hbCURL and Email ?
hbCURL and Email ?
hi
i have read that hbTIP may make Problem and hbCURL should be used.
did somebody have a Email-Solution using hbCURL and OpenSSL :?:
Pcmodula
Re: hbCURL and Email ?
Post by Pcmodula »
AUGE_OHR wrote: Wed Jun 29, 2022 2:55 pm hi
Hi Jimmy, Minigui Extended can help you.
Search Sendmail2.
It contain 3 types of send.
Socket, cdo, curl and i have tested It with one account that require SSL settings.
Can be a start for solve your request.
Have fun
Pcmodula
Pcmodula wrote: Wed Jun 29, 2022 4:50 pm Search Sendmail2.
i can´t find "Sendmail2" :(
can you point me please in which Folder i found Sample with "Sendmail2" (MiniGUI Version ? )
Pcmodula
Post by Pcmodula »
AUGE_OHR wrote: Wed Jun 29, 2022 5:06 pm hi,
samples\Applications\SendMail2
If my memory don't fail
I suggest to check into changelog.txt of this year.
Pcmodula
Pcmodula wrote: Wed Jun 29, 2022 8:17 pm Search Sendmail2.
have just upgrade to latest MiniGUI Extendet Version and found SendMail2
      do case
         case adata[2][9]   // use Cdo
         case adata[2][8]   // use Curl
       OtherWise           // use Tsmtp by Matteo Baccan
so i search for TSMTP and found
c:\minigui\SOURCE\Socket\tsmtp.prg
c:\minigui\SOURCE\Socket\tpop3.prg
but looking into Source i do not found SSL / TLS ... but (old) Port 25 ... hm
i guess both CLASS does not handle SSL / TLS > 1.1 which is need now
as i know Collaboration Data Objects (CDO) is not support any more since Server 2016
Server 2016 now use Exchange Web Services (EWS) but it have no COM Interface.
not sure if CDO will work in Future
CURL.EXE is Part of Windows 10/11 and use Parameter for Email.
Question : are hbCURL and CURL.EXE the "same" :?:
i will try CURL.EXE Way but i would prefer to use hbCURL "internal" in my Apps
thx for help
Hi Jimmy
TRY download Curl
example : https://curl.se/windows/dl-7.84.0_3/cur ... -mingw.zip
extract and copy to folder
2022-07-01 22_25_55-curl.png (13.27 KiB) Viewed 3768 times
use this batch
set HB_WITH_CURL=C:\curl\include
set HB_STATIC_CURL=yes
set path= %path%;c:\hmg.3.5
build64  hbcurl.hbp
pause
in folder
2022-07-01 22_28_10-hbcurl.png (13.11 KiB) Viewed 3768 times
see content in build.log
hbmk2: Construyendo sub-proyecto (nivel 2): hbcurls.hbp
hbmk2: Dependencia 'curl' encontrada: C:\curl\include
hbmk2: Harbour: Compilando m¢dulos...
Harbour 3.2.0dev (r1604201603)
hbmk2: Compilando...
In file included from C:/curl/include/curl/curl.h:3103:0,
from ../../../../core.c:49:
../../../../core.c: In function 'HB_FUN_CURL_EASY_GETINFO':
C:/curl/include/curl/typecheck-gcc.h:139:13: warning: call to '_curl_easy_getinfo_err_curl_certinfo' declared with attribute warning: curl_easy_getinfo expects a pointer to 'struct curl_certinfo *' for this info
_curl_easy_getinfo_err_curl_certinfo(); \
../../../../core.c:1787:60: note: in expansion of macro 'curl_easy_getinfo'
#define HB_CURL_EASY_GETINFO( hb_curl, n, p ) ( hb_curl ? curl_easy_getinfo( hb_curl->curl, n, p ) : ( CURLcode ) HB_CURLE_ERROR )
../../../../core.c:1975:19: note: in expansion of macro 'HB_CURL_EASY_GETINFO'
res = HB_CURL_EASY_GETINFO( hb_curl, CURLINFO_CERTINFO, &ret_slist );
hbmk2: Creando librer¡a est tica... libhbcurls.a
hbmk2[hbcurl]: Advertencia: Fuentes de Biblioteca de importaci¢n no se
encontraron.
hbmk2: Creando librer¡a est tica... libhbcurl.a
thx for Answer.
i found out that my Enail Provider WEB.DE make much Problem with SendMail2 Sample
when send from my 2nd Email Account T-ONLINE.DE -> WEB.DE a Email using CURL.EXE i got
The mail system
<Auge_Ohr@Web.DE>: host mx-ha02.Web.DE[212.227.17.8] said: 554-Transaction
failed 554-Reject due to policy restrictions. 554 For explanation visit
https://web.de/email/senderguidelines?i ... 34.81&c=hi (in reply to
end of DATA command)
"send" Email using
aadd(acCmd, "--ssl-reqd --url smtps://")
with Port 587 i got
curl: (35) schannel: next InitializeSecurityContext failed: SEC_E_INVALID_TOKEN (0x80090308) - Das Token, das der Funktion übergeben wurde, ist ungültig.
using Port 465
i got
##O#-#
curl: (67) Login denied
without "s"
aadd(acCmd, "--ssl-reqd --url smtp://")
with Port 587 i got
##O#-#
using Port 465
##O#-#
##O=# #
-#O#- # #
-=O#-# # #
-=O=# # # #
-=O=-# # # #
-=O=- # # # #
-=O=- # # # #
curl: (56) response reading failed
but it work with T-ONLINE.DE so it is a Problem of WEB.DE :!:
when try to send from WEB.DE these Parameter are recommend by WEB.DE
smtp.web.de
STARTTLS Port 587
so did CURL.EXE don´t know STARTTLS :?:
any Idea what i can do :idea:
p.s. it work with HbTIP and OpenSSL v1.0.2.20
i have change some Code and Login "seems" to work but later still got Error
CURL.EXE --insecure --ssl-reqd --url smtps://smtp.web.de:465 --user XXXXXXXX@web.de:Password --mail-from XXXXXXXX@web.de --mail-rcpt YYYYYYYY@t-online.de --stderr G:\minigui\2\SendMail\CurlReply.txt --upload-file G:\minigui\2\SendMail\Template.eml
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   346    0     0  100   346      0   1114 --:--:-- --:--:-- --:--:--  1119
curl: (56) Failure when receiving data from the peer
so what is Error 56 mean ... :?:
have found many Message about it but none belong to Email
need some Idea :idea:
Hi!
Did you resolve your problem?
I want to connect to this topic with such a problem.
I want to leave a copy of the sent mail on the mail server sent items folder.
Does anybody know how to do it?
For simple email-sending (not mass-bulk) I use Thunderbird-Mozilla command-line.
This works fine but sending email needs manual click on send-button...
