
#hbmk2 options:
-lurlmon
In PRG:
#require "hbtip"
#require "hbssl"
And some DLL in attachement (CURL.RAR) +
2 rar files. Place them in folders with the names of the files.
curl-7.53.1-win32-mingw.rar
(2.17 MiB) Downloaded 108 times
curl-7.40.0-devel-mingw32.rar
(3.74 MiB) Downloaded 95 times
CURL.rar
(1.78 MiB) Downloaded 100 times
edk
Post by edk »
Here is an example I prepared for Serge once,
mandrill.7z
(2.85 MiB) Downloaded 132 times
you must have your API Mandrill Key.
It is a platform for mailing / conducting advertising and information campaigns.
Ricardo Arraes posted on ModHarbour function which sends messages with curl.
I've tested and it works!
Does anybody have contact to him?
Maybe he is able to help with communicating with imap server?
Maybe sb. will need, I'm placing here this function:
FUNCTION sendSmtp(wto, wfrom, wpsw)
  LOCAL hCurl,uValue,nHandle,cTxt:=""
  curl_global_init()
  if ! empty( hCurl := curl_easy_init() )
    cTxt:="From: Email Test <"+wfrom+">"+Chr(13)+Chr(10)+;
        "To: Somebody <"+Alltrim(wto)+">"+Chr(13)+Chr(10)+;
        "Subject: Sending email"+Chr(13)+Chr(10)+;
        "Date: Tue, 3 Feb 2021 20:40:16"+Chr(13)+Chr(10)+Chr(13)+Chr(10)+;
        "Hey, "+Chr(13)+Chr(10)+Chr(13)+Chr(10)+;
        "This is a test!"
    nHandle := Fcreate("C:\xampp\htdocs\example\tmp\test.txt")
    Fwrite(nHandle,cTxt )
    FClose(nHandle)
    curl_easy_setopt( hCurl, HB_CURLOPT_USE_SSL, HB_CURLUSESSL_TRY )
	  curl_easy_setopt( hCurl, HB_CURLOPT_UPLOAD )
    curl_easy_setopt(hCurl, HB_CURLOPT_USERNAME, wfrom)
    curl_easy_setopt(hCurl, HB_CURLOPT_PASSWORD, wpsw)
    curl_easy_setopt(hCurl, HB_CURLOPT_URL, "smtps://smtp.gmail.com:465")
    curl_easy_setopt( hCurl, HB_CURLOPT_PROTOCOLS, hb_bitOr( HB_CURLPROTO_SMTPS, HB_CURLPROTO_SMTP ) )
    curl_easy_setopt( hCurl, HB_CURLOPT_TIMEOUT_MS, 15000 )
    curl_easy_setopt(hCurl, HB_CURLOPT_FOLLOWLOCATION, 1)
    curl_easy_setopt(hCurl, HB_CURLOPT_SSL_VERIFYPEER, 0)
    curl_easy_setopt(hCurl, HB_CURLOPT_MAIL_FROM, wfrom)
    curl_easy_setopt(hCurl, HB_CURLOPT_MAIL_RCPT, {wto})
    curl_easy_setopt(hCurl, HB_CURLOPT_VERBOSE, 0)
    curl_easy_setopt(hCurl, HB_CURLOPT_UPLOAD, 1)
    curl_easy_setopt( hCurl, HB_CURLOPT_UL_FILE_SETUP, "C:\xampp\htdocs\example\tmp\test.txt" )
    IF (nret:=curl_easy_perform( hCurl )) == 0
      uValue := nret
      uValue:=nret
  curl_global_cleanup()
RETURN uValue
At now, I try to list IMAP folders.
There is a sample in curl library, but it is written in C, I'm very poor with it.
But I get error 77 described as 77 Problem with reading the SSL CA cert. The default or specified CA cert bundle could not be read/used to verify the server certificate.
There no info in sample to use any cert...
Even using windows curl to list folders, I'm getting them without any cert.
franco
Post by franco »
I do not understand what curl is.
I use gmail for sending emails. Is this not a good way. I have been using for many years.
Google has now set up a 2 step verification which allows send without setting security down. Google gives a special registered password,
just for email sending. The EXE is registered with google. I still use main password to going into account for setup.
I set forwarding to a different account for any return emails. This way the send account is only for sending out of my pos program.
I send invoices and Accounts Receivable Statements.
All The Best,
Franco
Canada
