CheckBox in a Grid Problem
Re: CheckBox in a Grid Problem
Red,
Make a small demo.prg with this grid and extract from your dbf. Then post it here!
Red2
- DBs Used: Visual FoxPro, FoxPro
Thank you all for you kind suggestions.
I made two discoveries about the ColumnControl for Column #1.
1) If ColumnControls[1] is {"CHECKBOX, "Yes", "No"} then my DynamicBackColor is not correct.
The part of DynamicBackColor that uses Column #1's Value Fails.
It should display a Column #1 .T. (value) row in GREEN.
I can successfully use {"CHECKBOX"} but still no CheckBox control appears. 2) Also, when this (Fails) happens I cannot programmatically read or update Column #1's Value.
Until today I did not know what was causing this incorrect Nil value "bug".
Mol: A ColumnControls[1] Value of NIL displays just the same as {"CHECKBOX"}. No CheckBox appears.
Serge, I will post some simple code that demonstrates my Grid.
Unfortunately I have some other things going on that will delay this for a day or two.
Thank you all for your great help!
Red2
llThisCellVal := GetProperty( "DataBrowse", "BrowseStates", "CellEx", lnGridRowNr, 1 ) // Always returns Nil!Mol: A ColumnControls[1] Value of NIL displays just the same as {"CHECKBOX"}. No CheckBox appears.
Red2
Hi, Red2 What field are you using for index. is it you checkbox field.
I just moved field 5 of samples grid36 to 1 andit works fine.
I will try to check DynamicBackColor now.
All The Best,
Franco
Canada
Franco
Canada
I don`t know if this what you want. Any other Dynamicbackcolor is I think the same grid problem I am having.
The only dynamicbackcolor I can get towork is row cells. if I add anything else it does not work.
This is grid36 in grid samples with my changes.
public bcolor := { || if( this.Cellrowindex/2 == int(this.CellRowIndex/2), {210,120,255}, {100,200,255})} // I added
* Grid Column Controls Definitions
aCtrl_1 := {'TEXTBOX','NUMERIC','9999999999'}
aCtrl_2 := {'TEXTBOX','CHARACTER'}
aCtrl_3 := {'TEXTBOX','CHARACTER'}
aCtrl_4 := {'DATEPICKER','UPDOWN'}
aCtrl_5 := { 'CHECKBOX' , 'Yes' , 'No' }
aCtrl_6 := {'TEXTBOX','CHARACTER'}
WIDTH 800 ;
HEIGHT 510 ;
TITLE 'Hello World!' ;
DEFINE MAIN MENU
POPUP 'File'
ITEM 'Append (Alt+A)' ACTION Form_1.Grid_1.Append
ITEM 'Set RecNo' ACTION Form_1.Grid_1.RecNo := val(InputBox('',''))
ITEM 'Get RecNo' ACTION MsgInfo( Str(Form_1.Grid_1.RecNo) )
ITEM 'Delete (Alt+D)' ACTION Form_1.Grid_1.Delete
ITEM 'Recall (Alt+R)' ACTION Form_1.Grid_1.Recall
ITEM 'Get Value' ACTION ( aValue := Form_1.Grid_1.Value , MsgInfo( Str( aValue [1] ) + ' , ' + Str( aValue [2] ) ) )
ITEM 'Set Value' ACTION ( aValue [ 1 ] := val(InputBox('New Row','Selected Cell (Value)')) , aValue [ 2 ] := val(InputBox('New Col','Selected Cell (Value)')) , Form_1.Grid_1.Value := { aValue [ 1 ] , aValue [ 2 ] } )
ITEM 'Save Pending Changes (Alt+S)' ACTION Form_1.Grid_1.Save
ITEM 'Clear Changes Buffer (Undo) (ALt+U)' ACTION Form_1.Grid_1.ClearBuffer
END POPUP
END MENU
SELECT 1
USE TEST ALIAS TEST
INDEX ON CODE TO TEST_CODE
GO TOP
SELECT 2
USE CHILD ALIAS CHILD
INDEX ON CODE TO CHILD_CODE
GO TOP
SELECT 1
SET RELATION TO CODE INTO CHILD
GO TOP
@ 10,10 grid Grid_1 ;
WIDTH 770 ;
HEIGHT 440 ;
HEADERS {'Column 5','Column 1','Column 2','Column 3','Column 4','Column 6'} ;
