Migration from HMG to HMG Minigui
- dragancesu
Re: Migration from HMG to HMG Minigui
Remember dos time
In batch use command mode 80,25
If have minimized put mode 1,1
I send a ZIP file containing a tiny BAT_TEST.PRG ....
2 exe files: BAT_TEST.EXE compiled with HMG and BAT_TEST_MG.EXE compiled with MiniGui.
2 bat files: BT.BAT and BTMG.BAT to call BAT_TEST.EXE and second to call BAT_TEST_MG.EXE
Now put all in a new folder and the on your desktop create a shorcut to BT.BAT and then a shortcut to BTMG.BAT
Clicking on BT.BAT will open 1 window and BTMG.BAT 2 windows...
Now how to get rid of second window ?
- bat-test.zip
- (2.73 MiB) Downloaded 360 times
Serge,
Please modify the following line in your batch file combt.bat:
as belowhbmk2 bat_test.hbp bat_test.hbc c:\minigui\harbour\bin\minigui.hbc -inc -comp=bcc -beep -o%oname% -exitstr -Lc:\minigui\lib
That's allhbmk2 bat_test.hbp bat_test.hbc -gtgui c:\minigui\harbour\bin\minigui.hbc -inc -comp=bcc -beep -o%oname% -exitstr -Lc:\minigui\lib
Brilliant Grigory ! Many Thanks
Bonsoir tout le monde
très intéressant , Mr Serge avez vous réussi votre migration de HMG a minigui extended ? , car je pense aussi le faire
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Oui, Tonton!
C'etait très facile!
Merci mon ami , je vais essayer de le faire également
Y.TABET
Y.TABET
Commence avec des application simple/petits..!
trés bien et merci
Y.TABET
Y.TABET
Première phase premier problème inexpliqué
Trouver l'erreur
C:\MINIGUI\IDE\SAMPLES\GESTIO~1\gestion.Prg(41) Error E0030 Syntax error "syntax error at 'WINDOW'"
- First_TRY.PNG (29.2 KiB) Viewed 25678 times
Y.TABET
Y.TABET
