Run Process -> Return Handle
i want to run many Instance of App but i need "Control" them.
as they all have "same Name" i can´t use "FindWindow" to get Handle
so how can i "run" a Instance and get it´s Handle under harbour :idea:
attached Xbase++ Sample using OT4XB Syntax
TRunProcess.zip
(3.95 KiB) Downloaded 61 times
Re: Run Process -> Return Handle
hi
it seems that ShellExecute() return
  HMG_retnl ((LONG_PTR) hInstance );
https://docs.microsoft.com/en-us/window ... llexecutea
If the function succeeds, it returns a value greater than 32. If the function fails, it returns an error value that indicates the cause of the failure. The return value is cast as an HINSTANCE for backward compatibility with 16-bit Windows applications. It is not a true HINSTANCE, however. It can be cast only to an INT_PTR and compared to either 32 or the following error codes below.
hi
i try it this Way
   hwnd := ShellExecute(0, "open", "Playvlc.exe", cPara,cHome ,1)
   AADD(aWin, hwnd)
it does start "Playvlc.exe" as i want but i have always 42 as hwnd ... :(
what do i miss ... :idea:
found out that i can find "Title" even when use NOCAPTION
so i can "search" for Windows and it´s Handle after call ShellExecute()
PROCEDURE GetVLChandle()
LOCAL cTitle, hwnd, ii, iMax, cMemo
   iMax := nRow * nCol
   FOR ii := 1 TO iMax
      cTitle := "PLAYVLC" + STRZERO( ii, 2 )
      hwnd := FindWindowEx(,,, cTitle )
      IF !EMPTY( hwnd )
         WritePlay( cTitle + ".PLAY", STR( hwnd ) )
         AADD( aWin, hwnd )
! Note : i write a "Number" ... not a String ?!
STATIC PROCEDURE CheckCloseScreen()
   IF lCheckScreen = .T.
      aDir := DIRECTORY( "PLAYVLC*.PLAY" )
      iMax := LEN( aDir )
      FOR ii := 1 TO iMax
         IF ".PLAY" $ aDir[ ii ] [ F_NAME ]
            nCount ++
            cMemo := ReadPlay( aDir[ ii ] [ F_NAME ] )
            AADD( aCheck, cMemo )
      IF nCount <> nOpenVLC
         lCheckScreen = .F.
         iMax := LEN( aWin )
         FOR ii := 1 TO iMax
            hProcess := aWin[ ii ]
            SendMessage( hProcess, WM_CLOSE, 0, 0 )
            hb_idleSleep( .1 )
         Domethod( "IPTVMAIN", "PLAYTV", "SHOW" )
         SnapToCtrl("IPTVMAIN","PLAYTV")
