Print Problem
martingz
Print Problem
Post by martingz »
The following problem has happened to someone, until about 3 - 4 months ago, the printing system worked correctly, now the printer indicates that it is ready, but it does not print the entire print run, this does not always happen
I use HMG 3.4.2
Español
A alguien la a sucedido el siguiente problema, hasta hace unos 3 - 4 meses, el sistema de impresion trabajaba correctamente, ahora la impresora indica que esta lista, pero no me imprime todo el tiraje, no siempre pasa esto
Uso HMG 3.4.2
Re: Print Problem
Try to print to TXT file and see content...?
martingz
Re: Print Problem
Post by martingz »
the receipt has text, images, 1 qr and barcode, and 20,000 are printed every 5 days, the strangest thing before did not fail
thank you very much for your attention
Re: Print Problem
how "old" is the Printer ( Printer Name / Type ) :?:
martingz wrote: Sat Jun 18, 2022 3:58 pm20,000 are printed every 5 days
this is about 1460000 a Year which will "Stress" Printer "Mechanic"
martingz wrote: Sat Jun 18, 2022 3:58 pm now the printer indicates that it is ready, but it does not print the entire print run, this does not always happen
how did you check Status of Printer when printing :?:
the "Rubber" which transport Paper will become "old" so Printer can show "Paper Empty".
Pcmodula
Re: Print Problem
Post by Pcmodula »
martingz wrote: Fri Jun 17, 2022 6:46 pm The following problem has happened to someone, until about 3 - 4 months ago, the printing system worked correctly, now the printer indicates that it is ready, but it does not print the entire print run, this does not always happen
I use HMG 3.4.2
Español
Uso HMG 3.4.2
Hi, i can suggest Two test:
1) disable snmp option Port , this solve mechanic printer trouble that os detect, if success change/ revise the printer
2) Check the spooler clear the print queues. Eventually stop the service, wait a bit and start the service.
From dos type services.msc looking for spooler.
If the restart Is successful the trouble can be located in your os. My esperience suggest stop and start, not the direct restart.
Good luck
Pcmodula
Re: Print Problem
A few years ago I had the problem print spooler had stopping by itself
martingz
Re: Print Problem
Post by martingz »
Printer Laser Ricoh 5200 DN
We use 5 printers, every one print 4000+ , the printers are rented and at the slightest problem they must change them
Pcmodula
the problem is that sometimes the spooler is clean and should contain jobs and other times it is full but the printer marks ready to print
Mol
that's exactly what happens
thank you all for your comments, with everyone's help, I came to the conclusion that the problem is the spooler, I'll try to send them directly to the printer without using the spooler and see what happens
greetings and thanks
martingz
Re: Print Problem
Post by martingz »
Returning to the topic in case it helps someone
The problem continued
printing directly to the printer the problem continues, the printer says that it is ready and there are jobs to print
It does not print all the invoices, that is, it prints some and not others, without showing an error
Lastly, the PageScript32 library was used, and none of the previous problems occurred.
Cheers
Retomando el tema por si a alguien le sirve
El problema continuo,
imprimiendo directamente a la impresora el problema continua, la impresora dice que esta lista y hay trabajos por imprimir
No imprime todas las facturas , es decir imprime algunas y otras no, sin mostrar error
Como ultimo se utilizo la libreria PageScript32, y ninguno de los paroblemas anteriores se presento
Pcmodula
Re: Print Problem
Post by Pcmodula »
martingz wrote: Fri Jul 08, 2022 3:27 pm Returning to the topic in case it helps someone
Cheers
Do you use hbprinter previous?
something similar had happened to me in the past, but I haven't solved it.
it would be interesting to find out if it also happens with miniprint ..
Pcmodula
Re: Print Problem
did you get "Status" Message like "no Paper" after each Page :?: ( HMG_PrintGetJobInfo )