WIDTHS {100,140,140,140,100,110}; // I changed
FONT "ARIAL" SIZE 8;
EDIT ;
VALUE { 1 , 1 } ;
COLUMNCONTROLS { aCtrl_5 , (aCtrl_1) , aCtrl_2 , aCtrl_3 , aCtrl_4 , aCtrl_6 } ; // I changed
ROWSOURCE "Test" ;
COLUMNFIELDS { 'Married', 'Code' , 'First' , 'Last' , 'Birth' , 'child->info' } ; // I changed
ALLOWDELETE ;
DYNAMICBACKCOLOR {BCOLOR,BCOLOR,BCOLOR,BCOLOR,BCOLOR,BCOLOR} // I added
CENTER WINDOW Form_1
All The Best,
Franco
Canada
Franco
Canada
Red2,
Such a small demo as this will do:
FUNCTION MAIN()
aARQ := {}
AADD( aARQ , { 'F1' , 'N' , 7 , 0 } )
AADD( aARQ , { 'F2' , 'C' , 10 , 0 } )
AADD( aARQ , { 'F3' , 'C' , 10 , 0 } )
AADD( aARQ , { 'F4' , 'D' , 8 , 0 } )
AADD( aARQ , { 'F5' , 'L' , 1 , 0 } )
AADD( aARQ , { 'F6' , 'C' , 10 , 0 } )
DBCREATE( "TESTRED2" , aARQ )
SELECT 1
USE TESTRED2
GO TOP
APPEND BLANK
REPLACE F1 WITH 123
REPLACE F2 WITH '123'
REPLACE F3 WITH '123'
REPLACE F4 WITH DATE()-123
REPLACE F5 WITH .f.
REPLACE F6 WITH 'F6'
APPEND BLANK
REPLACE F1 WITH 321
REPLACE F2 WITH '312'
REPLACE F3 WITH '321'
REPLACE F5 WITH .T.
APPEND BLANK
REPLACE F1 WITH 123
REPLACE F5 WITH .f.
APPEND BLANK
REPLACE F1 WITH 321
REPLACE F5 WITH .T.
aCtrl_5 := {'CHECKBOX' , 'Yes' , 'No' }
WIDTH 800 ;
HEIGHT 510 ;
TITLE 'Hello Red2!' ;
WIDTH 770 ;
HEIGHT 440 ;
HEADERS {'Column 1','Column 2','Column 3','Column 4','Column 5','Column 6'} ;
EDIT ;
VALUE { 1 , 1 } ;
COLUMNCONTROLS { aCtrl_1 , (aCtrl_2) , aCtrl_3 , aCtrl_4 , aCtrl_5 , aCtrl_6 } ;
ROWSOURCE "TESTRED2" ;
COLUMNFIELDS { 'F1', 'F2' , 'F3' , 'F4' , 'F5' , 'F6' } ;
ALLOWDELETE ;
Yes Serge, but I think Red2 wants his checkbox cell to be red when .F., green when .T.
All The Best,
Franco
Canada
Franco
Canada
Red2
Hi Everyone,
Thank you all for your kind suggestions and advice!
In the attached .ZIP file is my example code.
1) It uses HMG's IDE
2) It creates the sample .DBF file that the Grid displays.
3) Column #1 of the Grid, displays the Logical field, By_State->MergeState
4) The Grid's COLUMNCONTROLS array is generated in function DataBrowse_OnInit()
I REALLY appreciate everyone's ideas and guidance.
Thanks again,
Red2
Thanks again,
Red2
- Example_14-August.ZIP
- (3.93 KiB) Downloaded 126 times
Hi Red2
I can't get it working neither..! Maybe Grigory has a solution?
- AUGE_OHR
hi Red,
i have look into your Sample and wonder why you use COLUMNCONTROLS
i do not "see" that COLUMNCONTROLS "in Header" of GRID.
i do "see" .F. / .T. in 1st Column
i have try with GRID ... but it seem not to work ...
here a Sample using BROWSE which work
Red2
Hi JImmy,
Thank you for your kind suggestion. I appreciate it.
More Information:
My display originally used a Browse Control.
I changed it to a Grid Control so Column #1 would display a CheckBox.
For my needs a Grid works OK because no rows will ever be added or deleted.
I want the user to interact with Column #1 using a CheckBox.
The HMG sample C:\HMG.3.4.4\Samples\Controls\Grid\Grid_CheckBoxes\Demo.PRG is appropriate: Unfortunately I have been not been able to make this happen using:
1) The HMG IDE and
2) Displaying a .DBF table instead of a data Array.
I am still looking for a successful result.
Thank you again for your expert guidance.
Red2
More Information:
1) The HMG IDE and
Red2
